If you drive for Walmart Spark, mileage tracking is one of the most valuable records you control. The miles you drive for deliveries can reduce your taxable income, support your vehicle deductions, and show whether an offer was actually worth the time and wear on your car.
That matters because Spark work uses your own vehicle, your own gas, and your own route time. If you want the tax deduction, the IRS expects a mileage log that shows what you drove, when you drove it, and why the trip was for business.
Why mileage tracking matters for Spark drivers
Spark drivers are treated as self-employed for the US tax workflow in the current source set, which means the business use of your car can become a deductible expense. That is why mileage is not just a note for later. It is part of your tax file and part of your weekly profit review.
There are two common ways to deduct vehicle use:
- The Standard Mileage Rate
- The Actual Expense Method
You can only use one method for the same vehicle in the same tax year, so the recordkeeping has to support whichever method you choose.
Which Spark miles can count as business mileage
Not every mile you drive in a workday counts. The miles need to be tied to an ordinary and necessary business purpose.
Business mileage can include:
- Driving to Walmart after you have accepted an order
- Delivering groceries or general merchandise to customers
- Driving between customer stops on a batch route
- Returning items when the delivery requires it
- Driving to buy delivery supplies or other business gear
The same trip can also include non-deductible miles, so it helps to note where the business route stopped and the personal route began.
Which miles usually should stay out of the deduction
Personal miles do not become deductible just because you worked that day.
Miles that usually do not count include:
- Personal errands before or after a Spark trip
- Personal Walmart shopping
- Unrelated commuting-style driving
- Personal side trips in the middle of a route
- Miles for another app unless you tag them separately
If you are unsure about a trip, record it anyway and classify it later. A complete log with personal segments marked clearly is better than trying to rebuild the day from memory.
How to deduct Spark mileage on your taxes
How the standard mileage rate works
The standard mileage rate is the simpler method for many drivers because you mainly need clean business-mile totals. For 2026, the IRS business mileage rate is 72.5 cents per mile.
To use it, you:
- Track your qualifying Spark business miles
- Multiply those miles by the IRS rate for the year
- Keep the mileage log in case the deduction is ever questioned
Parking fees and tolls tied to the business route can usually still be tracked separately. If you want the broader method comparison, use Standard Mileage Rate vs Actual Expenses.
How the actual expense method works
The actual expense method is more detailed because it uses the business-use share of your real vehicle costs. That can include:
- Depreciation
- Lease Payments
- Registration Fees
- Licenses
- Insurance
- Repairs
- Gas Or Charging
- Garage Rent
- Tires
- Oil
- Tolls
- Parking Fees
You calculate your business-use percentage by comparing business miles with total annual vehicle miles, then apply that percentage to the eligible costs.
For example, if you drove the car 20,000 total miles for the year and 15,000 of those miles were for Spark or other business use, the business-use share would be 75%. If your eligible vehicle costs were $8,000, the deductible business portion would be $6,000.
Which method is often better for Spark drivers
It depends on your vehicle costs and how many miles you drive, but many high-mileage drivers find the standard mileage rate simpler and often more favorable.
The actual expense method can be worth the effort if your vehicle costs are unusually high. The only reliable way to know is to track both your miles and your costs cleanly enough to compare them.
What the IRS expects from your mileage log
The IRS wants a record created close to when the driving happened, not a guess at tax time. A useful Spark mileage log should show:
- Date
- Distance
- Starting Point
- Ending Point
- Business Purpose
- Vehicle Used
- Total Annual Miles For The Vehicle
- Parking And Toll Records Where Relevant
If you want a deeper guide to the log format itself, use How to Track Mileage for Tax Deductions.
Final mileage tips for Spark drivers
- Use a mileage tracker app so the route is captured while it happens.
- Stay consistent instead of rebuilding trips at the end of the month.
- Do not guess. Estimated miles are weaker than a contemporaneous log.
- Combine mileage records with your other business deductions instead of treating mileage as a standalone note.
The IRS generally expects you to keep tax records for at least three years, so save the mileage log with your payout records, receipts, and tax forms.
The current Spark source set is strongest for the United States, so the mileage deduction workflow in this article is US-first.
For Canada, the reusable comparison point is still vehicle recordkeeping: keep total kilometres, business kilometres, trip purpose, and vehicle-by-vehicle logs cleanly separated. For Europe, use local country rules for VAT, worker status, and vehicle deductions rather than assuming the US Spark model applies there.
Use MyCarTracks automatic mileage tracking to record Spark trips while you drive, then review them in MyCarTracks business mileage reports. For the broader product overview, use MyCarTracks.
Can Spark drivers deduct the miles they drive for deliveries?
Yes. If the miles are business-related and you keep a proper log, Spark delivery driving can support a vehicle deduction under the IRS rules.
Do you need a mileage log if you already have Spark payout records?
Yes. Payout history can support your timeline, but it does not replace a mileage log that shows the route, date, distance, and business purpose.
Which deduction method is easier for most Spark drivers?
For many drivers, the standard mileage rate is easier because it focuses on business miles instead of requiring every vehicle cost to be allocated and documented.
- Walmart Spark Driver Guide
- Walmart Spark Pay Guide
- Walmart Spark Tax Guide
- Walmart Spark Tax Deductions
- How to Track Mileage for Tax Deductions
- Independent Contractor vs Employee for Gig Workers
