Amazon Flex mileage tracking matters because it helps you keep more of what you earn and avoid turning tax season into a reconstruction project.
Amazon shows block offers and payouts, but it does not give you a complete Amazon Flex mileage tracking system for taxes, deductions, or honest profit review. If you do not track the miles yourself, it becomes much harder to answer basic questions later: how much did this block really make, which trips were business-related, and do you have enough proof if someone asks how you got your numbers?
This Amazon Flex mileage guide is for drivers who want a simple answer to three things: which miles should be tracked, how detailed the record needs to be, and how to build a mileage log that is actually useful instead of just technically present.
What Amazon Flex drivers need to know first
If you drive for Amazon Flex, start tracking miles as you work, not months later. Keep the date, route or destination, business purpose, distance, station, return trips, tolls, parking, and any personal stops that broke up the day. Then match that record with your block history and deposits so you can see both your tax deduction and your real profit.
Why Amazon Flex drivers should care about mileage tracking
If you deliver with Amazon Flex in the US, you are typically handling your own business records as an independent contractor. That means you do not just need to know what Amazon paid you. You also need to know what it cost you to earn that money.
That is where mileage tracking creates real value. Every qualifying business mile can reduce taxable income when your records support the deduction. For many drivers, mileage is one of the biggest vehicle-related records in the business, which is why it can have a direct effect on how much tax you pay.
Mileage tracking also tells you whether a block was actually worth taking. A block can look fine on the offer screen, but once you include the drive to the station, the route itself, a return to the warehouse, tolls, parking, and the drive after the last stop, the numbers can change quickly. Without a solid mileage record, it is easy to overestimate profit and keep accepting blocks that are weaker than they look.
That is also why rough guesses are not good enough. IRS rules are built around records, not memory. If you wait until tax season and try to rebuild the year from payout screens, calendar notes, map history, and toll statements, you are much more likely to miss miles or end up with a file you do not fully trust.
Good Amazon Flex mileage tracking gives you something immediately useful: a stronger deduction file, a cleaner year-end workflow, and a much better read on what your delivery work is really earning.
Which Amazon Flex miles should you track?
The simplest way to think about Amazon Flex mileage is this: track the segments that explain what happened during the workday, then review which parts belong in your business total.
That matters because an Amazon Flex day rarely looks like one clean trip. A normal block can include driving to the station, loading packages, following the route between stops, making a return, stopping for something personal, and ending up far from home. If all of that becomes one number in a notes app, you lose the detail that makes the record useful.
What usually belongs in the record
Amazon Flex drivers usually want to capture:
- the drive tied to an accepted block
- the station or warehouse segment
- miles between delivery stops
- return-package trips
- route-related support or follow-up trips
- supply runs with a clear delivery-work purpose
- tolls and parking connected to the route
What usually should stay out of the business total
These usually need to stay separate unless a later review shows a specific business purpose:
- personal errands
- school or family driving
- meal stops that were simply personal use
- miles for another app unless tagged separately
- driving with no accepted block or no business reason
Track first, classify second. That does not mean every recorded mile automatically becomes deductible. It means you preserve enough detail to review the trip properly instead of guessing later.
A simple Amazon Flex example
Imagine you accept a block, drive to the station, complete the route, stop at a grocery store on the way home, then return one undelivered package to the warehouse. Those are not all the same kind of miles. A useful record separates the station drive, the delivery route, the personal stop, and the return-package trip. Once the day is broken down that way, it is much easier to review what belongs in the business record and what does not.
What US drivers should know about Amazon Flex mileage deductions
For US drivers, mileage tracking is not just an admin task. It is part of how you support one of the biggest deductions available to vehicle-based gig workers.
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. That is why this topic matters so much in practice. If you drive a lot for Amazon Flex and keep a strong log, those miles can add up to meaningful tax savings. IRS Publication 463 also says business-related parking fees and tolls may be deductible separately from the standard mileage rate.
The key point is not that every mile automatically helps you. The key point is that the Amazon Flex mileage deduction can be valuable, but only when the record is detailed enough to support it.
What the IRS wants in an Amazon Flex mileage log
IRS Publication 463 is the baseline here. The IRS wants a record that shows when you drove, how far you drove, and why the trip was related to the business.
For Amazon Flex, a useful Amazon Flex mileage log should usually show:
- the date
- the distance
- the route context, start point, or destination
- the business purpose
- the vehicle used
- total annual miles for the vehicle when needed
- tolls, parking, and related notes
- notes that explain returns, mixed-use days, or other unusual route details
This is where many drivers get caught out. They keep Amazon screenshots, block history, or payout records and assume that is enough. It is not. Those records show income and app activity. They do not fully explain the miles behind the work.
If you want the deeper field-by-field version of that rule, read IRS Mileage Log Requirements.
What happens if your mileage record is weak
When mileage tracking is incomplete, two problems usually show up:
- Your deduction is harder to support because the record is thin.
- Your profit review is less reliable because the route cost is unclear.
That is why drivers end up rebuilding the year from memory, screenshots, toll statements, and map history. It is possible, but it is much weaker than a log kept close to the trip.
Standard mileage or actual expenses: which one fits better?
Most Amazon Flex drivers eventually ask the same question: should I use the standard mileage method or actual expenses?
The honest answer is that it depends on your vehicle, your costs, and how good your records are. Mileage tracking still matters either way.
Standard mileage method
With the standard mileage method, you multiply qualifying business miles by the IRS rate for the year. Many Amazon Flex drivers prefer this because it is simpler. You still need a strong mileage log, but you do not need to allocate every car receipt to the same degree as the actual-expense method.
This method is often attractive when you drive a lot and want a cleaner system. It still requires discipline, though. You need to separate personal driving, keep route details, and preserve the notes that explain what the trip was for.
With actual expenses, you track the business-use share of costs such as:
- fuel or charging
- repairs and maintenance
- tires
- registration
- lease costs or depreciation where applicable
- tolls and parking
This method can work better for some drivers, especially when vehicle costs are high, but it requires more paperwork. You need receipts, business miles, and total vehicle miles so the business-use percentage can be calculated correctly.
If you want the full car-cost comparison behind that choice, see Standard Mileage Rate vs Actual Expenses.
A practical way to compare the two
If you are not sure which method will be better, the practical answer is simple:
- Track mileage correctly from day one.
- Keep your vehicle receipts too.
- Compare the methods before filing.
That gives you options later instead of locking you into weak records early. For a deeper comparison, see Standard Mileage Rate vs Actual Expenses.
A simple Amazon Flex mileage tracking workflow
The best workflow is the one you will actually follow on real block days, including apartment routes, returns, traffic, and personal stops that interrupt the day.
For most drivers, the easiest system is:
- Start tracking before you drive to the station.
- Tag the trip as Amazon Flex.
- Add a short note for the block, station, or route while the day is still fresh.
- Separate personal stops instead of leaving them buried in the route.
- Mark package returns clearly.
- Review the trip the same day or at least the same week.
- Match the log against block pay, tolls, parking, and receipts.
That review step is where mileage tracking becomes valuable. It is not just there to satisfy a tax rule. It shows whether the work made sense after the real driving cost is included.
Manual logs can work, but Amazon Flex often creates too many trip segments for memory-based tracking to stay clean. That is why many drivers prefer a mileage tracking app that captures trips automatically and lets them review the business details afterward.
Amazon Flex recordkeeping habits that save time later
These habits usually make the difference between a stressful tax file and a clean one:
- start tracking before the station drive, not after pickup
- keep return-package miles visible instead of hiding them in the daily total
- record tolls and parking alongside the route
- tag Amazon Flex separately from other gig apps
- keep total annual miles for the vehicle if actual expenses might matter
- compare the mileage log with block history and deposits at least monthly
Amazon Flex also creates a few patterns that are easy to under-record:
- apartment-heavy routes with extra parking time and route friction
- routes that end far from home
- failed deliveries that lead to return miles
- mixed days where Amazon Flex overlaps with another app or a personal errand
If those details are missing, the route can look cheaper and cleaner than it really was.
What changes for Canada and Europe
CRA says the best evidence for business vehicle use is a full and accurate logbook. For each business trip, CRA expects the date, destination, purpose, and kilometres driven. It also expects total kilometres, business kilometres, and odometer readings at the start and end of the fiscal period.
For Amazon Flex drivers in Canada, that means a vague monthly estimate is not enough. Your kilometre record should show what the trip was for and how it connects to the work, not just a number with no context.
Europe needs a more careful approach because worker status, vehicle-expense treatment, VAT, and platform rules can vary by country. The practical takeaway is to keep strong route logs, platform records, receipts, and local tax documents together so the file is usable when country-specific advice is needed.
How MyCarTracks helps with Amazon Flex mileage tracking
If you want a cleaner Amazon Flex mileage tracking workflow, MyCarTracks helps by automatically recording trips, separating business and personal driving, and exporting business mileage reports you can actually review later. That is especially useful for drivers who do not want to rebuild routes from memory every week.
You can also use MyCarTracks as your Amazon Flex mileage tracking system if you drive for more than one app and want one place to tag trips, review mixed-use days, and export records.
Before tax season, make sure you have these records
Before you file, make sure you can put your hands on:
- block history
- mileage exports or log summaries
- total annual vehicle miles
- station or route notes where needed
- return-package notes
- toll and parking records
- vehicle expense receipts if you may compare actual expenses
- payout history, deposits, and tax forms
Common Amazon Flex mileage mistakes
The most common mistakes are usually simple:
- waiting until tax season to estimate miles
- treating Amazon block history as a mileage log
- mixing Amazon Flex, personal driving, and other apps in one total
- forgetting return-package trips
- skipping total annual miles when actual expenses may matter
- losing toll and parking records
- leaving personal errands inside a business route
Most of the time, these mistakes cost drivers in one of two ways: a weaker deduction or a misleading picture of profit.
Questions Amazon Flex drivers usually ask
Can Amazon Flex block history replace a mileage log?
No. It can support your records, but it does not fully show the miles you drove or the business purpose behind each trip segment.
Should I track the drive to the station?
Yes, track it. Whether that segment ultimately counts the same way as the route itself can depend on your situation, but untracked miles cannot be reviewed later.
Do I need total annual miles for the vehicle?
Yes if you may use actual expenses or need to show business-use percentage. That is why beginning and ending odometer records still matter.
Is mileage tracking different from a mileage log?
They are closely related. Mileage tracking is the process of capturing trips. The mileage log is the record you keep, review, and rely on later for taxes and profit analysis.
Should I track package returns?
Yes. Returns can add real business miles and explain why a block took longer or cost more than expected.
- Amazon Flex Driver Guide
- Amazon Flex Delivery Blocks and Expenses
- Amazon Flex Driver Requirements
- Amazon Flex Insurance and Vehicle Rules
- Amazon Flex Pay Guide
- Amazon Flex Tax Deductions
- Amazon Flex Tax Guide
- Amazon Flex Tax Forms
- Why Gig Workers Need a Mileage Tracking App
- Gig Mileage Tracking Guide for the US, Canada, and Europe
- How to Track Income and Expenses Across Multiple Gig Apps
- IRS Mileage Log Requirements
