If you are applying to shop with Instacart, the background check is one of the first real approval gates, and mileage tracking only matters after you clear it. You need to know what Instacart checks, what can delay the result, and which records you should save before the application turns into support back-and-forth.
This guide walks you through the same screening questions most shoppers hit early: what Instacart reviews, what to prepare before you consent, how long the check can take, what can slow it down, and what to do if the report or account status looks wrong.
If you want your onboarding trips organized once approval starts moving, MyCarTracks mileage tracking can separate document errands, inspection drives, and your first approved batch miles from the start.
What Instacart checks before approval
Instacart’s onboarding now relies on third-party screening, including Checkr, for initial criminal and motor vehicle record checks on shopper applicants, alongside age, identity, and driver-license verification where the role involves delivery (platform integrity overview).
The closest shopper-requirements sources keep this baseline simple:
- You Must Be At Least 18.
- You Must Be Eligible To Work In The Market.
- You Must Provide The Identity And Tax Details The Application Requires.
- You Must Pass The Background Check.
For delivery-based shopper roles, the screening file usually sits next to the rest of the approval file, not apart from it. That means your license, insurance, phone access, and payout setup can all affect how smoothly the account moves toward approval.
What to prepare before you consent to the check
Before you start the application, gather the same basics the requirement guides expect shoppers to have ready:
- Your Legal Name Exactly As It Appears On Your Documents.
- Your Current And Recent Addresses.
- Your Date Of Birth.
- Your Social Security Number Or Taxpayer Information Where Required.
- Your Driver’s License Or Other Required Government ID.
- Your Bank Account Information For Direct Deposit.
- Clear Photos Of Your License And Insurance If Delivery Work Is Involved.
- A Smartphone With A Data Plan That Can Run The Shopper App Reliably.
This is also the stage where duplicate-account or mismatched-document problems start. The Shopper Application Terms require the information you submit through the Shopper App to stay true, accurate, and complete, and they make clear that you may not sign up more than once or impersonate another person (Shopper Application Terms).
How the application and check usually move
The requirement sources describe a short signup flow, even though the result can still take longer:
- Start the Instacart shopper signup flow or open the Shopper app.
- Create the account and enter your personal details.
- Submit the documents and consent to the background check.
- Wait for the review and account decision.
- Go online only after the account is fully cleared.
If your documents are ready, the application itself can be quick. The stronger competitor source says the basic application can be finished in about 15 minutes, while approval may take one to four days. The supporting requirement source is looser and says a few days is common, but some regions take longer.
What can slow the result down
The biggest delays usually come from small file problems, not dramatic failures.
Common delay triggers include:
- A Name Or Address That Does Not Match Across Documents.
- Blurry Or Incomplete Uploads.
- Expired Insurance Or License Records.
- Missing Vehicle Information For Delivery Roles.
- Court Or Motor-Vehicle Record Processing Delays.
- A Waitlist Or Market-Capacity Limit That Looks Like Screening Delay In The App.
- Duplicate-Account Or Account-Security Flags.
The closest competitor FAQ also warns that some shoppers wait much longer when a market has a waitlist. That matters because “not active yet” does not always mean “failed background check.”
What can block or complicate approval
The public Instacart source set is not as detailed as some rideshare screening guides about exact disqualifier lists, so you should avoid guessing at a master blacklist. What the sources do support is this:
- Criminal-History Review Is Part Of The Check.
- Motor-Vehicle Record Review Is Part Of The Check For Delivery-Based Roles.
- Identity Verification Is Part Of The Review.
- The Account Can Be Denied, Paused, Or Rechecked If Instacart Cannot Verify That The Right Shopper Is Using The Account.
The 2025 platform-integrity update adds other controls that can affect access after signup, including biometric profile-photo review, duplicate-account detection, secure logins, real-time identity verification, and ongoing background-check refreshes (platform integrity overview).
What to do if the report or account status looks wrong
Do not start by resubmitting random versions of the same documents. Start by pinning down what failed.
Keep this dispute file together:
- The Report Or Notice You Received.
- The Date You Submitted The Dispute Or Appeal.
- Supporting DMV, Court, Or Identity Documents.
- Platform Support Messages.
- Any Final Decision Notice.
Instacart’s current security workflow also says a shopper whose account was suspended or deactivated may submit an appeal directly to the Trust & Safety team, which reviews the evidence provided (platform integrity overview).
Why the shopper role still changes the screening file
The closest shopper-requirements source separates full-service shoppers from in-store shoppers, and that distinction still matters here.
Full-service shopper screening context
For a full-service shopper, the background file sits next to:
- Your Driver’s License.
- Your Auto Insurance.
- Your Delivery Eligibility.
- Your Payout Setup.
- The Miles You Will Later Need For Tax Records.
In-store shopper screening context
For in-store work where it exists, the job can be structured differently:
- A Car Is Not Required.
- Delivery Miles Are Not The Core Record.
- Wage And Schedule Records Matter More Than Vehicle Files.
That is why you should not assume every Instacart screening outcome leads to the same post-approval workflow.
How mileage tracking and tax records start after approval
Once the account clears, mileage tracking starts becoming useful immediately because the first approved work often includes document errands, store approach miles, and early delivery routes that are easy to lose.
Keep these records together from the first week:
- Your Approval Email Or App Notice.
- The Date You First Went Online.
- Your First Batch Summary.
- Mileage Logs For The First Approved Workdays.
- Insurance And License Renewal Dates.
- Support Messages About Any Account Review.
If you want the trip rules after approval, use Instacart Mileage Guide. If you want the broader signup file around roles, equipment, and transport, use Instacart Shopper Requirements. If you want the tax side behind those same records, use Instacart Tax Guide and Instacart Tax Forms.
This is the strongest market for the full screening explanation. It is where the public Instacart shopper sources give the clearest age, role, background-check, and signup workflow details.
Instacart also operates in Canada, but the current shopper source set is thinner there. Keep the same identity and records discipline, but do not assume the US approval wording is the full Canadian rule set.
Instacart is not broadly the platform to plan around in Europe. If you are comparing similar grocery-delivery work there, use local platform screening, worker-status, and tax rules instead of assuming the North American Instacart approval flow applies.
Frequently asked questions
How long can the Instacart background check take?
If your documents are ready, the application itself can be quick, but approval may still take one to four days or longer. Waitlists, record processing, and document mismatches can stretch that timeline.
Does a failed or delayed account always mean the background check failed?
No. A queue, a document mismatch, a duplicate-account flag, or market availability can all slow activation without meaning the criminal or motor-vehicle review itself failed.
What should you save in case the account is paused later?
Save the consent record, approval emails, document uploads, support messages, renewal dates, and any dispute or appeal timeline. Those records are usually more useful than trying to reconstruct events later.
Use MyCarTracks as a mileage tracker app to tag onboarding trips, store approaches, and your first approved Instacart miles without mixing them with personal driving.
If you want the broader product overview after setup, use MyCarTracks. If you want the role-level guide next, use Instacart Shopper Guide.
- Instacart Shopper Guide
- Instacart Shopper Requirements
- Instacart Pay Guide
- Instacart Mileage Guide
- Instacart Tax Guide
- Instacart Tax Forms
- How to Track Mileage for Tax Deductions
