DoorDash taxes are easier to manage when you split them into three jobs: report the income, subtract the work costs, and keep the proof. If you dash as an independent contractor, DoorDash does not withhold taxes for you, so your mileage log and receipt folder are part of the return, not optional extras.
If you want a mileage tracker app, MyCarTracks mileage tracking keeps the miles, notes, and year-end reports in one place.
The right tax file tells the full story of the work. It shows what DoorDash paid, what reached your bank, what you spent to earn it, and which miles were business miles rather than personal driving.
What DoorDash drivers need to know first
As a Dasher, you are usually self-employed. That means DoorDash earnings are not taxed the same way as W-2 wages, and taxes are not automatically withheld from each payout.
The tax picture usually includes two layers:
- income tax on the profit after deductions
- self-employment tax, which covers Social Security and Medicare for self-employed workers
The IRS explains that self-employed workers generally file an annual return and pay estimated taxes quarterly when needed. For many Dashers, the first step is simply to keep income, mileage, and expense records organized by tax year.
How to file DoorDash taxes
Most Dashers file through Form 1040 with Schedule C for business income and expenses and Schedule SE for self-employment tax. If estimated tax payments are due, those are usually handled through Form 1040-ES during the year.
You can file with:
- IRS Free File if you qualify
- tax software
- a tax professional
A clean filing flow usually looks like this:
- Download the DoorDash tax form if one was issued.
- Match DoorDash income to bank deposits and payout records.
- Export your mileage log and keep personal trips separate.
- Sort expenses into clear categories.
- Compare the standard mileage method with actual expenses if you track both.
- File the return and keep the final copy with the year-end records.
That order matters because the tax form is only the summary. The mileage log, the receipt folder, and the bank history are what make the return easier to defend later.
What tax forms do you get from DoorDash?
US Dashers commonly receive Form 1099-NEC through Stripe Express or DoorDash’s tax-form flow when earnings meet the reporting threshold. When the account is eligible, the form is generally available by January 31 of the following year.
If you want the document-by-document version of that process, use DoorDash Tax Forms.
Before you download the form, confirm the tax details in Stripe Express, including your name, address, and tax ID. If paperless delivery is available, opt in so the form is easier to store with the rest of the year-end file.
Some Dashers may also see a 1099-K or an annual earnings summary, depending on the payment flow and reporting setup. Even if the form is small or the summary looks incomplete, keep it with the year-end file.
If the form is wrong, save the original PDF, the correction request, and the support case number with the tax-year folder. The form is part of the record, but it is not the whole tax file.
What is DoorDash’s NAICS principal business code?
When you file DoorDash taxes in the US, you may be asked for a principal business code on Schedule C. For delivery drivers, the code commonly used is 492000, which the IRS Schedule C instructions list under couriers and messengers.
That code fits DoorDash work because you are delivering food, groceries, and other local orders rather than running a restaurant or a passenger transport business. If you see other codes suggested online, check whether they actually describe delivery work before you copy them into the return.
What if you made less than $600?
You still need to report the income. The $600 threshold determines whether a form is issued, not whether the income belongs on the return.
If you dashed for even a short stretch, keep the income records anyway:
- DoorDash earnings history
- bank deposits
- payout screenshots
- tips and adjustments
- mileage logs
That is especially important if you used more than one app, changed payout settings, or did not receive a form for part of the year.
What happens if you do not report DoorDash income?
If you skip income that should have been reported, the IRS can charge penalties or interest, and a missing form does not remove the duty to report the work income. If the IRS receives a 1099 that does not match what you filed, the mismatch can create a bigger problem later than a clean return would have.
The practical fix is simple: keep the income records, keep the forms, and reconcile the numbers before you file.
What expenses can Dashers deduct?
Common DoorDash deductions include:
- mileage or actual vehicle costs
- fuel or charging
- repairs, tires, brakes, and maintenance
- parking and tolls
- phone and data
- hot bags and courier backpacks
- drink carriers, chargers, and mounts
- roadside assistance
- software or subscriptions used for the work
- delivery-use insurance where applicable
- tax preparation costs
Mixed-use costs need a business-use split. If a phone, vehicle, or subscription is also used personally, only the business portion belongs in the DoorDash file.
The point of the deduction section is not to claim everything possible. It is to keep the costs that truly help explain why taxable profit was lower than gross DoorDash income.
For the category-by-category write-off version, see DoorDash Tax Deductions.
Do you need quarterly estimated tax payments?
If you expect to owe $1,000 or more for the year, estimated quarterly payments usually matter. The IRS says self-employed workers generally pay Social Security, Medicare, and income taxes through estimated taxes because no employer is withholding them.
For 2026, the usual estimated-tax due dates are:
- April 15, 2026
- June 15, 2026
- September 15, 2026
- January 15, 2027
If you are not sure what to set aside, a practical habit is to move money into a tax reserve each week or month instead of waiting until filing season.
In the US, DoorDash income is commonly handled as self-employment income. The IRS self-employed tax center explains that gig workers usually file an annual return, pay estimated taxes quarterly when needed, and report the business on Schedule C with self-employment tax on Schedule SE.
The 2026 IRS business standard mileage rate is 72.5 cents per mile. That rate is useful because it turns clean business miles into a deduction without forcing you to track every fuel receipt as the main method.
Keep US records together by tax year:
- 1099-NEC, 1099-K, or annual summary
- Schedule C support
- Schedule SE support
- estimated-tax confirmations
- mileage log
- receipts and bank deposits
Canadian Dashers should keep income records, receipts, total kilometres, business kilometres, and records that support the business-use portion of mixed-use vehicle costs.
The CRA says vehicle expense records should include the date, destination, purpose, and kilometres driven, plus enough support to show the business share. Keep separate logs if you use more than one vehicle.
If GST/HST or a business number applies to your situation, keep those records in the same year-end folder instead of scattering them across different apps or notebooks. See the CRA’s motor vehicle expenses and motor vehicle records guidance.
Australia and New Zealand
DoorDash also operates in Australia and New Zealand, so the same recordkeeping habit applies there: separate business trips from personal driving, save receipts, and keep the local tax-ID details with the year-end folder. Australian Dashers should keep kilometres, tax invoices, registration papers, and business-use splits for vehicle claims. New Zealand Dashers should keep a logbook or actual-cost records and separate home-to-work travel from business travel.
See DoorDash Australia, DoorDash New Zealand, the ATO’s motor vehicle expense records, and IRD’s vehicle expenses.
DoorDash is not the main delivery platform in many European countries, so local delivery work often follows country-specific rules for VAT, invoices, social contributions, insurance, and worker status.
Use the same recordkeeping structure, but check the local tax office and platform rules before you file. The EU’s platform work rules are a useful starting point for the wider policy picture.
What if you drive for multiple apps?
If you work for DoorDash and other delivery platforms, keep each app separate during the year so income, mileage, and deposits stay clean.
At tax time, you usually combine the self-employment numbers on the same return rather than treating each app as a separate business file. The important part is not to double-count mileage or expenses that belong to more than one platform.
Mileage tracking and records to keep
Keep one DoorDash tax folder with:
- tax forms and corrections
- Stripe Express or tax-form portal messages
- DoorDash earnings records
- bank deposits
- Fast Pay or DoorDash Crimson records
- mileage exports
- receipts and invoices
- insurance and vehicle records
- support messages for missing pay or adjustments
If you work for more than one delivery app, keep each platform’s records separate until the final tax return stage. That makes it easier to match income, deposits, and mileage without double-counting.
- using bank deposits as the only income record
- ignoring income because no 1099 arrived
- estimating mileage at the last minute
- mixing DoorDash, personal driving, and other apps
- forgetting phone, bags, tolls, parking, and software
- claiming personal costs as business costs
- not saving corrected forms or support messages
Use MyCarTracks to keep DoorDash mileage current all year. Tag DoorDash sessions, separate personal driving, and export monthly reports that match your income, deposits, and receipts.
The business mileage reports page shows the reporting side when you need a clean tax-year export.
- DoorDash Background Check
- DoorDash Driver Guide
- DoorDash Insurance Requirements
- DoorDash Mileage Guide
- DoorDash Pay Guide
- DoorDash Tax Deductions
- DoorDash Tax Forms
- DoorDash Requirements
- DoorDash Dasher Pay
- DoorDash Australia
- DoorDash New Zealand
- Stripe platform-issued 1099 FAQs
- IRS self-employed individuals tax center
- IRS Schedule C & Schedule SE FAQ
- IRS estimated tax FAQ
- IRS Publication 463
- IRS instructions for Schedule C
- IRS 2026 standard mileage rate announcement
- CRA motor vehicle expenses
- CRA motor vehicle records
- ATO motor vehicle expense records
- IRD vehicle expenses
- EU rules on platform work
