Lyft Background Check
Before you can start driving for Lyft, you need to clear a background check, a driving-record review, and the rest of the onboarding file. If you want your first inspection, DMV, and support trips separated from personal driving, set up MyCarTracks mileage tracking before the approval process starts.
The key is not only passing the check. You also need to know what Lyft reviews, what can slow the process down, what can disqualify you, and what records you should save if something comes back wrong.
What Lyft checks before you can drive
Before the background review even starts, make sure your basic file is complete. Local driver requirements and state and city requirements can add extra items depending on your market.
Your base requirements usually include:
  • A Current And Valid Driver’s License
  • Valid Plates
  • Current Registration
  • An Auto Insurance Policy With Your Name On It
Some cities and states also add local permits, inspections, airport documents, or other eligibility checks.
In addition to those documents, Lyft reviews three core screening areas:
  • National Sex Offender Registry checks
  • Criminal-history checks
  • DMV driving-record checks
Which driving issues can stop approval
Driving-record disqualifiers deserve their own section because they are often the part drivers can verify fastest.
These records commonly block approval:
  • An Invalid License, including suspended, surrendered, or expired status
  • Four Or More Moving Violations Within The Last Three Years, including accidents and running traffic lights
  • One Major Moving Violation Within The Last Three Years, including reckless driving or driving on a suspended license
  • A DUI Or Drug-Related Driving Violation Within The Last Seven Years
  • A Serious Driving-Related Conviction Within The Last Seven Years, including hit and run
If you already know your DMV file has a problem, request the record before you apply instead of waiting for Lyft to reject it.
Which criminal-history issues can stop approval
Criminal-history disqualifiers are reviewed separately from the driving record, so keep that paperwork separate too.
The background review can stop approval if it shows:
  • A Listing On The National Sex Offender Registry
  • A Violent Crime Conviction
  • A Sexual Offense Conviction
  • An Act Of Terror Conviction
  • A Fraud-Related Offense Within Seven Years
  • A Drug-Related Offense Within Seven Years
  • A Theft Or Property-Damage Offense Within Seven Years
Some convictions can still matter even when they are older, so do not assume the issue disappears just because the driving-record lookback is shorter.
How long the background check can take
Some Lyft background checks finish in a few days. Others take several weeks.
The most common reasons for delays are:
  • Lyft Or Checkr Needs More Information From You
  • A Court Has Not Returned Records Yet
  • A Court Backlog Is Slowing Verification
  • Another Agency Or Party Still Needs To Confirm Information
That is why you should keep your application file clean from the start. Small mismatches in your name, address history, or document photos can turn a fast review into a long one.
How to check your Lyft background-check status
Lyft uses two separate vendors in the US flow:
  • Checkr handles the criminal background review
  • Safety Holdings Inc. handles the driving-record review
You can track the criminal-screening side through the Checkr candidate portal. Save the status page, any action items, and the email address tied to the application in the same folder as your Lyft application confirmations.
What to do if Lyft disqualifies you
If the report is wrong, dispute it with the screening vendor first and save the case number.
If the report is accurate but you still want reconsideration, keep any supporting documents together, such as:
  • A Certificate Of Rehabilitation
  • A Certificate Of Relief From Disabilities
  • A Court-Approved Dismissal Or Expungement Document
  • A Recent Name-Change Record
If the problem is on the driving side, go to the DMV, correct the record there, and save the updated motor-vehicle report or any other document that proves the issue was fixed.
What to prepare before you apply
Before you start the Lyft application, gather:
  • Your Legal Name
  • Your Date Of Birth
  • Your Current Contact Details
  • Your Driver’s License
  • Your Address History If Requested
  • Your Social Security Number Where Required
  • Your Insurance Card
  • Your Registration
  • Any Inspection Or Local Documents Your Market Requires
Use the same spelling and the same address format across Lyft, Checkr, your license, your insurance, and your bank details. Small mismatches are one of the easiest ways to slow the review down.
How mileage tracking, mileage logs, and tax records fit the onboarding file
Mileage tracking still matters here because onboarding driving often gets mixed into personal miles and then disappears.
Keep a separate record for:
  • Inspection Trips
  • DMV Visits
  • Support Appointments
  • Document-Errand Driving
  • Your First Approved Lyft Work Trips
Those mileage logs make the startup file easier to classify later when you build your tax records and decide which miles belong in the business file. If you want the broader onboarding checklist around insurance, documents, and account approval, use Lyft Driver Requirements. If you want the insurance side separated from screening, use Lyft Insurance Requirements.
The strongest official Lyft screening support is in the United States. This is where the Checkr, DMV, and ongoing monitoring workflow is clearest, and it is where most of the disqualifier detail lives.
Lyft also operates in selected Canadian markets. Toronto is the strongest current Canada source, and it still uses driver screening and driving-record review as part of approval. Keep the local city page with your own signup file instead of assuming the US process maps over perfectly.
Lyft is not broadly active across Europe. If you are comparing private-hire or rideshare work there, use local platform, licensing, and background-check rules instead of assuming Lyft’s US screening process applies.
Frequently asked questions
What can stop you from passing Lyft’s background check?
Driving problems such as an invalid license, repeated moving violations, or a recent DUI can stop approval. Criminal-history issues such as violent crimes, sexual offenses, registry listings, or certain recent fraud, drug, theft, or property-damage offenses can also block approval.
How long should you expect Lyft’s check to take?
Some checks finish in a few days, but others take weeks when courts, DMV files, address history, or missing documents need extra review.
Can Lyft keep checking your record after approval?
Yes. Ongoing criminal and driving-record monitoring can continue after you are already active, so do not throw away your original approval or dispute paperwork.
Use MyCarTracks as a mileage tracker app to tag onboarding driving separately from paid Lyft work, then keep those records with your approval emails and dispute documents.
If you want the broader product view after setup, use MyCarTracks. If you want the tax-side mileage workflow for active driving, use Lyft Mileage Guide.
