Airbnb Mileage Guide
This Airbnb mileage guide matters because hosting usually creates fewer trips than delivery work, but those trips are easy to forget and they can still change your real profit and your tax file. If you drive for cleaning, inspections, supplies, repairs, permit errands, or guest issues, those miles need their own record.
Airbnb mileage also gets complicated faster than many hosts expect because the same property can have guest use, owner use, maintenance trips, setup runs, and mixed-purpose visits in the same month. The log has to separate those reasons clearly.
If you want to capture those property trips while they are still easy to explain, MyCarTracks automatic mileage tracking helps save them automatically, and Airbnb’s taxes for hosts plus IRS Publication 463 are the key official references behind the deduction side.
Why mileage tracking matters for Airbnb hosts
Mileage tracking matters because the property does not run itself. Hosts drive to check the unit, restock supplies, meet cleaners, handle repairs, respond to lock problems, attend inspections, and deal with city or tax paperwork. If those trips are not captured while they happen, they usually disappear by year-end.
A mileage log also helps outside tax season. It shows which property created the extra supply runs, how much driving one listing really needs, and whether frequent short stays are costing more than the nightly rate suggests.
What counts as business mileage for Airbnb
Business mileage for Airbnb starts with trips that have a clear hosting purpose and are tied to the rental activity rather than personal use of the property.
Deductible Airbnb business miles
Common examples include:
  • pre-arrival inspections
  • cleaning checks and turnover visits
  • supply and amenity runs
  • laundry trips for the listing
  • repair and maintenance visits
  • contractor, cleaner, or manager meetings
  • permit, tax, or inspection errands
  • trips between rental properties
  • urgent guest-support trips
The stronger note is always the one that explains the reason. “Supply run for Oak Street after March 12 checkout” is much more useful than a generic “Airbnb trip.”
Miles you cannot deduct
Not every drive near a rental property belongs in the business log. Personal use is where many hosts weaken their record.
Non-deductible miles
These usually do not belong in the business total:
  • personal vacations or owner stays
  • family errands near the rental
  • shopping that was mostly personal
  • trips where the hosting task was incidental
  • routes estimated after the fact instead of logged while they happened
If a trip mixed rental work with personal time, split it honestly instead of forcing the full route into one category.
The home office exception
Some hosts ask whether driving from home to the rental property counts automatically. It does not. In the United States, that answer can depend on whether your home qualifies as a principal place of business and on the details of the activity. Most hosts should track those trips separately and review them with the rest of the file instead of assuming they always count.
Choosing a mileage deduction method
Hosts who can claim vehicle costs generally compare the standard mileage method with actual vehicle expenses. The better choice depends on your records, business-use percentage, and how the vehicle is used across the year.
The standard mileage rate
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. This method is usually simpler because you multiply qualifying business miles by the yearly rate and keep the underlying log that proves the miles were business-related.
If you want the broader method comparison, use Standard Mileage Rate vs Actual Expenses.
The actual expenses method
The actual-expenses method relies on the real vehicle costs tied to the business-use share of the car. That means keeping records for fuel, insurance, repairs, maintenance, registration, depreciation or lease-related costs, and total annual vehicle miles so the business-use percentage can be supported.
This method usually asks more from the recordkeeping side. If the total-mile and business-mile split is weak, the calculation is weak too.
Expenses you can deduct regardless of method
Some driving-related costs can still matter even when you use the standard mileage rate. Parking and tolls tied to the business route should be saved with the trip record, and supply or repair receipts should stay linked to the drive that created them.
That is why a trip record and a receipt file work best together. The mileage shows where you went and why. The receipt shows what happened there.
How to track mileage as an Airbnb host
A practical Airbnb log should show:
  • date
  • vehicle
  • route or destination
  • miles or kilometres
  • property
  • tolls or parking where relevant
  • personal-use split when the day mixed personal time with hosting
Track the trip while it happens. Waiting until tax season leads to missing restocking runs, missing permit trips, and overconfident route estimates that you cannot explain later.
How to claim your mileage deduction
In the United States, hosts often review mileage as part of the wider rental or small-business file, along with payout records, expenses, and property-use notes. Some hosts end up using Schedule C language, while others review the property under a rental-income framework. The filing path can depend on the services provided, the level of activity, and the rest of the property facts.
The key point for this guide is narrower: the mileage record should be complete even before the final filing classification is chosen. If the log is clean, it is easier to place the deduction correctly later.
For the broader filing side, use:
Common mileage mistakes Airbnb hosts make
The most common mistakes are:
  • skipping setup trips before the first guest
  • counting owner stays as business driving
  • logging supply receipts without logging the trip
  • forgetting parking and tolls
  • using one generic tag for multiple properties
  • rebuilding the mileage log months later
  • failing to track total vehicle miles when using actual expenses
Most of those mistakes come from delay, not from complexity. A short note written the same day is usually enough.
Why mileage deductions still matter for Airbnb hosts
Mileage deductions still matter because property work is rarely visible in the payout screen. A listing can look efficient from the booking side while quietly creating weekly restocking trips, repair calls, permit errands, and cleaner coordination drives.
If you do not measure that driving, you are not measuring the full cost of hosting.
Mileage record differences by market
Airbnb host mileage records should always explain the property, the route, and the business purpose, but the filing context changes by market.
  • United States: keep a clear mile-by-mile log, review whether the standard mileage rate or actual expenses makes more sense, and keep parking and toll records with the trip file.
  • Canada: keep total kilometres, business kilometres, destination, and purpose so the rental-use share of the vehicle can be supported cleanly.
  • Europe: keep the route, purpose, invoices, and personal-use split, then apply the local country treatment for vehicle costs, registration, and VAT where relevant.
Use MyCarTracks to capture host trips automatically and tag them by property. Add short notes for inspection, cleaning, restocking, repair, permit, or guest-support work so the exported log explains more than distance alone.
If you want the full tracking setup, see automatic mileage tracking, Airbnb Host Expense Records, and How to Track Mileage for Tax Deductions.
Quick checklist
  • Tag the correct property.
  • Add the business purpose.
  • Split personal stops.
  • Save tolls, parking, and related receipts.
  • Match repairs and supply runs to the property file.
  • Export monthly instead of waiting for year-end.
