MyCarTracks CLI lets you work with the MyCarTracks API v3 from your terminal. It is useful for developers, internal automation, exports, reports, support checks, and AI agents that can run shell commands.
The CLI is based on Restish. Restish reads the MyCarTracks OpenAPI document and generates commands from the current API. When new API operations are published, you can sync the API specification and use the updated commands without installing a separate MyCarTracks binary.
What you can do
Use the CLI to:
- List vehicles, tracks, users, groups, jobs, geofences, and other API resources.
- Export API responses as JSON or YAML.
- Filter command output for reports and scripts.
- Build read-only fleet checks for operations or support teams.
- Give a shell-capable AI agent a safe way to inspect MyCarTracks data.
Before you start
You need:
- Restish installed on your computer.
- MyCarTracks API credentials.
- The official MyCarTracks CLI configuration from GitHub.
If you do not have API credentials yet, create them first: Where to get your API credentials?
Install Restish
Install Restish with Homebrew:
brew install rest-sh/tap/restish
Or install it with Go:
go install github.com/rest-sh/restish/v2/cmd/restish@latest
Get the CLI configuration
Clone the official MyCarTracks CLI repository:
git clone https://github.com/mycartracks/mycartracks-cli.git
cd mycartracks-cli
The repository contains a .restish.json file that connects Restish to the MyCarTracks API v3 base URL:
https://mycartracks.com/services/rest/v3
Restish uses the public OpenAPI document to build the command list:
https://mycartracks.com/services/rest/openapi.json
You can also browse the API documentation here:
Configure the CLI
Trust the project configuration once:
restish config trust
Sync the MyCarTracks API specification:
restish --rsh-profile public api sync mycartracks
The public profile is only used to download the public API specification. Your API commands still use your own credentials.
Set your MyCarTracks API credentials:
export MYCARTRACKS_CLIENT_ID="your-client-id"
export MYCARTRACKS_CLIENT_SECRET="your-client-secret"
By default, the CLI requests a read-only OAuth2 token.
Run your first commands
Show all available MyCarTracks commands:
restish mycartracks --help
List vehicles:
restish mycartracks list-vehicles --limit 10
List tracks:
restish mycartracks tracks --limit 10
Show help for a specific command:
restish mycartracks tracks --help
Output and filters
Return vehicle data as JSON:
restish mycartracks list-vehicles --limit 10 -o json
Return vehicle data as YAML:
restish mycartracks list-vehicles --limit 10 -o yaml
Show only selected fields:
restish mycartracks list-vehicles --limit 10 -q 'data[].{id:id,name:name}'
List tracks for one vehicle:
restish mycartracks tracks --vehicleIds 123 --limit 50
Use command help to see the available filters for each API operation:
Keep commands current
The CLI command list comes from the live MyCarTracks API documentation. Sync again when you want to refresh command names, parameters, or newly published operations:
You can inspect how Restish sees the API metadata:
restish doctor api mycartracks
Read and write access
The default configuration uses the read scope. This is enough for listing vehicles, tracks, users, groups, jobs, geofences, map sharing links, and other available read operations.
If your API credentials are allowed to use write access, update .restish.json and change both scopes values from:
read
to:
read write
Only use read write when your credentials are allowed to create, update, or delete API data.
Use with AI agents
MyCarTracks CLI is not an AI-agent skill by itself. It is a command-line tool. If your agent can run shell commands, you can create a skill, workflow, or instruction file that tells the agent how to use restish mycartracks ... safely.
Good agent tasks include:
- Check whether vehicles are returned by the API.
- Summarize recent tracks for a selected vehicle.
- Export vehicle or track data as JSON for another workflow.
- Look for missing, stale, or suspicious fleet data.
- Prepare an internal operations summary from read-only API responses.
For agent workflows, start with read-only credentials and ask the agent to show the command it plans to run before any write-capable action.
Example OpenClaw workflow
OpenClaw can run command-line agent tasks with openclaw agent. Use the MyCarTracks CLI repository as the workspace and make sure your API credentials are already set:
cd mycartracks-cli
Then ask the agent to use read-only CLI commands:
openclaw agent \
--agent ops \
--message "Use restish mycartracks list-vehicles --limit 100 -o json. Summarize vehicle IDs, names, and any obvious missing data. Do not modify anything."
For recent track review:
openclaw agent \
--agent ops \
--message "Use restish mycartracks tracks --limit 50 -o json. Summarize recent tracks by vehicle and note anything unusual. Do not call write commands."
OpenClaw agent names and model options depend on your own OpenClaw setup. Check the OpenClaw CLI documentation for the current command syntax:
Reusable agent prompt
Use this prompt with OpenClaw, Codex, Claude Code, or another shell-capable agent:
You are helping me inspect MyCarTracks fleet data.
Workspace:
- Use the current mycartracks-cli directory.
- Use Restish commands only.
- Use read-only API operations unless I explicitly approve otherwise.
Credentials:
- MYCARTRACKS_CLIENT_ID and MYCARTRACKS_CLIENT_SECRET are already set.
Task:
1. Run restish mycartracks --help to inspect available commands.
2. Run restish mycartracks list-vehicles --limit 100 -o json.
3. Run restish mycartracks tracks --limit 50 -o json.
4. Summarize vehicles, recent tracks, and any missing or suspicious data.
5. Include the exact commands used.
6. Do not change API data.
Optional skill file
Some agent systems let users create skills or reusable instructions. A customer can create a MyCarTracks skill that wraps the CLI and sets read-only defaults.
Example SKILL.md:
# MyCarTracks Fleet Data
Use this skill when the user asks to inspect MyCarTracks vehicles, tracks, positions, jobs, geofences, or fleet activity from the command line.
## Requirements
- Work inside the `mycartracks-cli` repository.
- Use `restish mycartracks ...` commands.
- API credentials must be available as `MYCARTRACKS_CLIENT_ID` and `MYCARTRACKS_CLIENT_SECRET`.
- Prefer read-only commands.
## Safety
- Do not use write commands unless the user explicitly approves the exact action.
- Do not print client secrets or bearer tokens.
- Do not edit `.restish.json` unless the user asks.
## Common commands
```sh
## Workflow
1. Sync the API spec if commands look stale:
```sh
2. Run the smallest read-only command that answers the request.
3. Parse JSON output.
4. Summarize IDs, names, dates, and anomalies clearly.
5. Include the exact command used in the final answer.
Adapt the skill format to the agent platform you use. The important point is that the skill treats MyCarTracks CLI as a tool and keeps read-only behavior as the default.
Troubleshooting
If commands are missing or old, sync the API specification again:
If authentication fails after changing credentials, clear cached tokens:
restish api auth logout mycartracks
If token fetching fails with invalid_scope, keep the default read scope unless your credentials are allowed to request write access.
If Restish says the project configuration is not trusted, run:
Or pass the config file explicitly:
restish --rsh-config ./.restish.json --rsh-profile public api sync mycartracks
restish --rsh-config ./.restish.json mycartracks --help
More links
- MyCarTracks API v3 documentation: MyCarTracks API v3
- MyCarTracks CLI GitHub repository: GitHub - mycartracks/mycartracks-cli: Restish-powered CLI configuration for accessing the MyCarTracks API v3 from the terminal using the live OpenAPI spec. · GitHub
- API settings: Log in to your vehicle tracking platform MyCarTracks
