If you drive for Lyft as an independent contractor, mileage tracking is one of the biggest things that can lower your tax bill and improve your weekly profit review. If you want those miles captured automatically instead of rebuilt at tax time, start with MyCarTracks mileage tracking.
Every work mile changes the business result. The hard part is knowing which drives count, how to log them, which deduction method fits you, and how to keep the record strong enough to survive a tax review later.
Why mileage tracking matters for Lyft drivers
Driving for Lyft means you are running your own small business. That means you are responsible for your own vehicle costs, your own tax records, and your own mileage log.
You can usually choose between two vehicle-deduction methods:
- The Standard Mileage Rate
- The Actual Expenses Method
Many drivers use the standard mileage method because it is simpler and often works well for high-mileage driving. But whichever method you choose, your mileage tracking still has to be accurate enough to prove what was business use and what was personal driving.
Which Lyft drives usually count as business mileage
The IRS treats deductible business miles as trips that are ordinary and necessary for the work. For Lyft drivers, that usually means the miles tied directly to running the rideshare business.
Trips that usually belong in your Lyft mileage record include:
- Driving To Pick Up A Passenger
- Taking A Passenger To Their Destination
- Driving While Online And Waiting For Ride Requests
- Driving To A Required Vehicle Inspection
- Supply Runs For Your Rideshare Work, Such As Water, Phone Mounts, Or Cleaning Supplies
- Trips To A Mechanic Or Car Wash When They Are Clearly Tied To The Lyft Vehicle
Which Lyft drives usually do not count
Not every mile belongs in the deduction file.
These trips usually need to stay out of the business total:
- The First Drive Of The Day From Home To Your First Pickup If That Trip Is Treated As Personal Commuting
- The Last Drive Home After You Log Off
- Personal Errands During A Lyft Shift
- Family, School, Food, Or Shopping Trips
- Driving That Has No Real Lyft Business Purpose
If you are unsure, record the trip and classify it carefully later. It is easier to separate a personal trip out than it is to reconstruct a missing work trip from memory.
How the standard mileage method works
This is the method many rideshare drivers use because it is simple.
You keep track of your qualifying business miles for the year and multiply them by the IRS mileage rate. For 2026, the IRS business standard mileage rate is 72.5 cents per mile.
That one rate is designed to cover normal vehicle costs such as:
- Fuel Or Charging
- Insurance
- Maintenance
- Depreciation
- Other Basic Operating Costs
For many high-mileage Lyft drivers, this method is easier to manage because the deduction starts with a strong mileage log instead of a full car-cost spreadsheet.
How the actual-expenses method works
This method can be worth a look if your vehicle costs are unusually high or you keep excellent vehicle records already.
Instead of using one cents-per-mile rate, you add up your actual car costs for the year and then apply the business-use percentage.
That can include:
- Gas And Oil
- Repairs And Maintenance
- Insurance Premiums
- Registration Fees
- Lease Payments Or Depreciation
Example: if you drive 20,000 total miles in a year and 15,000 of them are for Lyft, your vehicle is at 75 percent business use. You would usually apply that percentage to the eligible car costs.
Which vehicle costs you can still deduct separately
Some costs can still matter even if you use the standard mileage method.
The most common separate items are:
- Parking Fees While Driving For Lyft
- Tolls Paid During Lyft Work
Keep those receipts and route notes with the mileage file. Just do not mix them up with tickets or fines, which are not deductible.
How to track your Lyft mileage
Your mileage log needs to be complete enough that you could explain it later without guessing.
Keep these details for each business trip:
- Date
- Starting Point And Destination
- Total Mileage
- Business Purpose
- Location Name Where It Helps, Such As An Airport Or Inspection Site
You can keep that manually, but manual logs are easy to miss on busy days. A dedicated mileage tracker gives you a cleaner record and makes it easier to keep Lyft, Uber, delivery work, and personal driving separate.
How to claim your mileage deduction
When it is time to file in the United States, you generally report your rideshare business income and expenses on Schedule C (Form 1040).
You then use one vehicle-expense method:
- Standard Mileage Rate: Total qualifying business miles multiplied by the IRS rate
- Actual Expenses: Business-use percentage multiplied by the eligible vehicle costs
Do not use both methods on the same vehicle for the same year unless the IRS rules allow a change. Keep the logs and receipts for at least three years in case you need to explain the return later.
If you want the filing side explained step by step, use Lyft Tax Guide. If you want the broader write-off breakdown, use Lyft Tax Deductions.
Which mileage-log habits save the most trouble later
To keep the log strong enough for taxes and for your own weekly review:
- Record Drives As They Happen
- Use One Tracking Method Per Vehicle
- Keep Personal Trips Out Of The Business Total
- Keep Dates, Addresses, And Mileage Consistent
- Save Parking And Toll Records Beside The Mileage File
- Tag Lyft Separately If You Also Drive For Other Apps
Lyft’s own app data can help you review rides, but it should not be your only mileage record. Keep your own record in case you later lose access to app history or need a cleaner export for taxes.
Common mistakes Lyft drivers make
The mistakes that usually cost drivers the most are:
- Not Tracking Miles Consistently
- Mixing Personal Driving Into The Lyft Total
- Forgetting Parking And Toll Records
- Guessing Or Rounding Miles Instead Of Logging Trips
- Waiting Until Tax Season To Rebuild The Year
- Choosing A Method Without Keeping The Records That Method Needs
This is where the standard mileage rate, Schedule C, and IRS log requirements matter most. Keep the US file centered on business miles, total vehicle miles, parking, tolls, and the method you chose.
CRA expects business-trip logs to show the date, destination, purpose, and kilometres driven. Keep total kilometres and business kilometres by vehicle, especially if the same car is used for both Lyft and personal driving.
Lyft is not broadly active across Europe. If you are comparing similar platform work there, use the local country rules for vehicle expenses, VAT, social contributions, and business logs instead of assuming the US rideshare mileage workflow applies.
Use MyCarTracks to track Lyft mileage automatically, review business versus personal drives, and export mileage reports before tax time.
If you want the broader product overview after setup, use MyCarTracks. If you want the full rules for business logs in general, use How to Track Mileage for Tax Deductions.
- Lyft Driver Guide
- Lyft Pay Guide
- Lyft Tax Deductions
- Lyft Tax Forms
- Lyft Tax Guide
