If you want to drive for Walmart Spark, you need to know the driver requirements quickly: who qualifies, which documents matter, and how to avoid approval problems. You should also think about mileage tracking from the start, because clean mileage logs and a mileage tracker app make the first tax deduction file much easier to support.
This article walks through the Spark driver requirements section by section so you can see who qualifies, what documents matter, how vehicle and insurance rules work, what the background check covers, and which onboarding details usually cause delays.
Who qualifies to drive for Walmart Spark
The strongest current source set keeps the eligibility rules fairly direct. To qualify, you generally need to meet these baseline requirements:
- Be at least 18 years old.
- Be eligible to work as a U.S. independent contractor.
- Have a Social Security number.
- Have a valid state-issued driver’s license.
- Have access to an eligible vehicle insured in your name.
- Have a U.S. mobile phone number.
- Use an Android phone or iPhone that supports the Spark Driver app, GPS, and camera features.
- Pass a criminal-history and driving-record background check.
The support material also keeps one practical point visible that new applicants often miss: you may need to lift packages or groceries weighing up to about 60 pounds, so the work is not only about driving.
Which documents you should have ready
Before you upload anything, prepare the core identity and vehicle records the Spark signup flow asks for:
- A valid state-issued driver’s license.
- A real-time selfie or identity-check photo.
- A current auto insurance policy that shows your name, the vehicle details, and the policy expiration date.
Depending on the specific onboarding screen, you may also be asked for your phone number, email address, Social Security details, and payout setup information. Use the same legal name and current address everywhere so the documents line up.
Which vehicles usually qualify
Spark does not use the same kind of make, model, or year list that some rideshare platforms use. The current requirement sources instead focus on the vehicle being reliable, clean, safe, and appropriate for delivery work.
The commonly accepted vehicle types include:
- Cars
- Station Wagons
- SUVs
- Vans
- Trucks
Bikes, motorcycles, and scooters are not treated as standard Spark vehicles in the current source set. If you use a smaller car, you can still qualify, but you may limit which larger-item offers are realistic for you.
What to know if you plan to rent or borrow a vehicle
You can generally use an eligible vehicle that you own, lease, borrow, or rent, as long as it is insured in your name and acceptable for the work. The practical issue is not just the vehicle itself. You also need to confirm the rental company allows business use and that your insurance records can still show the vehicle correctly.
If you use a borrowed or rented vehicle, save the insurance proof and any agreement that explains why you are allowed to use that car for delivery work.
How the insurance requirement works
Spark requires proof of active personal auto insurance during onboarding. The current requirement sources treat your own policy as the core coverage you need to bring to the platform.
That means you should check these points before you apply:
- Your policy is active and not expired.
- Your name appears on the policy.
- The vehicle on the policy matches the one you plan to use.
- Your coverage meets your state’s minimum requirements.
One detail you should not miss: Walmart Spark does not provide supplemental auto insurance coverage. That is why it is worth asking your insurer whether app-based delivery work creates a coverage gap and whether you need a delivery endorsement or stronger policy.
What the Spark background check usually reviews
The background-check step is separate from the document-upload step, even though they happen during the same broader onboarding flow. Spark uses Checkr for the screening flow, and the review usually covers:
- Criminal History
- Driving Record
- Social Security Number Verification
That review commonly uses your Social Security number and driver’s license information. The current timing guidance is usually one to seven days, but county-level records, document mismatches, and waitlists can stretch the timeline.
How the delivery-partner onboarding flow usually works
Spark does not always present the process as one single local hiring office. The current source family describes an onboarding flow that can involve Spark itself plus delivery-partner and platform systems.
During onboarding, expect steps such as:
- Completing the online application
- Uploading license, insurance, and other required documents
- Agreeing to the background check
- Verifying your phone number and email address
- Choosing or confirming your earnings account
- Signing final agreements in the app
Because different markets can route drivers through slightly different screens, save confirmations and status notices instead of assuming you can retrieve them easily later.
What other local or state rules can still matter
The broad Spark qualification list is national, but local rules can still affect what happens next. Depending on where you live, you may run into:
- Local inspection expectations
- State-specific insurance rules
- Delivery-partner process differences
- Waitlist or market-capacity limits
The safest way to read this is simple: meeting the general requirements does not guarantee instant access in every market.
How to make the onboarding process smoother
You can avoid a lot of preventable delay if you do the basics carefully:
- Make sure every uploaded document is current and easy to read.
- Respond quickly if the platform asks for more information.
- Check that your license, insurance, and profile details all match.
- Make sure your vehicle is actually ready for delivery work before approval lands.
- Keep screenshots of application milestones, approval messages, and document uploads.
Those steps are not glamorous, but they are usually what separate a clean onboarding flow from a frustrating one.
Why mileage tracking belongs in the requirement stage
Driving for Spark means working as an independent contractor, so your recordkeeping starts before the first delivery. Vehicle costs, insurance, phone use, parking, tolls, and mileage can all become part of your business records, and those same records support your tax deduction workflow later.
Mileage logs before the first route
One of the easiest ways to protect the tax deduction side of the job is to start mileage logs before the first active route instead of after the first payout.
If you want the deduction side broken out further, use Walmart Spark Tax Deductions. If you want the trip rules in detail, use Walmart Spark Mileage Guide, which also links to Standard Mileage Rate vs Actual Expenses for the method comparison and How to Track Mileage for Tax Deductions for the mileage logs checklist.
Walmart Spark should be treated as a US-first platform in the current source set. The full onboarding and driver workflow is documented most clearly for the United States.
Canada can be mentioned only as a narrower recordkeeping comparison if you are comparing similar delivery work across countries. Europe should stay a short omission note rather than a full Spark workflow because the current official support is too thin there.
Start MyCarTracks automatic mileage tracking before your first Spark workday so your requirement documents, offer history, and mileage logs begin together instead of being rebuilt later. For the broader product overview, use MyCarTracks. For report exports, use MyCarTracks business mileage reports.
Can Walmart Spark reject you even if you have a car and insurance?
Yes. Having a vehicle and insurance is only part of the qualification file. You still need to meet the age, identity, work-authorization, phone, and background-check requirements, and your market can still have capacity limits or waitlists.
Which issues usually block Spark approval?
The most common blockers are document mismatches, expired insurance, unreadable uploads, a suspended license, major recent driving problems, disqualifying criminal history, or market waitlist limits that keep onboarding from finishing quickly.
How long does it usually take to get approved?
If your documents are clean and your market is open, some drivers move through the process in a few days to about a week. If the background check needs extra review or the market is full, it can take longer.
- Walmart Spark Driver Guide
- Walmart Spark Background Check
- Walmart Spark Driver App Setup
- Walmart Spark Pay Guide
- Walmart Spark Mileage Guide
- Walmart Spark Tax Guide
- Walmart Spark Tax Deductions
- Independent Contractor vs Employee for Gig Workers
