Car fringe benefits tax can apply when an employer provides a car, or makes a car available, for an employee’s private use. The ATO taxable value of a car fringe benefit guidance points employers to the statutory formula method or the operating cost method, and the operating cost method needs adequate records.
FBT is an employer-side tax. It is separate from an employee claiming unreimbursed work-related car expenses and separate from a cash car allowance paid through payroll. If an employer-provided car has private use, salary packaging, employee contributions, electric-vehicle treatment, parking, tolls, or reimbursement of private costs, check the current ATO source before calculating.
This article is educational and is not tax, legal, payroll, employment, or financial advice. FBT rules, rates, thresholds, exemptions, and lodgment dates can change. Check current ATO guidance and a qualified professional before lodging or relying on an FBT calculation.
Car FBT is mainly an employer issue. It can apply when a car is available for an employee’s private use, including some salary-packaged or company-car arrangements. Employers generally calculate taxable value with the statutory formula method or the operating cost method. The operating cost method needs logbook and odometer records, while all FBT positions need records that support the taxable value, exemption, or concession claimed.
When can a car fringe benefit arise?
A car fringe benefit can arise when a car is provided to an employee, or an associate of an employee, and it is used or available for private use. “Available” matters: a car garaged at home or otherwise available for private use can create FBT questions even if business use is also substantial.
Common situations include:
- company cars available after hours
- salary-packaged or novated-lease cars
- pool cars taken home overnight
- employer-paid private-use running costs
- cars used partly for work and partly privately
- reimbursed private-use vehicle costs
If the car is used only for work duties and private use is genuinely excluded, the FBT analysis may be different. Keep records showing the restriction and actual use.
Car allowance is different
A cash car allowance is usually an allowance paid through payroll. It is not the same as providing a car for private use.
For employees, the ATO employment allowances guidance generally treats allowances shown on an income statement or payment summary as income to declare. For employers, a cash allowance belongs in payroll and withholding analysis rather than ordinary car FBT analysis, unless another benefit is also provided.
Statutory formula method
The statutory formula method uses the car’s base value, a statutory percentage, days available for private use, days in the FBT year, and employee contributions to work out taxable value.
In practical terms, the taxable value formula is:
(base value x statutory percentage x private-use availability days / days in the FBT year) - employee contribution
Use this method when the required facts are available and it produces an appropriate result for the arrangement. Keep purchase or lease records, availability records, employee contribution evidence, and calculation worksheets.
Do not copy old examples or rate figures without checking the current ATO rates and thresholds page. The FBT year and calculation settings can change, and the taxable value is only one step before any gross-up and FBT rate calculation.
Operating cost method
The operating cost method uses actual operating costs and private-use percentage. It can be useful when business use is high, but it depends on adequate records.
Records usually include:
- logbook records
- odometer readings
- fuel or charging records
- servicing, repairs, tyres, insurance, and registration records
- lease or finance records
- employee contributions
- worksheets showing private-use percentage and taxable value
The ATO record keeping for FBT guidance lists records such as calculations, worksheets, employee declarations, invoices, receipts, logbooks, and odometer records.
Fringe benefits tax rate, gross-up, and taxable value
Do not treat the car’s taxable value as the final FBT payable. Employers generally work out taxable value first, then apply the correct gross-up treatment and FBT rate when calculating the FBT amount to pay.
For FBT years ending 31 March 2022 through 31 March 2026, the ATO FBT rates and thresholds page lists a 47% FBT rate, a type 1 gross-up rate of 2.0802, and a type 2 gross-up rate of 1.8868. Check the current ATO table before using these figures, especially once you are working beyond the 31 March 2026 FBT year.
Electric cars and plug-in hybrids
The electric car exemption is conditional. The ATO electric cars exemption page sets out requirements for eligible electric cars and associated car expenses.
Eligibility can depend on points such as whether the vehicle is a zero or low emissions car, when it was first held and used, passenger and load limits, the luxury car tax position, the employee relationship, and whether associated car expenses are within the exemption.
Plug-in hybrid electric vehicles changed from 1 April 2025. The ATO plug-in hybrid guidance says a PHEV is no longer considered a zero or low emissions vehicle under FBT law from that date, although transitional treatment can continue where the ATO requirements are met.
Do not assume “electric” or “hybrid” means exempt. Confirm the vehicle type, first use, luxury car tax position, timing, and any binding commitment before applying an exemption.
Other vehicle, parking, and toll FBT issues
The ATO FBT on cars, other vehicles, parking and tolls hub separates cars, other motor vehicles, exempt use of eligible vehicles, electric cars, car parking, and road or bridge tolls.
Some utes, vans, taxis, and other vehicles can have limited private-use concessions or exemptions, but the answer depends on the vehicle and use. Car parking and tolls also have their own FBT rules. Treat those as separate checks rather than assuming they follow the company-car answer.
For car parking, check the ATO car parking and FBT conditions before deciding no benefit exists. The check can include whether the employer owns, leases, or controls the parking premises, whether the parking is at or near the employee’s primary place of employment, whether a commercial parking station within one kilometre charges above the threshold, whether the car is parked for more than four hours between 7 am and 7 pm, whether the employee drives between home and work, and whether an exemption applies.
Car parking exemptions can apply for some employees with disabilities, small businesses, exempt employers, and minor benefits. Do not apply those shortcuts without checking the detailed ATO conditions.
FBT year, lodgment, and payment
The FBT year runs from 1 April to 31 March. The ATO lodging and paying FBT guidance says employers with an FBT return obligation generally lodge and pay by 21 May, unless a tax agent lodgment date, extension, or next-business-day rule applies.
Do not wait until income tax year-end to review FBT records. FBT has its own year and due dates.
Records employers should keep
Keep FBT records for five years. A practical car FBT file includes:
- vehicle purchase, lease, or finance records
- registration and insurance records
- fuel, charging, servicing, repair, tyre, toll, and parking records
- logbooks and odometer readings
- employee declarations or alternative records where relevant
- employee contribution records
- statutory formula or operating cost worksheets
- private-use policy and availability records
- EV/PHEV exemption support where claimed
- FBT return, lodgment, and payment records
Records should support the taxable value, exemption, concession, or decision not to lodge.
How MyCarTracks helps with car FBT records
MyCarTracks automatic mileage tracking can capture trip records, separate business and private use, and export reports by driver, vehicle, date, purpose, and distance. That is useful when a car FBT position needs logbook, odometer, or private-use support.
For teams, MyCarTracks fleet tracking can help managers review vehicle activity, driver usage, and vehicle records before FBT, payroll, finance, or accountant review.
- Treating a company car as FBT-free because it is used mostly for work.
- Ignoring that availability for private use can matter.
- Treating a cash car allowance as the same thing as a car fringe benefit.
- Using old FBT rates, thresholds, EV rules, or PHEV treatment without checking current ATO guidance.
- Choosing the operating cost method without adequate logbook and odometer records.
- Treating taxable value as the same as final FBT payable and skipping gross-up treatment.
- Missing employee contributions or private-use records.
- Leaving EV, PHEV, parking, toll, ute, van, or exempt-vehicle questions until after the FBT year has ended.
- Keeping trip records but no calculation worksheet or exemption support.
Who pays car FBT?
FBT is paid by the employer, not the employee. It can apply when the employer provides a car or makes a car available for private use.
Is a car allowance subject to FBT?
A cash car allowance paid through payroll is generally income/payroll treatment rather than a car fringe benefit. FBT may still matter if the employer also provides a car or reimburses private-use costs.
What methods calculate car FBT?
The ATO points employers to the statutory formula method and the operating cost method. The operating cost method requires adequate records.
What FBT rate applies to car fringe benefits?
For FBT years ending 31 March 2022 through 31 March 2026, the ATO rates and thresholds page lists a 47% FBT rate. Check the current ATO table before relying on the rate for a later FBT year.
Do I need a logbook for car FBT?
You need adequate records for the method used. The operating cost method relies on logbook and odometer support to work out private-use percentage.
Are electric cars exempt from FBT?
Some electric cars can be exempt if the ATO requirements are met. Plug-in hybrid electric vehicle treatment changed from 1 April 2025, with transitional rules only where the conditions are satisfied.
When is the FBT return due?
The FBT year runs from 1 April to 31 March. Employers who need to lodge generally lodge and pay by 21 May unless a tax agent date, extension, or next-business-day rule applies.
- Mileage Reimbursement Rules for Employers (Australia) for reimbursement policy and payroll context
- Is Car Expense Reimbursement Taxable Income? (Australia) for employee payment treatment
- ATO Car Logbook Requirements (Australia) for trip, odometer, and logbook records
- Logbook Method (Australia) for business-use percentage records
- ATO: Taxable value of a car fringe benefit
- ATO: FBT on cars, other vehicles, parking and tolls
- ATO: Car parking and FBT
- ATO: Electric cars exemption
- ATO: FBT on plug-in hybrid electric vehicles
- ATO: Lodging your FBT return and paying
- ATO: Record keeping for FBT
- ATO: Employment allowances
- ATO: Fringe benefits tax - rates and thresholds
