If you need your Shipt tax forms, start with this: the forms help, but they are not the whole recordkeeping file. You still need your own payout records, mileage tracking file, and expense support so the return reflects the full income and deduction story.
This guide follows the forms workflow step by step: which tax forms you may receive, which thresholds affect form delivery, where to find them, what to do if one is missing, and how those forms fit into the final filing process.
If you want the driving side to reconcile with the same return, MyCarTracks automatic mileage tracking helps save business trips automatically, and Shipt’s tax guidance for shoppers is the official platform source for the broader filing workflow around those forms.
Why mileage tracking still matters in a tax-forms article
Mileage tracking still matters here because the form shows income, not the deduction side. Your mileage logs, receipts, and tax records still need to back up the return even when the 1099 arrives on time.
What tax forms Shipt can send
Depending on how payments were processed and how much you earned, the year-end file can include:
- 1099-K
- 1099-NEC
- Annual Summary
The current public Shipt tax guidance also makes the main tax point clear: taxes are not withheld from shopper pay, so the year-end documents are only part of the self-employed filing process.
Thresholds for receiving tax forms
The form thresholds depend on the type of reporting. IRS 1099-NEC guidance and related IRS FAQ pages explain the reporting rules for nonemployee compensation. If a form does not arrive, that still does not mean the income disappears from your return.
Where to find your Shipt tax documents
Your form search should usually include:
- the Shipt shopper account or tax section
- payout or processor records tied to Stripe Connect
- any email notice tied to year-end document availability
That means your tax file should not depend on one inbox search alone.
What to do if you did not get a 1099
If you expected a form and it did not appear:
- check the account tax section
- check related payout or processor records
- review your total earnings for the year
- contact support if the account should already show the document
Even without the form, taxable self-employed income still needs to be reported.
How to use the 1099 when you file
The totals from your forms or annual summaries should line up with the rest of your filing records. For most US shoppers, the form totals eventually feed into the same self-employed filing path that includes:
- Form 1040
- Schedule C
- Schedule SE
If you want the broader filing workflow, use Shipt Tax Guide.
What records to keep with your forms
Do not treat the form as a complete filing file by itself. Keep it with:
- payout history
- bank deposits
- annual summaries
- mileage logs
- receipts
- parking and toll records
- app notices tied to adjustments or corrections
That combined file makes it easier to explain why your gross income, deductions, and deposits line up the way they do.
Why your own records still matter more than the form
The form is not a replacement for:
- payout history
- bank deposits
- mileage logs
- receipts
- app notices and adjustments
That is why mileage tracking still belongs in a tax-forms article. A 1099 can show income, but it cannot rebuild the deduction side for you later.
If you want the trip rule behind the same filing file, use Shipt Mileage Guide.
What to do if the numbers do not match
Sometimes the amount on a form, the amount in your annual summary, and the amount you expected from memory do not feel the same. Start with the records you can verify:
- compare the form with your payout history
- compare the payout history with your deposits
- check whether tips, bonuses, or processor timing changed the total you expected
- save any support messages tied to a correction request
That review is usually easier when your mileage tracking, payout records, and expense file are already organized instead of scattered across apps and inboxes.
Canada and Europe note
This article is US-first because the practical Shipt forms workflow is documented most clearly in the US source set. For Canada and Europe, keep platform statements, payout records, business-registration or VAT records, and local tax documents based on the country where you file.
Use MyCarTracks business mileage reports alongside your Shipt tax forms so the deduction side and the income side stay together in one filing file. For the broader product overview, use MyCarTracks.
Will Shipt send you a W-2?
No. Shipt work is generally handled as independent-contractor income rather than employee wages.
Do you still owe taxes if no Shipt 1099 shows up?
Yes. A missing 1099 does not remove your duty to report taxable income.
Why does mileage tracking matter in a tax-forms guide?
Because the form shows income, but your mileage logs and receipts support the deductions that usually matter when you file.
- Shipt Tax Guide
- Shipt Tax Deductions
- Shipt Mileage Guide
- Shipt Pay Guide
- How to Track Mileage for Tax Deductions
- Instacart Tax Forms
- Walmart Spark Tax Forms
