Instacart Tax Forms
If you worked with Instacart last year, the tax forms are only one part of the file you need. You still need mileage tracking, income records, expense records, and deposit history so you can report the work accurately instead of relying on a single year-end document.
For many full-service shoppers, the key job is not only downloading a 1099. It is understanding which form belongs to which payment stream, spotting when a form is missing, and using the tax documents together with your deductions and statements so the return reflects what you actually earned.
If you want a mileage tracker app running before next year gets messy, MyCarTracks mileage tracking helps you keep Instacart trips, other apps, and personal driving separate while the details are still fresh.
Why these tax forms show up
If you shop and deliver orders yourself for Instacart, the tax workflow is usually closer to self-employment than payroll. That means you may be responsible for tracking income and expenses yourself instead of relying on paycheck withholding to do the recordkeeping for you.
The form path can still change with your shopper role and payment setup. Full-service shoppers usually watch for contractor-style tax documents, while employee-style shopper arrangements can follow wage paperwork instead. Either way, the form is only the summary. Your own records still do the heavy lifting.
Which Instacart tax documents and 1099s you may receive
Instacart shoppers can see more than one year-end document. The exact mix depends on the type of income, how payments were processed, and the reporting rules that applied during that tax year.
Form 1099-NEC
Form 1099-NEC is the IRS form used to report at least $600 of nonemployee compensation. For Instacart shoppers handling this work as self-employment income, this is one of the first forms to watch for when contractor-style payments are reportable.
Form 1099-K
Form 1099-K covers certain payment-card and third-party network transactions. The federal threshold can change over time, and some states can require a form at lower amounts. For 2025 federal reporting, the threshold reverted to more than $20,000 and more than 200 transactions for third-party settlement organizations, but you can still receive a 1099-K in situations where a lower state threshold or another reporting rule applies.
If you work across several apps, the broader Gig Worker 1099 Forms guide helps you compare how 1099-K, 1099-NEC, platform statements, and no-form income fit together.
Instacart annual summary or earnings summary
Even when a 1099 does not show the whole picture, an annual or earnings summary can still help you reconcile the year. Use that summary to review gross earnings, fees, incentives, and any mileage estimate or payout detail the platform displayed, but do not treat it as a substitute for your own records.
You still report income even when no 1099 arrives
A missing form does not erase taxable income. Your filing obligation follows what you earned, not only which documents were issued.
If no 1099 arrived
Common reasons include:
  • You were below the reporting threshold for that form.
  • The payment path did not trigger that specific form.
  • Your taxpayer or payout information needs review.
If no form shows up, rebuild the income from your Instacart earnings history, annual summary, bank deposits, and correction messages anyway. This is the same reason the broader Instacart Tax Guide keeps gross income separate from the form itself.
Where to pull your Instacart tax documents
US information returns are generally furnished by January 31, so start checking in late January rather than waiting until filing week.
Use this download routine:
  • Sign in to the Shopper app or the web account tied to your shopper profile.
  • Check the earnings or tax-documents area first, then the email tied to your payout setup.
  • If a payment processor handled part of the form delivery, follow the portal instructions from that processor and download the PDF early.
  • Save the original form, any corrected form, and the annual summary in the same folder.
If something is missing or the identity details are wrong, start fixing it early. Tax-document corrections, portal-access problems, and mailing-detail issues are much easier to sort out before the filing deadline.
How these forms fit into the return
For many US full-service shoppers, the forms fit into a larger filing path rather than acting as the whole return by themselves.
The usual document flow looks like this:
  • 1099-NEC, 1099-K, and annual summaries help you reconstruct gross income.
  • Schedule C (Form 1040) is where business income and expenses are commonly reported.
  • Schedule SE (Form 1040) is where self-employment tax is calculated when it applies.
  • Form 1040 is the main individual return.
  • Form 1040-ES is the estimated-tax package that can matter during the year when you expect to owe enough tax.
The form total is usually gross income before your deductions. That is why this article should sit beside Instacart Tax Deductions, Instacart Mileage Guide, and the broader How to Claim Self-Employed Taxes workflow instead of replacing them.
Keep mileage tracking and the records behind each form
For each tax document you download, keep the support behind it:
  • The annual or monthly earnings statements.
  • Bank deposits and payout history.
  • Mileage logs or exports, especially if vehicle costs are one of your biggest deductions.
  • Receipts for phone costs, supplies, tolls, parking, and other business expenses.
  • Support messages about corrections, refunds, or payment adjustments.
If you need the mileage side cleaned up before filing, How to Track Mileage for Tax Deductions is the companion workflow.
Cross-market notes
This is the main market where 1099-NEC, 1099-K, Schedule C, Schedule SE, Form 1040, and Form 1040-ES are the right documents to keep together. The current IRS pages for each form belong in the same file as your Instacart summaries, deposits, and deductions.
Instacart also operates in Canada, but the US 1099 naming pattern is not the main record model there. Canadian shoppers should keep platform statements, deposits, kilometres, and business-income records organized around their local filing workflow, including Form T2125 for business or professional activities when it applies.
Instacart is not broadly the platform to plan around in Europe. If you are comparing similar grocery-delivery work there, keep the local platform statements, invoices, VAT records, and country-specific reporting documents together instead of assuming the North American 1099 workflow applies; the European Commission VAT for businesses page is only the starting point.
Use MyCarTracks to keep the mileage side of the tax file lined up with your Instacart forms and annual summaries. When you need the export that matches the return, the business mileage reports workflow gives you a cleaner record than rebuilding the year from memory.
