If you need the 2026 IRS mileage rate, the short answer is 72.5 cents per mile for qualifying business driving. The official figures for business, medical, moving, and charitable mileage are in the IRS 2026 mileage rate announcement, and the supporting vehicle-expense rules are in Publication 463.
The rate is only the calculation step. You still have to match the trip to the right category and keep a mileage record that can survive reimbursement, payroll, or tax review. If you want the logging side handled automatically, MyCarTracks automatic mileage tracking can capture the trip before you export the report.
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. Medical and eligible moving mileage are 20.5 cents per mile. Charitable mileage is 14 cents per mile.
2026 IRS mileage rates
| Use | 2026 rate |
| Business | 72.5 cents per mile |
| Medical | 20.5 cents per mile |
| Moving for eligible Armed Forces members and certain intelligence community members | 20.5 cents per mile |
| Charitable service | 14 cents per mile |
These rates apply to miles driven on or after January 1, 2026. If you need to compare the current year with prior years before pricing a reimbursement or deduction, use Historical IRS Mileage Rates by Year.
How 2026 compares with 2025
The business rate increased by 2.5 cents, from 70 cents per mile in 2025 to 72.5 cents in 2026. The medical and eligible moving rate dropped by half a cent, from 21 cents to 20.5 cents. The charitable rate stayed at 14 cents.
| Use | 2026 | 2025 |
| Business | 72.5 cents | 70 cents |
| Medical | 20.5 cents | 21 cents |
| Eligible moving | 20.5 cents | 21 cents |
| Charitable service | 14 cents | 14 cents |
What the standard mileage rate is meant to do
The standard mileage rate is a pricing method for qualifying miles. It gives you a federal cents-per-mile figure you can use for business deductions, substantiated employee reimbursements, and certain nonbusiness mileage categories. It does not turn a personal or commuting trip into a business trip, and it does not replace the trip log that proves what happened.
When self-employed readers use the business rate
Self-employed taxpayers usually use the business rate to price qualifying business miles for the tax year in which those miles were driven. That works best when the mileage log is current and the business-use story is easy to follow. If your vehicle has unusually high costs or you are comparing methods, Standard Mileage Rate vs Actual Expenses and Self-Employed Mileage Deduction Rules are the deeper reads.
When employees and employers use the business rate
Employees often see the 2026 business rate inside a company reimbursement policy. Employers often use it because it is familiar and it fits substantiated mileage allowances cleanly under the federal framework described in Publication 15. A company can choose a different rate or another vehicle program, but the trip still needs a business purpose, a mileage record, and consistent approval rules.
When the medical, moving, and charitable rates apply
The 20.5-cent medical rate belongs to qualifying medical travel, not work trips. The 20.5-cent moving rate is much narrower and is limited to eligible active-duty Armed Forces members and certain intelligence community members under current federal rules. The 14-cent charitable rate belongs to qualifying service for a charitable organization. Those categories should stay separate from a business reimbursement file so the report does not mix unrelated rule sets.
Which vehicles the rate covers
The 2026 announcement says the federal rates apply to cars, vans, pickups, and panel trucks, including gasoline, diesel, hybrid, and fully electric vehicles. If your situation involves a vehicle outside that group, do not assume the same cents-per-mile treatment without checking the applicable rule or policy.
When actual expenses may be the better method
The federal rate is a useful shortcut, but it is not always the best fit. Some self-employed readers will compare it with the actual-expense method because they have high ownership or operating costs, while some employers will compare it with a car allowance or FAVR design because role costs vary too much for one flat rate. The point is not to memorize one number and stop there. The point is to use the right method for the vehicle, the worker, and the year.
A simple 2026 mileage calculation
Suppose you drove 150 approved business miles in February 2026. At 72.5 cents per mile, that is $108.75 before any separately documented parking or tolls. If the same report also includes miles from December 2025, split the report before you calculate. The 2026 rate only applies to miles driven in 2026.
Why mileage logs and mileage tracking still matter
The cleanest rate calculation still fails if the trip record is weak. That is why IRS Mileage Log Requirements matters as much as the rate table.
If you want the reporting side handled as you drive, MyCarTracks automatic mileage tracking can capture trips, separate business and personal driving, and keep the export tied to the right year instead of leaving you to rebuild the file later. For the broader product overview behind that workflow, use MyCarTracks.
- Identify the person or entity using the record: employee, employer, self-employed worker, volunteer, contractor, owner, or fleet manager.
- Identify the purpose: reimbursement, deduction, payroll support, job costing, customer billing, vehicle program review, or fleet reporting.
- Identify the tax year and the US rule set that applies. Do not mix business, medical, moving, charitable, reimbursement, and state-law rules in one calculation.
- Confirm whether the trip qualifies under the relevant source. A route can be real and still be personal, commuting, or outside the policy.
- Apply the rate, method, or program only after the trip record is complete.
- Save the source, report, approval, and payment record together.
Rate calculation workflow
For a rate-based calculation, keep the math transparent:
- source rate
- effective date
- qualifying distance
- excluded distance
- reimbursement or deduction purpose
- separate parking and tolls
- reviewer or approver
Example: 86.4 business miles at 72.5 cents per mile equals $62.64 before any separately handled parking or tolls. If part of the route was personal, remove that distance before multiplying. If the trip happened in a prior year, use the prior-year rate. If the report spans two rate periods, split the report.
Rates are useful because they standardize calculations. They are risky when people use them as shortcuts for eligibility. The official rate source should be saved with the article, policy, or reimbursement report.
Suppose a consultant drives 86.4 business miles for client meetings in February 2026. The business calculation is 86.4 x 72.5 cents, or $62.64, before any separately supported parking or tolls. If the same consultant also drove 18 personal miles that day, those miles stay out of the business calculation.
Now suppose the same report includes December 2025 trips. Those trips should not use the 2026 rate just because the report was prepared in 2026. Split the report by tax year, save the official IRS rate source for each year, and keep the trip log behind the calculation.
Save the official source used for each rate, rule, or policy decision. For public articles, that means linking to the IRS or the relevant state source rather than repeating unsupported third-party claims. For internal company use, it means saving the policy version and source rate that were active when the trip was paid. This matters when a reader later asks why a 2026 trip was calculated differently from a 2025 trip, or why one state required a different reimbursement workflow from another state.
- Is the trip business, commuting, personal, medical, charitable, or another category?
- Is the rate from the correct tax year and rule set?
- Are different trip categories kept separate?
- Does the record name the vehicle and driver?
- Does the business purpose make sense without extra memory?
- Are parking, tolls, and other route costs handled separately?
- Are total annual vehicle miles needed?
- Is the reimbursement policy saved with the report?
- Are state-specific rules relevant?
- Is a professional review needed before filing, payroll, or policy decisions?
Get tax, payroll, legal, or accounting review when the answer affects a filed return, employee wages, worker classification, taxable benefits, multi-state reimbursement, FAVR design, or a dispute over unpaid expenses. A mileage app can make the record cleaner, but it cannot decide the legal or tax treatment by itself.
- date of each trip
- start and end location, destination, route, or client/job context
- distance driven
- driver or employee name when a team is involved
- total odometer readings where required
- receipts for fuel, charging, repairs, parking, tolls, insurance, registration, and other vehicle costs
- reimbursement requests, approvals, denials, and employer policy documents
- tax-year rate source used for each calculation
- using the current rate for an older tax year
- mixing commuting, personal errands, and business miles
- saving only payout, calendar, or bank records without a mileage log
- forgetting total annual miles when actual expenses or business-use percentages matter
- treating an employer reimbursement policy as if it were a tax rule
- treating a tax rule as if it were an employer reimbursement promise
- missing parking, tolls, support trips, return trips, and supply runs
- waiting until tax season to explain routes from memory
What is the 2026 IRS business mileage rate?
The 2026 IRS business standard mileage rate is 72.5 cents per mile for qualifying business use of a car, van, pickup, or panel truck.
Can I use the 2026 rate for 2025 miles?
No. Use the rate for the year the miles were driven. A 2025 trip should be calculated with the 2025 rate, even if you prepare the report in 2026.
Can an employer reimburse more or less than the IRS rate?
Yes. Employers are not forced to use the federal business rate as their company policy, but reimbursements above the substantiated federal-rate treatment can create wage and payroll consequences. Keep the policy source and the trip record together.
Does the IRS mileage rate include gas?
The business standard mileage rate is designed to account for vehicle operating costs through a per-mile rate. Do not add fuel as a separate vehicle operating cost when using the standard mileage method without professional review. Parking and tolls may be handled separately when they are business-related and supported.
Do electric vehicles use a different IRS mileage rate?
No. The IRS 2026 announcement says the rates apply to gasoline, diesel, hybrid, and fully electric vehicles.
Does the standard mileage rate replace the mileage log?
No. The rate tells you how to price qualifying miles. The mileage log is still what proves the trip date, destination, business purpose, and distance.
- Record trips automatically.
- Classify business and personal driving while the trip is still fresh.
- Add tags for employee, vehicle, client, project, platform, or state.
- Review mileage weekly so personal stops and unclear routes are fixed early.
- Export reports by tax year, pay period, vehicle, driver, or reimbursement cycle.
- What Is a Mileage Log?
- IRS Mileage Log Requirements
