Shipt Mileage Guide
If you drive for Shipt, mileage tracking is one of the records most likely to change your tax bill. It is also one of the records most people try to rebuild too late. The trips to stores, customer addresses, and route stops add up quickly, and without a clean log you can lose one of the largest deductions tied to the work.
This guide answers the main mileage question quickly and gives you the practical value behind it: which write-off methods exist, what the IRS expects, and which trips usually count.
If you want to capture those trips while they are still easy to explain, MyCarTracks automatic mileage tracking helps save business driving automatically, and Shipt’s official tax guidance for shoppers is the platform source that connects those miles to filing.
Why mileage tracking matters
As an independent contractor, you can deduct qualifying business mileage tied to your Shipt work. For many shoppers, that becomes one of the biggest write-offs on the return because the platform depends on your vehicle for store trips, deliveries, and related work travel.
Mileage also matters outside tax season. A route that looks useful in the app can look much weaker once you add distance, parking, tolls, and the time needed to finish the stop.
How to write off your Shipt mileage
US filers usually compare two vehicle-deduction methods:
  1. Standard Mileage Rate
  2. Actual Expense Method
You should understand both before locking in a method, because recordkeeping and long-term flexibility are different under each one.
Standard mileage rate method
The IRS standard mileage rate for business use in 2026 is 72.5 cents per mile. Many Shipt shoppers prefer this method because it is simpler: you multiply qualifying business miles by the rate instead of calculating each vehicle cost separately.
That rate is meant to cover common vehicle costs such as:
  • gas
  • maintenance
  • insurance
  • registration
  • depreciation
You still need a real mileage log. The rate is easier than the actual-expense method, but it is not a shortcut around recordkeeping.
The actual-expense method uses the business-use share of your real vehicle costs instead of a cents-per-mile rate. That can include:
  • gas or charging
  • insurance
  • repairs
  • tires
  • registration
  • lease payments
  • depreciation
This method can be stronger if your vehicle costs are unusually high, but it is also more demanding because you need both total vehicle miles and business miles to calculate the business-use percentage correctly.
What the IRS expects
IRS Publication 463 expects mileage records that are timely and specific. A useful Shipt mileage log should show:
  • Date
  • Starting Point
  • Destination
  • Miles Driven
  • Business Purpose
If the log is vague, late, or reconstructed from memory, the deduction is harder to defend.
Which Shipt miles usually count
The trips that commonly belong in a Shipt mileage log include:
  • driving tied to accepted Shipt orders or routes
  • driving from the store or pickup point to the customer
  • miles between customer stops on a route
  • driving to buy delivery supplies used for the work
  • parking and toll costs tied to the business route
Those are the trips most shoppers need to classify correctly first.
Which trips usually do not belong in the deduction total
Not every mile on a Shipt day is automatically deductible. You should separate:
  • personal errands
  • personal grocery shopping
  • miles for another platform unless tagged separately
  • driving with no accepted order or business purpose
Some home-to-first-stop and last-stop-to-home driving also needs careful review because the tax treatment can depend on your facts and filing position. Keep those trips separate in the log instead of blending everything into one total.
Why package-delivery routes need their own review
If you work Shipt package-delivery routes, mileage can look different from a regular shop-and-deliver order. You may be:
  • driving to a designated Target pickup point
  • loading many packages before the route begins
  • completing multiple dropoffs in one run
That makes route tagging even more important. A multi-stop route should not be mixed with personal errands or with another app’s miles in the same entry.
US, Canada, and Europe note
The full deduction workflow in this article is US-first because Shipt’s public onboarding and tax guidance are US-facing. US shoppers should keep mileage logs, payout records, and any parking or toll receipts together so the numbers line up at filing time.
If a Canadian reader is comparing similar delivery work, CRA motor vehicle rules still require a clean split between business and personal use. Keep business kilometres, total kilometres, and vehicle-specific records together.
For Europe, use local country guidance rather than assuming the US Shipt mileage workflow carries over. Worker classification, VAT, invoicing, and vehicle-expense rules can differ significantly by country.
Workday mileage routine
The easiest way to stay accurate is to use the same routine every workday:
  1. Start tracking before the accepted Shipt trip begins.
  2. Tag the trip as Shipt while the route context is still clear.
  3. Separate any personal stop from the work route.
  4. Save parking, toll, and related trip receipts.
  5. Review the week against your payout history.
If you want the deduction categories that sit behind the same log, use Shipt Shopper Expense Checklist. If you want the filing side next, use Shipt Tax Guide.
Common mileage mistakes
The most common problems are:
  • waiting until tax season to estimate miles
  • saving only payout screenshots and not trip logs
  • mixing personal and business driving
  • forgetting supply runs or route-related parking and tolls
  • changing vehicles without tracking annual totals separately
Use MyCarTracks automatic mileage tracking to record Shipt trips as you drive, then export them through MyCarTracks business mileage reports. For the broader product overview, use MyCarTracks.
Can Shipt shoppers deduct mileage instead of actual car costs?
Yes, if the standard mileage method fits your tax situation and you meet the IRS method rules.
Do parking and tolls matter if you use the standard mileage rate?
They can. Publication 463 explains that business-related parking fees and tolls may still be deductible in addition to the standard mileage rate.
Is a payout screenshot enough to prove your Shipt mileage?
No. A payout screenshot can support the work history, but it is not a substitute for a mileage log.
