Accurate mileage tracking is what turns a work drive into a deductible record. IRS Publication 463 sets the recordkeeping standard, and the 2026 IRS mileage-rate announcement only helps after the trip is classified correctly.
Start tracking before the first work trip, record the business purpose while it is still easy to explain, keep receipts that support the chosen method, and review the file at least weekly. If you want the trip record captured automatically before you sort the tax details, MyCarTracks automatic mileage tracking can do the first pass for you.
Which mileage categories can create a deduction
Mileage deductions are not one single bucket. The current federal categories are business mileage, charitable mileage, medical mileage, and the limited moving category for eligible active-duty Armed Forces members and certain intelligence community members.
For 2026, the IRS standard mileage rates are 72.5 cents per mile for business, 20.5 cents for medical, 20.5 cents for eligible moving, and 14 cents for charitable service. Keep the category straight before you start multiplying anything, because the record and filing rules are not identical across those uses.
What the IRS expects before you claim anything
The IRS does not ask you to submit your mileage log with a return, but it does expect adequate records if the trip is ever reviewed. That means the file needs the date, destination, mileage, and business or qualifying purpose for each trip, kept at or near the time of travel rather than rebuilt from memory months later.
That standard matters whether you plan to use the standard mileage method or compare it with actual expenses. The deduction method changes the year-end math, but it does not remove the need for a clean trip record.
Tracking rules for self-employed work
If you are self-employed, the trips that usually matter most are customer visits, temporary work locations, supply runs, bank trips, post office stops, and travel between business locations. The usual commute from home to a regular workplace still needs careful treatment, especially if the home office question is unsettled.
Many sole proprietors report the result on Schedule C, which is why the log should match the vehicle, tax year, and deduction method you used.
How business owners and employees should separate the workflow
A business owner tracking a deduction and an employee submitting reimbursement may use similar trip details, but they are not running the same process. Owners and contractors are usually building a deduction file. Employees are usually building a substantiated claim for an employer.
If both groups drive in the same business, keep the labels clear so reimbursement records do not get mixed into the deduction file by mistake.
Mileage tracking habits that keep tax records usable
Use this checklist as the working routine:
- Keep a trip-by-trip driving log. Record the date, route, purpose, miles, and vehicle used for each qualifying drive.
- Save supporting receipts when the method needs them. Parking, tolls, and actual-expense records belong with the trip file instead of floating in a separate folder.
- Record the odometer at the start of the tax year. That gives you a clean baseline for total vehicle use.
- Record the odometer at the end of the tax year. This helps support the business-use percentage when one vehicle handles both work and personal driving.
- Use the right tax-year rate or method. Do not price older miles with a newer rate.
- Keep the documents after filing. Save the export, notes, receipts, and any correction history together in case someone asks later.
How to calculate the deduction after the log is clean
The standard mileage method uses one simple formula:
qualifying business miles x the rate for that tax year = mileage deduction amount
If you use actual expenses instead, total the supported vehicle costs and apply the business-use percentage from the mileage record. The more mixed-use the vehicle is, the more important those start-of-year and end-of-year odometer readings become.
How to stay ready for an audit or review
Good mileage tracking is really audit preparation done early. Keep the trips organized by year and vehicle, and make sure unusual routes, late edits, and corrections are explained while the details are still easy to verify.
The IRS can request records later, and its audit records guidance is much easier to deal with when the log, receipts, and year-end totals already match.
Manual logs, spreadsheets, and mileage apps
| Method | Best use | Main weakness |
| Paper log | low trip volume and simple solo use | easy to forget or backfill from memory |
| Spreadsheet | shared review and simple formulas | still depends on manual entry |
| Mileage tracking app | higher trip volume, mixed-use vehicles, or team reporting | still needs classification and review |
The best system is the one you will maintain weekly. A perfect template that sits untouched for months is weaker than a simple process that stays current.
Why weekly review beats year-end cleanup
Weekly review is where most deduction files are either saved or weakened. It is much easier to split a personal detour, fix the business purpose, or attach a toll receipt on Friday than it is during tax season.
If you need cleaner exports by driver, vehicle, or tax year, MyCarTracks mileage reports can help turn the weekly log into a year-end file without rebuilding the route history from scratch. For the broader product overview behind the reporting workflow, use the MyCarTracks homepage.
- Identify the person or entity using the record: employee, employer, self-employed worker, volunteer, contractor, owner, or fleet manager.
- Identify the purpose: reimbursement, deduction, payroll support, job costing, customer billing, vehicle program review, or fleet reporting.
- Identify the tax year and the US rule set that applies. Do not mix business, medical, moving, charitable, reimbursement, and state-law rules in one calculation.
- Confirm whether the trip qualifies under the relevant source. A route can be real and still be personal, commuting, or outside the policy.
- Apply the rate, method, or program only after the trip record is complete.
- Save the source, report, approval, and payment record together.
Mileage log workflow
A mileage log should be maintained as work happens, not reconstructed from memory. The weekly workflow is simple: review new trips, classify each one, split personal stops, add business purpose notes, attach route costs, and export exceptions for correction.
For teams, the log should also show driver, vehicle, approval status, and project or client tag. For self-employed workers, it should preserve total vehicle use where required. For employees, it should match the reimbursement policy fields.
Suppose a worker reviews trips every Friday. They classify customer visits, split a personal stop, add a project tag, attach a toll receipt, and mark one unclear route for correction. By month-end, the export already has clean records instead of guesses.
That weekly habit is what makes the log useful for taxes, reimbursement, and manager review.
Save the official source used for each rate, rule, or policy decision. For public articles, that means linking to the IRS or the relevant state source rather than repeating unsupported third-party claims. For internal company use, it means saving the policy version and source rate that were active when the trip was paid. This matters when a reader later asks why a 2026 trip was calculated differently from a 2025 trip, or why one state required a different reimbursement workflow from another state.
- Is the trip business, commuting, personal, medical, charitable, or another category?
- Is the rate from the correct tax year and rule set?
- Are different trip categories kept separate?
- Does the record name the vehicle and driver?
- Does the business purpose make sense without extra memory?
- Are parking, tolls, and other route costs handled separately?
- Are total annual vehicle miles needed?
- Is the reimbursement policy saved with the report?
- Are state-specific rules relevant?
- Is a professional review needed before filing, payroll, or policy decisions?
Get tax, payroll, legal, or accounting review when the answer affects a filed return, employee wages, worker classification, taxable benefits, multi-state reimbursement, FAVR design, or a dispute over unpaid expenses. A mileage app can make the record cleaner, but it cannot decide the legal or tax treatment by itself.
- date of each trip
- start and end location, destination, route, or client/job context
- distance driven
- driver or employee name when a team is involved
- total odometer readings where required
- receipts for fuel, charging, repairs, parking, tolls, insurance, registration, and other vehicle costs
- reimbursement requests, approvals, denials, and employer policy documents
- tax-year rate source used for each calculation
- using the current rate for an older tax year
- mixing commuting, personal errands, and business miles
- saving only payout, calendar, or bank records without a mileage log
- forgetting total annual miles when actual expenses or business-use percentages matter
- treating an employer reimbursement policy as if it were a tax rule
- treating a tax rule as if it were an employer reimbursement promise
- missing parking, tolls, support trips, return trips, and supply runs
- waiting until tax season to explain routes from memory
- Record trips automatically.
- Classify business and personal driving while the trip is still fresh.
- Add tags for employee, vehicle, client, project, platform, or state.
- Review mileage weekly so personal stops and unclear routes are fixed early.
- Export reports by tax year, pay period, vehicle, driver, or reimbursement cycle.
- What Is a Mileage Log?
- IRS Mileage Log Requirements
