Instacart Mileage Guide
If you shop and deliver for Instacart, mileage tracking is one of the most valuable records you can keep. Every qualifying business mile can lower taxable income, but only if your log is detailed enough to show what the trip was for, where it started, where it ended, and why it belonged to the work.
The hard part is not only counting miles. It is separating deductible driving from personal errands, understanding which deduction method fits your situation, and keeping the log close enough to real time that it still holds up months later.
If you want a mileage tracker app running before the week gets messy, MyCarTracks mileage tracking helps you keep Instacart miles, other apps, and personal driving separate while the details are still fresh.
Why mileage tracking matters for Instacart shoppers
If you handle Instacart orders yourself, the driving cost is usually your responsibility rather than something an employer absorbs for you. That is why mileage tracking matters so much: it is often one of the biggest recurring deductions in the whole file, and it also helps you see whether a batch was actually worth taking after time, distance, tolls, parking, and vehicle wear are counted.
For many shoppers, the main choice comes down to two deduction methods:
  • The standard mileage method.
  • The actual expense method.
Either way, the log is still the foundation. A weak or reconstructed mileage record can cost you the deduction even if the driving really happened.
Which Instacart miles usually count
Not every drive belongs in the business total. The cleaner approach is to keep only the miles that were ordinary and necessary for the shopper work and to split out any personal miles the moment the trip changed purpose.
Miles that usually belong in the mileage log
These are the kinds of Instacart trips shoppers commonly track:
  • Driving to the store for an accepted batch.
  • Driving from one store to another during the work.
  • Driving to the customer’s address for the dropoff.
  • Driving between delivery stops in a multi-order route.
  • Driving to buy required or clearly work-related supplies, such as insulated bags.
Miles that usually do not belong
These miles usually need to stay out of the deduction total:
  • The ordinary drive from home before the work qualifies as business driving.
  • The drive home after you log out for the day.
  • Personal grocery runs in the middle of a shift.
  • Any other personal errand that is not part of the Instacart work.
Mixing business and personal miles is one of the easiest ways to weaken the file, so split the trip at the point where the purpose changed instead of guessing later.
Standard mileage method
This is the simpler method for many Instacart shoppers. You track all qualifying business miles for the year, then multiply them by the IRS business rate for that tax year.
For 2026 in the United States, the business standard mileage rate is 72.5 cents per mile. That single rate is designed to cover common car costs such as gas, maintenance, insurance, and depreciation.
This method is more detailed, but it can be stronger when vehicle costs run high. Instead of multiplying miles by a standard rate, you total your real vehicle costs for the year and apply the business-use percentage to those costs.
The car-expense rules in Publication 463 cover costs such as:
  • Gas and oil.
  • Repairs and maintenance.
  • Insurance premiums.
  • Registration fees.
  • Lease payments or depreciation.
If you drove 18,000 total miles during the year and 14,000 of them were for Instacart, the business-use share would be about 78%. That percentage is what connects the vehicle costs to the shopper work.
Costs you can usually deduct with either method
Some route costs still matter even if you use the standard mileage method. Business parking fees and tolls can still be deducted separately under Publication 463, so save those records with the trip file.
Parking tickets and fines are a different category. They do not become deductible just because they happened during a workday.
What your mileage log should include
A clear, accurate mileage log matters more than a rough estimate. A useful Instacart log should include:
  • Date of the trip.
  • Starting location and destination.
  • Business purpose.
  • Total miles driven.
  • Vehicle used.
An end-of-year estimate or a payout summary can help you cross-check the file, but it is not the same as a real mileage log. The stronger record is the one built as the trips happen.
If you want the field-by-field checklist in a broader format, use IRS Mileage Log Requirements and How to Track Mileage for Tax Deductions.
How the mileage deduction fits into the return
For many US full-service shoppers, vehicle costs are usually handled through Schedule C (Form 1040). That is where business income and expenses are commonly reported.
The basic flow is:
  • Choose the standard mileage method or the actual expense method for that vehicle.
  • Keep the mileage log and any supporting receipts.
  • Use the vehicle records alongside the rest of your income and expense file when you prepare the return.
If you want the broader filing workflow around the mileage record, use Instacart Tax Guide. If you want the full write-off list beyond driving, use Instacart Tax Deductions.
Common Instacart mileage mistakes
  • Not tracking miles consistently.
  • Including personal trips as business mileage.
  • Forgetting to save receipts for actual expenses.
  • Estimating miles instead of logging them as you go.
  • Choosing a method without checking which one actually fits the vehicle costs.
These mistakes usually cost money in one of two ways: either the deduction ends up smaller than it should be, or the record is too weak to defend later.
Cross-market notes
This is the strongest market for the full mileage-deduction workflow. The 2026 mileage-rate announcement, Publication 463, and Schedule C page are the core references to keep with the mileage file.
Instacart also operates in Canada, but the record focus shifts to kilometres and business-use percentages. Your log should capture the date, destination, purpose, and kilometres driven, along with total and business kilometres for the vehicle, following CRA motor vehicle records guidance.
Instacart is not broadly the platform to plan around in Europe. If you are comparing similar grocery-delivery work there, use the local vehicle-expense, invoice, VAT, and worker-status rules instead of reusing the North American Instacart mileage workflow; the European Commission VAT for businesses page is only a starting point.
Use MyCarTracks to record Instacart trips automatically, tag business and personal driving separately, and keep the route history attached to the mileage file while the week is still easy to explain. When you need the export for tax time, the business mileage reports workflow gives you a cleaner report than rebuilding the year from memory.
