Walmart Spark Tax Forms
If you drive for Walmart Spark, tax forms are only part of the filing picture. You still need your own mileage tracking, payout records, and expense file so you can report the income correctly and back up the tax deduction side of the return.
This guide stays focused on the forms and document workflow: which forms you may receive, where to find them, what to do if one is missing or wrong, how the forms connect to filing, and which records you should keep alongside them.
Which tax forms Spark drivers may receive
As a Spark driver, you may receive one or more of these year-end records:
  • 1099-NEC: Used for nonemployee compensation. Drivers who earned at least $600 should generally receive it by January 31.
  • 1099-K: You may also receive this if payments were processed through a third-party payment network and the reporting rules apply.
  • Annual Summary Or Earnings Report: Not an IRS form, but still useful when filing if it helps you compare your own totals against the platform’s records.
Even if none of these forms arrive, you still have to report taxable Spark income.
Where to find your Spark tax documents
Spark tax records may not always arrive through one simple channel. The practical places to check are:
  • The Spark app or related payment portal
  • The tax-documents or payments section inside that system
  • Your email around January
If you are not sure who handled the payout documents, use Spark support and your onboarding messages to confirm where the forms are being delivered.
What to do if you did not get a 1099
You are still responsible for reporting the income.
If you expected a form and do not see it:
  • Check your spam or promotions folders
  • Log into the platform or payment portal
  • Contact the payout or support team
  • Use your own payout history and annual records as backup
One threshold matters even if a form is missing: if you earned $400 or more in net self-employment income, you may still need to file and pay self-employment tax.
What to do if the form looks wrong
Do not ignore a form that has the wrong amount, the wrong name, or the wrong address. Request a corrected form as early as possible so your filed return does not start with a mismatch.
Keep:
  • The Original Form
  • The Error You Noticed
  • Support Messages
  • Payout History
  • Deposit Records
Those records make it easier to explain the correction request.
How the forms connect to filing your Spark taxes
The forms do not replace your return. They support it.
Most Spark drivers will still use:
If you want the broader filing workflow, use Walmart Spark Tax Guide. If you want the category-by-category write-offs, use Walmart Spark Tax Deductions.
Why mileage tracking belongs in the forms article too
Tax forms show income reported to the IRS. They do not show your mileage logs or your deductible business costs. That is why mileage tracking still belongs in the same filing folder as your forms.
Keep:
  • Mileage Logs
  • Receipts
  • Parking And Toll Records
  • Spark Earnings Summaries
  • Deposit History
  • Tax Forms
If you need the mileage-log rules themselves, use How to Track Mileage for Tax Deductions.
Spark tax checklist
Before you file, make sure you:
  • Download all 1099s and annual summaries
  • Check them for errors
  • Follow up on anything missing
  • Organize mileage logs and expenses
  • Keep the filing schedules ready with the rest of the tax file
This forms article is written around the US Spark workflow. If you are comparing delivery-platform tax records in Canada or Europe, keep the same recordkeeping discipline but use the forms and filing rules that apply in that country.
Use MyCarTracks automatic mileage tracking to keep the mileage side of the filing file current, then export it through MyCarTracks business mileage reports. For the broader product overview, use MyCarTracks.
Which Spark tax form is most common for drivers?
The most common year-end contractor form is usually the 1099-NEC, though some drivers may also see a 1099-K depending on the payment flow.
Do you still need to report income if no form shows up?
Yes. Missing forms do not remove the obligation to report taxable income.
What should you do if your Spark form is wrong?
Save the form, compare it with your payout records, and request a correction before filing if the amounts or personal details are wrong.
