Claiming mileage on taxes can lower taxable income, but only if the miles were actually deductible and the record behind them is strong enough to survive review later.
Before you file, match the trip to the right federal rule set and the right form. Business vehicle deductions for self-employed filers usually flow through Schedule C, while the recordkeeping and method rules live in Publication 463. Limited employee categories still use Form 2106.
If the hard part is mileage tracking rather than tax math, MyCarTracks automatic mileage tracking can help you keep trips organized before filing season turns into reconstruction season.
Most people claiming mileage on taxes start by deciding whether the trip belongs under the standard mileage method or actual expenses. Then they separate business driving from commuting and personal use, keep mileage logs and supporting documents, and report the deduction on the tax form that fits their filing status.
Who can claim mileage on taxes
The answer depends on why you drove and how you file.
- Self-employed individuals, independent contractors, and sole proprietors often claim vehicle deductions as part of their business filing through Schedule C.
- Some mileage can also matter for itemized medical or charitable deductions, which connect to Schedule A and the detailed rules in Publication 502 and Publication 526.
- A narrow group of employees still has a federal path through Form 2106, including Armed Forces reservists, qualified performing artists, fee-basis state or local government officials, and employees with impairment-related work expenses.
If you are self-employed and need the broader filing context after the mileage calculation, Self-Employed Mileage Deduction Rules and How to Claim Self-Employed Taxes are the right next reads.
Step 1: Choose the calculation method
Most business filers choose between the standard mileage method and actual expenses.
The standard mileage method uses a flat federal rate for each qualifying business mile. The actual expense method uses the business-use share of real vehicle costs instead. The better fit depends on your records, your vehicle costs, and whether the vehicle still qualifies for the standard method.
If you are still deciding between those methods, compare them directly in Standard Mileage Rate vs Actual Expenses before you file.
Step 2: Gather mileage tracking records
Your tax form is the last step. The real work is building the file behind it.
Mileage tracking records to gather
Keep these items together before you calculate anything:
- date of each trip
- start and end points or a usable route description
- business purpose for the trip
- miles driven for the trip
- total annual miles for each vehicle when the method requires a business-use percentage
- receipts for parking, tolls, and vehicle costs where relevant
- reimbursement records if an employer or client already paid part of the cost
That is why What Is a Mileage Log?, IRS Mileage Log Requirements, and How to Track Mileage for Tax Deductions matter before the filing screen opens.
Step 3: Calculate the deduction
Once the trips are classified and the records are in order, you can do the math.
Standard mileage method
The standard mileage method multiplies qualifying miles by the applicable federal rate for the year the miles were driven. For 2026, the IRS announced these standard mileage rates in its 2026 mileage-rate release:
| Use | 2026 rate |
| Business | 72.5 cents per mile |
| Medical | 20.5 cents per mile |
| Moving for eligible active-duty Armed Forces members and certain intelligence community members | 20.5 cents per mile |
| Charitable service | 14 cents per mile |
Parking and tolls for qualifying business trips can still matter, but they do not get folded into the per-mile number. If that distinction is still fuzzy, read Business Travel Tax Deduction before you combine route costs with mileage.
The actual expense method adds up the vehicle costs you can support, then applies the business-use percentage for the year. Publication 463 covers the deductible categories, including gas, oil, tires, repairs, insurance, registration fees, licenses, parking fees, tolls, lease payments, and depreciation where applicable.
That method can produce a larger deduction for some vehicles, but it also demands better records. If you use a mixed-use vehicle, business miles alone are not enough. You also need total annual miles and clean receipts so the percentage can be defended later.
Step 4: Put the deduction on the right tax form
After you know the method and the amount, move it onto the filing form that matches the trip category.
For self-employed filers and business owners
Self-employed taxpayers typically report qualifying vehicle deductions through Schedule C. If self-employment tax applies, the business result also feeds into Schedule SE. The IRS self-employed tax center is the best official starting point if you need the full filing chain.
For medical and charitable mileage
Medical mileage and charitable mileage do not use the same filing path as self-employed business mileage. Those deductions usually connect to itemized deductions on Schedule A, and the eligibility details live in Publication 502 and Publication 526.
For qualified employees
The remaining federal employee exceptions use Form 2106. If you do not fall into one of those exception categories, the vehicle deduction path is usually closed even if the driving was real and work-related.
Step 5: Keep the records after filing
Mileage deductions are easier to defend when the file survives beyond tax day.
Publication 463 explains that, in general, you should keep deduction records for three years from the date you file the return on which the deduction is claimed. If depreciation, amended returns, reimbursement disputes, or audit questions remain open longer, keep the related vehicle records longer too.
If you want the support file to stay cleaner from the start, use IRS Receipt Requirements for the Self-Employed with the mileage log so receipts and trip records do not drift into separate folders.
Most employees cannot deduct unreimbursed mileage
This is where many filings go wrong. A person can drive for work and still have no personal federal deduction available.
Current IRS guidance keeps the employee deduction path narrow. Most employees cannot use mileage as an unreimbursed employee deduction, while the specific Form 2106 categories above remain the main federal exceptions. If you are really dealing with reimbursement rather than deduction, What Is Mileage Reimbursement? and Mileage Reimbursement Rules for Employees are the better follow-ups.
How to protect more of the deduction
The easiest way to lose part of the deduction is to miss qualifying miles or mix them with nondeductible trips.
- separate business miles from commuting miles while the trip is still fresh
- save the rate source for the correct tax year instead of using the current year’s number by habit
- keep vehicle-level records if more than one car is used for business
- hold parking and tolls outside the mileage line when the method requires it
- keep moving-mileage claims separate from ordinary business miles because the eligibility is much narrower; see Moving Expense Mileage Deduction: Who Can Still Claim It?
If you use MyCarTracks for the record layer, the MyCarTracks features page shows the reporting and logbook-style exports that are useful when you need year-end review, accountant handoff, or reimbursement support.
Common mistakes when claiming mileage
- using the wrong year’s mileage rate
- treating commuting as deductible business mileage
- forgetting that actual expenses still need mileage records
- using a reimbursement record as if it automatically proves a tax deduction
- mixing medical, charitable, moving, and business miles in one total
- failing to keep total annual miles when the business-use percentage matters
- relying on memory instead of a mileage log and receipts
Do I need a mileage log if I use the standard mileage method?
Yes. The rate tells you how to price the mile. The log is what proves that the mile was qualified in the first place.
Can I claim both standard mileage and actual expenses for the same vehicle in the same year?
Not as two separate deductions for the same use. You choose the method that applies to that vehicle for that year, subject to the switching and eligibility rules explained in Publication 463.
Can I deduct mileage for driving from home to work?
Usually no. Ordinary commuting is generally nondeductible, although temporary workplace rules and qualifying home-office situations can change the analysis in some cases.
What if I already received reimbursement?
Do not assume the same cost can simply be deducted again. The tax treatment depends on what was reimbursed, how it was substantiated, and whether the payment already covered the business vehicle cost.
Use MyCarTracks as the trip record layer first, then let the tax form follow the facts.
- Capture trips throughout the year instead of rebuilding them at filing time.
- Classify business, commuting, and personal driving while the details are still clear.
- Export vehicle-specific reports by tax year when you are ready to calculate the deduction.
- Keep the mileage report with receipts, reimbursement records, and the official source pages used for the filing decision.
For a broader view of the product and reporting workflow behind that process, see MyCarTracks.
- Self-Employed Mileage Deduction Rules
- Business Miles vs Commuting Miles
- How to Track Mileage for Tax Deductions
