If you deliver with DoorDash as an independent contractor, this guide shows what to log, what counts, and how the mileage deduction works in the US, Canada, and Europe. Every qualifying business mile can lower taxable income and show whether a block made money after fuel, parking, tolls, and vehicle wear.
If you want a mileage tracker app, MyCarTracks mileage tracking gives you the workflow behind the log.
DoorDash restaurant and retail delivery can create more mileage than the payout screen shows. A single workday may include driving to a pickup, waiting, completing a delivery, repositioning to another zone, making a return or support trip, paying for parking or tolls, and mixing in personal stops. A clean mileage log keeps those pieces separate.
Track DoorDash miles while you drive, not at tax time. Save the date, route, distance, vehicle, business purpose, personal stops, tolls, parking, and platform tag. DoorDash can show useful trip activity, but you still need your own mileage log for taxes and profit review.
Why mileage tracking matters for DoorDash Dashers
Mileage tracking matters because DoorDash pay screens do not show the full cost of a run. If you are self-employed, business miles can be part of the record that lowers taxable income and helps you see whether a block, zone, or time window is actually worth driving.
The IRS gives self-employed drivers two common ways to handle vehicle costs: the standard mileage rate or the actual expenses method. Most Dashers start with the standard mileage rate because it is simpler to track, but the right method depends on the vehicle, the year, and the facts in your file.
What to track
Track each DoorDash trip with enough detail to connect the drive to the work:
- date
- start and end time
- starting and ending location or route context
- distance driven
- platform tag, such as
DoorDash - vehicle used
- restaurant pickup, retail pickup, delivery dropoff, hotspot, or support-related return
- tolls, parking, and route costs
- personal stops or gaps that should be separated from work mileage
What counts as business mileage
Track miles connected to the work itself:
- driving to the pickup or merchant
- driving from pickup to customer dropoff
- miles between deliveries while actively dashing
- hot-spot repositioning with a clear business purpose
- support-related returns, replacement trips, or supply runs tied to DoorDash
- toll or parking segments that are part of the delivery route
The IRS expects business mileage to be ordinary and necessary for the work, so the point of the log is to show the business connection clearly.
Some trips need extra care. Driving from home to the first work location, or from the last work stop back home, can be treated differently depending on your tax situation, regular work location, and local rules. Track those miles separately instead of blending them into the work route.
What usually does not count
Do not mix personal driving into DoorDash mileage totals. Examples to separate include:
- personal errands during a dash
- driving with no active dash or delivery purpose
- commuting or home-based driving that your local rules treat as personal
- meal breaks, school runs, family stops, or unrelated shopping
- miles for Uber Eats, Instacart, or another app unless tagged separately
When in doubt, record the trip and classify it later. Missing records are harder to fix than an extra trip that can be marked personal.
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. That rate is optional and applies to business use of a car, van, pickup, or panel truck. Self-employed workers commonly report vehicle expenses on Schedule C when the vehicle is used for business.
The standard mileage method is often simpler because you multiply qualifying business miles by the IRS rate. IRS Publication 463 also explains that business-related parking fees and tolls may be deductible in addition to the standard mileage rate. You still need a mileage log.
The actual expense method works differently. Instead of using a cents-per-mile rate, you track vehicle costs such as fuel, insurance, repairs, registration, tires, lease payments, depreciation, tolls, and parking, then apply the business-use percentage. To do that correctly, you need both business miles and total vehicle miles for the year.
Method choice can matter. Publication 463 says that if you want to use the standard mileage rate for a car you own, you must choose it in the first year the car is available for business use. If you lease the car, the standard mileage rate generally has to be used for the entire lease period once chosen. Review the current IRS rules or ask a tax professional before switching methods.
How to claim your mileage deduction
When it is time to file, US Dashers commonly report business income and vehicle costs on Schedule C. That is where the mileage log becomes part of the tax file instead of just a driving log.
If you want the full filing path that connects mileage to Schedule C, Schedule SE, and estimated taxes, see DoorDash Tax Guide.
You usually choose between two methods:
- Standard mileage rate: multiply your qualifying business miles by the IRS rate for the year.
- Actual expenses: deduct the business-use share of fuel, repairs, insurance, registration, depreciation, lease costs, parking, and tolls.
Do not use both methods for the same vehicle in the same year unless the IRS rules allow a switch. Keep the mileage log, the route context, and the receipts together so the tax file and the trip file tell the same story.
Keep mileage logs and receipts for at least three years in case you need them later.
What the IRS wants to see
A useful mileage log should be created close to when the driving happens. For DoorDash, keep records that show:
- date of the drive
- mileage or distance
- where the trip started and ended
- total miles for the vehicle during the year
- parking, tolls, and other route expenses with receipts where available
Keep platform records, payout records, and mileage records together. If the trip history, route notes, and earnings records tell the same story, your records are easier to review.
If you want the full checklist for building that record set, see How to Track Mileage for Tax Deductions.
Canadian Dashers should keep total kilometres, business kilometres, receipts, and any records that support the business-use share of a vehicle. A business-trip log should include the date, destination, purpose, and kilometres driven. See CRA’s motor vehicle expenses and motor vehicle records guidance for the recordkeeping rules.
If you use more than one vehicle, keep a separate log for each one. If you work on multiple platforms, tag the platform on every trip so DoorDash kilometres do not get mixed with other business or personal driving. If a route mixes business and personal use, write that split down the same day instead of reconstructing it later.
Australia and New Zealand
DoorDash is available in Australia and New Zealand, so the same mileage log structure applies there too. Keep the date, route, business purpose, trip distance, and receipts for tolls or parking, then separate personal driving from work driving as soon as you can. See the local DoorDash pages for Australia and New Zealand.
Australian Dashers should also keep business records tied to their ABN and local tax rules. The ATO says to keep kilometres for business and private use, plus receipts, tax invoices, registration papers, and claim details, and to keep those records for 5 years; see the ATO’s motor vehicle expense records and motor vehicle expense methods guidance.
New Zealand Dashers should keep the same trip notes, plus any records tied to their IRD number and local vehicle-expense rules. IRD says vehicle claims can use a logbook or actual-cost method and that home-to-work travel is personal; see Vehicle expenses.
Use country-specific guidance for DoorDash or similar local platform work. Vehicle expense treatment, VAT, worker status, invoicing, and social-contribution rules can differ by country, so keep the same record structure but check the EU’s platform work rules and then your local tax office guidance before filing.
Workday workflow
Use the same workflow every time you drive:
- Before starting a dash, start mileage tracking and tag the trip as DoorDash.
- When a personal stop happens, end or reclassify that segment.
- Use notes for unusual routes, stacked orders, tolls, parking, or support issues.
- After the dash, compare mileage with payout, tips, and direct costs.
- Each week, review whether zones and time blocks are profitable after mileage.
This weekly review is where many workers find missing value. A trip that looks profitable in the app may be weaker after mileage, parking, tolls, supplies, wait time, and vehicle wear are counted.
Avoid these recordkeeping problems:
- waiting until tax season to estimate mileage
- saving only payout screenshots without trip records
- combining multiple platforms and personal miles in one category
- forgetting returns, supply runs, or support-related trips
- claiming every mile driven that day without separating personal stops
- changing vehicles without tracking total miles for each vehicle
- losing receipts for parking, tolls, supplies, or route costs
Use MyCarTracks to record delivery miles automatically, tag DoorDash shifts, separate personal driving, and export tax-ready reports. The business mileage reports page shows the reporting side.
- DoorDash Driver Guide
- DoorDash Requirements
- DoorDash Pay Guide
- DoorDash Tax Guide
- DoorDash Tax Deductions
- DoorDash Tax Forms
- DoorDash Insurance Requirements
- How to Track Mileage for Tax Deductions
- How to Start Gig Driving: Requirements, Taxes, and Mileage
- DoorDash Become a Dasher
- DoorDash Dasher Pay
- DoorDash Australia Dasher Pay
- DoorDash New Zealand Dasher Pay
- IRS Publication 463
- IRS 2026 standard mileage rate announcement
- CRA motor vehicle expenses
- CRA motor vehicle records
- ATO motor vehicle expense records
- ATO motor vehicle expense calculation methods
- IRD vehicle expenses
- EU rules on platform work
