Illinois Mileage Reimbursement Rules
Illinois mileage tracking and reimbursement questions need to start with the statute if you want to review employee driving claims correctly, not the spreadsheet. Section 9.5 of the Illinois Wage Payment and Collection Act requires reimbursement for necessary expenditures or losses incurred within the scope of employment and directly related to services performed for the employer.
That rule is broad enough to make mileage reimbursement a policy question and a documentation question at the same time. Illinois allows employers to use written reimbursement policies, set documentation standards, and pick a workable reimbursement method, but those choices still need to fit the statute. Many employers use the 2026 IRS business mileage rate of 72.5 cents per mile as the starting benchmark for a cents-per-mile plan.
If you want the mileage log captured before the claim deadline becomes a problem, MyCarTracks automatic mileage tracking can help you preserve routes, classify business driving, and export reports that are easier for managers and payroll to review.
Illinois generally requires employers to reimburse employees for necessary work-related expenses, including qualifying vehicle use, when those costs are incurred within the scope of employment and directly related to services performed for the employer. The safest Illinois setup is a written policy, a clear documentation standard, and a reimbursement method that can be explained with the mileage log behind it.
Illinois reimbursement rule
Illinois gives you a direct statute to work from. Section 9.5 says an employer shall reimburse an employee for all necessary expenditures or losses incurred within the scope of employment and directly related to services performed for the employer. The statute defines necessary expenditures as reasonable costs required in the discharge of employment duties and primarily benefiting the employer.
The details in that same section matter just as much as the headline rule:
  • employees generally must submit supporting documentation within 30 calendar days after incurring the expense
  • a written expense reimbursement policy can allow additional time
  • if supporting documentation is nonexistent, missing, or lost, the employee may submit a signed statement
  • an employer is not responsible for losses caused by the employee’s negligence, normal wear, or certain theft losses
  • a written policy can set specifications or guidelines, but it cannot function as a no-reimbursement or de minimis reimbursement rule when the statute otherwise requires payment
That is why Illinois reimbursement disputes often turn on documentation and policy language rather than only on the mileage number itself. The Illinois Department of Labor Wage Payment and Collection Act page is a useful state starting point when the issue has already turned into a wage claim or compliance review.
Methods of mileage reimbursement in Illinois
Illinois employers usually rely on one of these methods:
  1. cents-per-mile reimbursement
  2. actual expense reimbursement
  3. FAVR reimbursement
Each method can work, but each one asks for a different level of tracking discipline.
Cents-per-mile (CPM)
The cents-per-mile method is usually the simplest Illinois option. Employees document qualifying business miles, and the employer reimburses those miles at a fixed rate. Many employers use the current IRS business mileage rate because it is familiar, updated annually, and easy to apply across a larger team.
That simplicity is the main advantage. A clean log plus a known rate is easier to review than a stack of mixed receipts. It is also easier to scale across employees who drive different routes but follow the same policy. If you are building the policy from scratch, How to Calculate Mileage Reimbursement and What Is Mileage Reimbursement? cover the core mechanics.
The actual expense method asks employees to track both mileage and vehicle costs, then apply a business-use percentage to those costs. That can make reimbursement more precise when driving volume swings widely or when the employer wants the reimbursement to reflect real operating costs more closely than a flat mileage rate does.
The downside is paperwork. Employees need mileage logs, receipts, and enough total-mileage history to support the business-use percentage. The more mixed-use the vehicle is, the more important it becomes to separate work miles from commuting and personal miles early. Standard Mileage Rate vs Actual Expenses and Business Miles vs Commuting Miles are the best next reads when the method choice is still unsettled.
FAVR reimbursement method
FAVR, short for fixed and variable rate reimbursement, splits vehicle costs into fixed items such as insurance, taxes, registration, and depreciation and variable items such as fuel, maintenance, oil, and tires. That can produce a more tailored result for teams that drive regularly and need a program more precise than a flat cents-per-mile rule.
FAVR is harder to administer well. It works best when the company has recurring drivers, consistent mileage reporting, and enough administrative discipline to maintain the program. If your Illinois workforce is comparing structured vehicle programs, FAVR Reimbursement Plans Explained and Car Allowance vs Mileage Reimbursement help frame the tradeoffs.
Mileage tracking records for Illinois claims
Illinois reimbursement policy is easier to follow when the supporting file is consistent from the first trip to the final approval. For a mileage-based program, that usually means keeping:
  • trip date
  • starting point and destination
  • miles driven
  • employee or driver name
  • parking and toll support when reimbursed separately
  • written policy version in effect for that claim period
If the company uses actual expenses, receipts and total-mileage support also become part of the file. If documents are missing, Illinois law allows a signed statement, but that should be the exception rather than the routine workflow.
The cleaner the file, the less likely the dispute becomes about memory. That is why What Is a Mileage Log? and IRS Mileage Log Requirements matter even when the question began as a state-law issue.
  • missing the 30-day documentation deadline when the written policy does not allow more time
  • using a mileage total without the trips that support it
  • treating commuting as reimbursable business mileage
  • writing a policy that sets standards but leaves employees guessing what proof is required
  • relying on missing receipts when a stronger mileage log could have prevented the dispute
Illinois reimbursement problems often start with late or vague records. A company can have the right policy and still end up with weak claims if employees wait until month-end to guess at routes, forget client destinations, or submit a single rounded total without the underlying trips.
Automatic trip capture helps because it turns reimbursement into a review task instead of a memory task. If you need a cleaner export by employee, vehicle, or pay period, MyCarTracks mileage reports can help you move from raw trip history to a manager-ready claim file. For the broader admin view behind approvals, reporting, and fleet context, use the MyCarTracks homepage.
