A Walmart Spark background check can slow or clear your approval, so you need the answer quickly: what gets screened, what can delay it, and what records to save. You should also set up mileage tracking early, because your first approved trips need mileage logs and tax deduction records from day one, not months later.
This guide focuses only on the background-check side of Spark approval so you can understand the screening flow without mixing it up with document uploads, zone waitlists, or payout setup.
What Spark background screening usually covers
The current source family describes the Spark background check as a review of your criminal history and driving record. The supporting requirement coverage also says the screening runs through Checkr and uses your Social Security number and driver’s license information.
In practice, that means the screening can involve:
- Criminal History Review
- Driving Record Check
- Social Security Number Verification
That review is separate from whether your insurance proof was accepted or whether your market currently has room for new drivers.
Which details you should prepare before the screening starts
Before the background-check flow begins, make sure these details are accurate and available:
- Legal Name
- Current Address
- Recent Address History If Requested
- Driver’s License Information
- Phone Number And Email You Can Access
You should also keep clean copies of the document screens and status notices, because a background-check delay is easier to untangle if you know exactly what was submitted and when.
Which issues can block or delay approval
The current source family points to several issues that can hold up approval or lead to ineligibility:
- Major Driving Violations
- A Suspended License
- Serious Or Disqualifying Criminal History
- Mismatched Identity Details
- Incomplete Application Information
- County-Level Processing Delays
Not every delay means you failed the screening. Spark onboarding can also pause because of insurance review, identity verification, market waitlists, or other account steps.
How long the background check usually takes
The background-check step often takes one to seven days when everything moves normally.
That is a useful expectation, but not a promise. It can take longer if county records are slow, your name or address history needs more review, or your market has a separate onboarding backlog.
What to do if something in the report looks wrong
If the background report or resulting notice looks wrong, do not start changing random details in the application just to force movement. Keep the timeline clear.
Save:
- The Notice Or Report
- The Date You Saw The Problem
- Any Dispute Submission
- Supporting Court Or DMV Records
- Spark Or Screening Messages
That file makes it easier to show whether the problem was the background report itself or some other onboarding issue.
Why background status and onboarding status are not the same thing
One of the easiest mistakes to make is treating every application delay as a background-check failure. The source family does not support that shortcut.
Your account can still be waiting on:
- Insurance Review
- Identity Verification
- Market Availability
- Final Agreement Screens
- Payout Setup
Keep those events separate in your notes so you can tell whether the screening cleared but some other part of enrollment is still open.
What to keep after the check clears
Once the report clears, keep a simple approval file with:
- Consent Or Disclosure Screens
- Status Emails
- Document Approval Notices
- Insurance Proof
- First Active-Account Notice
Those records are useful later if your account is paused, a renewal is rejected, or support asks you to confirm when approval happened.
Why mileage tracking still belongs in your approval file
Background approval is not a tax section, but it is still the right place to prepare the records that start on your first active day. Set up a mileage tracker app before the first delivery so your mileage logs, trip notes, and tax deduction support do not start late.
Mileage logs and tax deduction prep
Once approval clears, your next step should be a mileage tracker app and a simple file for mileage logs, payout notices, and route receipts. That keeps the tax deduction support tied to the first live workday instead of leaving it to memory.
The current Spark screening workflow is documented most clearly for the United States. Canada and Europe should not be treated as if they follow the same official Spark background-check process in the current source set.
Start MyCarTracks automatic mileage tracking once your account is approved so your first Spark trips already have route records attached. For the broader product overview, use MyCarTracks.
What can disqualify you from Spark during the background check?
Recent major driving problems, a suspended license, or serious criminal history can all create disqualification risk. Identity mismatches and incomplete information can also hold up the process even if they do not become permanent disqualifiers.
How long does Spark background screening usually take?
If the screening moves normally, the rough window is often one to seven days. Delays can still happen when records or market processing take longer.
Does a delayed application always mean the background check failed?
No. A delay can also come from insurance review, identity verification, waitlist status, payout setup, or another onboarding step that is still open.
- Walmart Spark Driver Requirements
- Walmart Spark Driver App Setup
- Walmart Spark Driver Guide
- Walmart Spark Pay Guide
- Walmart Spark Mileage Guide
- Independent Contractor vs Employee for Gig Workers
