IRS Mileage Log Requirements
IRS mileage log requirements are really mileage tracking rules: keep a timely record that shows the date, destination, business purpose, and miles for each business drive. Publication 463 sets the recordkeeping baseline, and it focuses on adequate, timely records rather than one required template.
Keep mileage records at or near the time of the trip. Record the date, destination, business purpose, and miles for each business drive, then keep the file organized enough to show annual vehicle use when that matters. If you want a cleaner weekly record before tax season arrives, MyCarTracks automatic mileage tracking can capture the trip data automatically and leave you with review instead of reconstruction.
Mileage tracking fields the IRS considers adequate records
Publication 463 does not force you into one mileage-log format, but it does expect specific elements to be recorded. A solid business mileage file should cover:
Required element What to record
Miles driven The business miles for each trip
Date The date of each trip, not only a monthly total
Destination The place you traveled to or the route context
Business purpose Why the trip was work-related
For mixed-use vehicles, keep annual odometer context as well. That helps show total vehicle use when the business percentage matters.
What timely records mean
Publication 463 gives more weight to records kept at or near the time of the trip than to a statement built later from memory. It also says a weekly log can count as timely if it accounts for the vehicle use during that week.
That is the practical standard most people should work backward from. If the log is only being recreated at tax time, the route, purpose, and personal stops are much more likely to be wrong.
Accepted mileage log formats
The IRS cares more about the information than the container. A paper logbook, spreadsheet, exported CSV or PDF, or digital mileage app can all work if the required details are there and the record can be produced later.
The format your employer wants may be narrower than the IRS baseline, which is why an employee should usually keep a personal copy even when a company expense system also stores the claim.
Does the IRS require odometer readings
Per-trip odometer readings are not the only way to keep a valid log, but annual odometer readings still matter when you need to show total vehicle use or support the business-use percentage. Publication 463 expects enough detail to prove the business portion of a mixed-use vehicle, and start-of-year and end-of-year readings make that easier.
That is also why What Is a Mileage Log? and How to Track Mileage for Tax Deductions should be read together with this page when the trip volume is high.
How to separate business and personal driving
If one vehicle handles both work and personal use, the file needs to show the business portion clearly enough to survive review. That means keeping personal and commuting trips out of the business total instead of assuming every drive on a workday qualifies.
The fastest way to weaken a mileage file is to submit one big monthly number without showing which trips were business, which were commuting, and which were personal.
Mileage log requirements for employees
The core fields are the same for employees: date, destination, miles, and business purpose. The difference is that the employer can add its own process requirements, such as a specific form, deadline, manager approval step, or proof for parking and tolls.
Keep your own copy even if the company stores the claim. That protects you if a reimbursement question comes up later and also makes it easier to compare the claim with the employer policy.
What to do if your log is reviewed later
If the IRS, your accountant, or an employer reviewer asks for support, the file should be easy to follow by year and by vehicle. Keep the mileage log with related receipts, approvals, and any notes that explain unusual routes or corrections.
For a broader look at the product workflow behind automatic capture, team reporting, and exports, see MyCarTracks. Parking and tolls should stay separate from the mileage line, especially when the standard mileage rate versus actual expenses question is still open.
  1. Identify the person or entity using the record: employee, employer, self-employed worker, volunteer, contractor, owner, or fleet manager.
  2. Identify the purpose: reimbursement, deduction, payroll support, job costing, customer billing, vehicle program review, or fleet reporting.
  3. Identify the tax year and the US rule set that applies. Do not mix business, medical, moving, charitable, reimbursement, and state-law rules in one calculation.
  4. Confirm whether the trip qualifies under the relevant source. A route can be real and still be personal, commuting, or outside the policy.
  5. Apply the rate, method, or program only after the trip record is complete.
  6. Save the source, report, approval, and payment record together.
Mileage log workflow
A mileage log should be maintained as work happens, not reconstructed from memory. The weekly workflow is simple: review new trips, classify each one, split personal stops, add business purpose notes, attach route costs, and export exceptions for correction.
For teams, the log should also show driver, vehicle, approval status, and project or client tag. For self-employed workers, it should preserve total vehicle use where required. For employees, it should match the reimbursement policy fields.
Suppose a self-employed repair technician visits three customer sites, stops for parts, and then drives home. A useful log does not only say “work miles.” It names the customer or job ticket, records the route or destination, captures the distance, marks the parts stop as business-related, and separates the regular commute or personal stop if one happened.
That same day can also support an employer reimbursement review if the technician is an employee. The fields are similar, but the output is different: the manager needs a policy-compliant claim, payroll needs the approved amount, and the employee needs a record that explains the trip without relying on memory.
Save the official source used for each rate, rule, or policy decision. For public articles, that means linking to the IRS or the relevant state source rather than repeating unsupported third-party claims. For internal company use, it means saving the policy version and source rate that were active when the trip was paid. This matters when a reader later asks why a 2026 trip was calculated differently from a 2025 trip, or why one state required a different reimbursement workflow from another state.
  • Is the trip business, commuting, personal, medical, charitable, or another category?
  • Is the rate from the correct tax year and rule set?
  • Are different trip categories kept separate?
  • Does the record name the vehicle and driver?
  • Does the business purpose make sense without extra memory?
  • Are parking, tolls, and other route costs handled separately?
  • Are total annual vehicle miles needed?
  • Is the reimbursement policy saved with the report?
  • Are state-specific rules relevant?
  • Is a professional review needed before filing, payroll, or policy decisions?
Get tax, payroll, legal, or accounting review when the answer affects a filed return, employee wages, worker classification, taxable benefits, multi-state reimbursement, FAVR design, or a dispute over unpaid expenses. A mileage app can make the record cleaner, but it cannot decide the legal or tax treatment by itself.
  • date of each trip
  • start and end location, destination, route, or client/job context
  • distance driven
  • driver or employee name when a team is involved
  • total odometer readings where required
  • receipts for fuel, charging, repairs, parking, tolls, insurance, registration, and other vehicle costs
  • reimbursement requests, approvals, denials, and employer policy documents
  • tax-year rate source used for each calculation
  • using the current rate for an older tax year
  • mixing commuting, personal errands, and business miles
  • saving only payout, calendar, or bank records without a mileage log
  • forgetting total annual miles when actual expenses or business-use percentages matter
  • treating an employer reimbursement policy as if it were a tax rule
  • treating a tax rule as if it were an employer reimbursement promise
  • missing parking, tolls, support trips, return trips, and supply runs
  • waiting until tax season to explain routes from memory
What does the IRS want in a mileage log?
A practical IRS mileage log should show the date, destination or route, business purpose, miles driven, vehicle used, and supporting notes. Mixed-use vehicles also need enough records to separate business and personal use.
Is a calendar enough for mileage records?
A calendar can support a trip, but it usually does not replace a mileage log. The log still needs distance, purpose, vehicle, and trip details.
Can I rebuild a mileage log at tax time?
Records kept close to the trip are stronger. A later reconstruction is weaker because routes, purposes, and personal stops are easier to miss.
Should I track odometer readings?
Odometer readings help support total annual vehicle use, especially when the vehicle is used for both business and personal driving or when actual expenses are compared.
  1. Record trips automatically.
  2. Classify business and personal driving while the trip is still fresh.
  3. Add tags for employee, vehicle, client, project, platform, or state.
  4. Review mileage weekly so personal stops and unclear routes are fixed early.
  5. Export reports by tax year, pay period, vehicle, driver, or reimbursement cycle.
Medical and Charitable Mileage Rates
Business Travel Tax Deduction
Moving Expense Mileage Deduction: Who Can Still Claim It?
Expense Reimbursements for Small Businesses
Historical IRS Mileage Rates by Year
Mileage Logbook Template and Examples
Mileage Reimbursement Rules for Employees
What Is Mileage Reimbursement?
How to Calculate Mileage Reimbursement
Is Mileage Reimbursement Taxable Income?
Mileage Reimbursement Rules for Employers
How to Reimburse Mileage for Remote Workers
How to Create a Mileage Reimbursement Policy
FAVR Reimbursement Plans Explained
What Is a Fleet Vehicle?
Instacart Mileage Guide
California Mileage Reimbursement Rules
Illinois Mileage Reimbursement Rules
Massachusetts Mileage Reimbursement Rules
Which States Require Mileage Reimbursement?
How to Claim Self-Employed Taxes (US)
Business Miles vs Commuting Miles
How to Claim Mileage on Taxes
Self-Employed Mileage Deduction Rules
Small Business Guides (US): Taxes, Expenses, and Vehicle Records
Small Business Tax Guide for 2026 (US)
Amazon Flex Mileage Guide
Amazon Flex Tax Guide
Amazon Flex Tax Deductions
Amazon Flex Tax Forms
Amazon Flex Insurance and Vehicle Rules
Amazon Flex Delivery Blocks and Expenses
Deductions You Can Claim Without Receipts (US)
Itemized vs Standard Deduction for Self-Employed People (US)
How to Keep Track of Business Expenses (US)
IRS Receipt Requirements for Self-Employed People (US)
Mileage Guides: IRS Rates, Reimbursement, Logs, and Deductions
Quarterly Tax Payments: Dates and How to Pay (US)
IRS Mileage Guide: Rates, Rules, and Reimbursements
Current IRS Mileage Rates for 2026
Car Allowance vs Mileage Reimbursement
Car Allowance vs Company Car
Small Business Tax Rates: Federal, State, Sales, and Payroll Taxes (US)
Amazon Flex Driver Requirements
Self-Employed Tax Deductions (US)
