Shipt Tax Deductions
If you want to keep more of what you earn on Shipt, you need to know which deductions actually belong in the file and which records support them. The biggest mistake is not usually choosing the wrong line on the return. It is failing to keep the receipt, mileage tracking file, or business-use record that proves the deduction later.
This guide walks through the main deduction categories you need before filing: vehicle expenses, phone use, delivery gear, training, insurance, subscriptions, home office, and the records that support the claim.
If you want the trip file to stay ready for those deductions all year, MyCarTracks automatic mileage tracking helps save business driving automatically, and Shipt’s tax guidance for shoppers explains the official self-employed tax context behind the write-offs.
Why mileage tracking matters for deductions
Mileage tracking matters because many shoppers rely on mileage logs to support one of the largest deductions in the file. If the trip record is weak, the deduction support is weaker too.
Vehicle expenses
Your vehicle is usually the most important business tool in the Shipt workflow, so it is also one of the highest-value deduction areas.
IRS mileage rate
Many US shoppers use the IRS standard mileage rate because it turns mileage tracking into a simpler deduction method. Instead of itemizing every fuel and repair bill, you multiply qualifying business miles by the IRS rate.
The actual-expense method works differently. Instead of a per-mile rate, you track the business-use share of:
  • gas or charging
  • maintenance
  • repairs
  • tires
  • insurance
  • registration
  • lease payments or depreciation
Vehicle expenses you may still track either way
Parking and tolls can still matter as separate records connected to the work route, so keep those receipts with the trip file.
Electric vehicle notes
If you use an EV for Shipt, the deduction method still depends on your records and filing position. The lower operating cost does not remove the need to compare the standard mileage and actual-expense methods carefully.
Phone and service plan
Your phone supports the shopper app, navigation, customer communication, and order handling. That means you may need records for:
  • the business-use share of your phone bill
  • chargers
  • mounts
  • battery packs
If the phone is mixed-use, only the business-use share belongs in the deduction file.
Delivery and work gear
Shipt work often requires gear such as:
  • insulated bags
  • reusable totes
  • cooler bags
  • weather gear used for the work
These categories are easier to defend when the receipt and the work use are both obvious.
Platform fees and commissions
Your platform records can also matter when you review adjustments, processor records, or other payout items that affect what you actually received. Keep the platform summary and bank records together so the income file and deduction file do not drift apart.
Work-related training
If you pay for business-related training, tax software, or delivery-work tools, keep the receipts and the business purpose notes together.
Insurance premiums
Depending on your filing situation, health-insurance or other self-employed insurance treatment may matter. This is a category where the record still needs to be saved even if you later confirm the exact filing treatment with a tax professional.
Roadside assistance
If a roadside-assistance plan supports the work vehicle, keep that membership record with the rest of your auto-support file.
Business subscriptions
Business-support subscriptions can include:
  • mileage-tracking tools
  • expense-tracking tools
  • cloud storage used for business files
If you want the trip side protected from day one, MyCarTracks automatic mileage tracking can help build the mileage file while you work.
Home office expenses
If you use a dedicated home space only for managing the business, the records for rent share, utility share, internet share, and workspace size need to be clean before the deduction belongs in the file.
How to track your deductions
The strongest routine is simple:
  1. keep mileage logs current
  2. save receipts by category
  3. reconcile payouts and deposits regularly
  4. keep your tax forms and support records together
If you want the filing path behind the same categories, use Shipt Tax Guide.
How to claim your deductions
US shoppers usually report deductions through Schedule C as part of the self-employed tax return. That means the category list is only useful if the recordkeeping file behind it is strong enough to support the final numbers.
Common deduction mistakes
The most common problems are:
  • forgetting mileage logs
  • mixing personal and business expenses
  • losing receipts
  • using a weak business-use percentage
  • missing smaller recurring deductions that add up
This deduction workflow is US-first because the strongest Shipt source set is built around US shopper operations and US tax treatment. Canada and Europe are better treated as comparison notes around self-employed recordkeeping rather than as full Shipt deduction workflows in the current source set.
Use MyCarTracks business mileage reports to reconcile Shipt trips against receipts and payout records before filing. For the broader product overview, use MyCarTracks.
Is mileage tracking usually the biggest deduction record for Shipt shoppers?
For many shoppers, yes. That is why the mileage file is often the first record worth protecting.
Can you deduct both mileage and every car bill at the same time?
Not in the simple all-at-once way many new shoppers assume. The correct vehicle method depends on IRS rules and the records behind your claim.
Does Shipt cover your gas, data, or delivery-gear costs for you?
No. Those are usually part of your own operating costs, which is why they belong in the deduction review.
