DoorDash Tax Forms
DoorDash tax forms summarise income, but they are not the whole tax file. Dashers still need mileage logs, receipts, payout records, bank deposits, and notes for promotions, tips, Fast Pay, DoorDash Crimson, refunds, and adjustments.
The form is the starting point. Your own records explain what you earned, what reached the bank, and what expenses reduced taxable profit.
If you want a mileage tracker app, MyCarTracks mileage tracking gives you the workflow behind the log.
What Dashers need to know first
If you dash for DoorDash in the US, you are generally self-employed, so the tax form is only one piece of your year-end file. You report your own income, keep your own records, and file the return yourself or through a tax preparer.
Eligible Dashers commonly look for Form 1099-NEC through Stripe Express or DoorDash’s tax-form flow. If your account meets the reporting threshold, Stripe usually sends the form by January 31 of the following tax year. Some accounts may also see a 1099-K or only an annual earnings summary, depending on the payment flow and reporting setup.
Before you download the form, confirm the tax details in Stripe Express, including your name, address, and tax ID. If you want paperless delivery, opt in so the form is easier to download and store with the rest of the year-end file.
If no form arrives, keep the income records anyway. The reporting threshold decides whether a form is issued; it does not decide whether the income belongs on your return.
Tax forms you may see
1099-NEC
Form 1099-NEC reports nonemployee compensation. Stripe’s guidance for DoorDash Dashers says the form is generally sent when the reporting threshold is met, and Stripe Express usually makes the form available by January 31 if the account is eligible.
1099-K
A 1099-K can appear when the payment flow runs through a processor that files payment-card or third-party network reporting. Stripe’s 1099-K guidance explains that the form is informational and summarizes account activity for tax reporting.
Annual earnings summary
DoorDash summaries are useful even when they are not a tax form. They help you reconcile tips, promotions, Fast Pay transfers, DoorDash Crimson deposits, refunds, and adjustments against your bank records.
Save the full set:
  • Stripe Express or tax-form portal messages
  • DoorDash email notices
  • 1099 form PDF
  • corrected form if issued
  • annual earnings summary
  • payout statements
  • bank deposits
  • mileage exports
  • expense records
If you also have W-2 wages from another job, keep those forms with your DoorDash records instead of mixing them into the gig file.
Where to find your forms
Stripe Express is usually the first place to check. DoorDash and Stripe can also send email notices that point you to the tax documents. If your form is available electronically, the download usually appears in the same tax-form flow used for consent and corrections.
If your name, address, taxpayer ID, or amount looks wrong, save the original form, the correction request, any support ticket number, and the final corrected form.
If you only see an annual summary inside the Dasher app, keep it anyway. It may still help you reconcile the year before you file.
What to do if no form arrives
Do not treat the form threshold as an income threshold. If you dashed below the reporting threshold, used more than one account, changed payout methods, or received income that did not trigger a form, keep the income records anyway.
Reconcile:
  • DoorDash earnings screen
  • weekly or monthly statements
  • Fast Pay transfers
  • DoorDash Crimson deposits
  • bank deposits
  • tips and promotions
  • mileage and expenses
How mileage tracking fits your tax return
The IRS says self-employed income is usually reported on Schedule C, and net earnings from self-employment are figured on Schedule SE when the total net earnings from self-employment from all businesses is $400 or more. The self-employment tax rate is commonly 15.3%, so the form affects more than just the income line. Those forms feed into your Form 1040.
If you want the broader filing workflow behind those forms, see DoorDash Tax Guide. If you want the deduction side tied to the same file, see DoorDash Tax Deductions.
That means the DoorDash tax form is the summary, not the return itself. The tax return still needs the rest of the file:
  • Schedule C for income and expenses
  • Schedule SE for self-employment tax
  • Form 1040 as the main return
  • quarterly estimated payments if you expect to owe enough tax
If you expect to owe $1,000 or more for the year, the IRS generally expects estimated quarterly tax payments. A simple planning rule is to set aside money as you go instead of waiting for the filing deadline.
If you work for multiple apps, keep each platform clean on its own first. Then combine the totals on the tax return once DoorDash, Uber Eats, Instacart, or other app records are reconciled.
How to file with the form in hand
Once you have the DoorDash form, gather the rest of your tax documentation and decide how you want to file:
  • use IRS Free File if you qualify
  • use paid tax software if you want guided filing
  • use a tax professional if you want help with the return and deductions
Your DoorDash form helps you report the gross side of the work, but the deductions still matter. Common DoorDash expenses include mileage, parking, tolls, phone use, delivery gear, and other ordinary business costs.
What to keep with your forms
Your year-end folder should show the path from delivery work to tax return:
  • total DoorDash income
  • each tax form received
  • any 1099-K if issued
  • payout and deposit records
  • mileage log by vehicle
  • total annual vehicle miles or kilometres
  • receipts for delivery gear, phone, parking, tolls, vehicle costs, and software
  • correction or support messages
If a form is missing, keep the year-end statement, bank deposits, and app payout records together so you can still file accurately.
Save records by year and month. A good file name is simple: 2026-03-doordash-earnings, 2026-03-doordash-mileage, 2026-03-doordash-parking, and 2026-doordash-1099.
Regional notes
Canadian Dashers usually keep platform payout summaries, kilometre logs, receipts, and bank deposits rather than a US-style 1099 form. Use the same year-end folder to keep the business records in one place and follow the CRA’s vehicle-record rules when mileage or vehicle costs matter.
Australia and New Zealand
DoorDash also operates in Australia and New Zealand, but the year-end paperwork is not a US-style 1099 file. Keep platform payout summaries, mileage or kilometre logs, receipts, and local tax-ID details with the tax-year folder. Australian Dashers should keep ATO vehicle records, and New Zealand Dashers should keep IRD vehicle-expense records.
See DoorDash Australia, DoorDash New Zealand, the ATO’s motor vehicle expense records, and IRD’s vehicle expenses.
DoorDash is not the main delivery brand in most European markets, so the local paperwork often looks more like invoices, VAT records, or platform summaries than a US 1099 file. Keep the local tax office guidance and the platform records together with the mileage file.
Avoid these recordkeeping problems:
  • waiting until tax season to estimate mileage
  • treating the 1099 as the whole tax file
  • ignoring the annual summary because it is not a tax form
  • ignoring the form correction workflow when details are wrong
  • mixing multiple apps into one record before the platform totals are clean
  • forgetting to check Stripe Express or DoorDash email before assuming the form is missing
  • not saving corrections or support messages
  • filing without matching deposits to the year-end summary
Use MyCarTracks to keep DoorDash mileage tied to the same tax year as your Stripe Express or DoorDash earnings history. The business mileage reports page shows the reporting side.
