VEHICLES
To access and manage the list of your vehicles from the web-console, click VEHICLES tab. You will get cumulative information about your vehicles in clearly formatted table with more options for every vehicle. Use the filter to set exact date you need statistics and choose only vehicles you want to view. Select Statistics and you can look at your data in a new perspective. After you selected vehicles and your desired date range you can export that data in Excel format that can be also opened with Open Office or Google Docs.
You can add new vehicle by pressing the green button ** Add new vehicle. Use sharing to share it among your employees.
You can also edit every vehicle you created, e.g. color of the vehicle, odometer state and more. The same color will be used to visualize this vehicle.
If your vehicle didn’t send any data for a long time and you would like to know where the vehicle is, you can request its actual position by clicking on ** Request actual position button.
TRACKS (trip records)
To access the list of recorded trips, click on TRACKS tab. You’ll get time sorted records of every vehicle in your fleet. You can use filter to view records only from certain vehicles and certain date range. This list contains mileage data with a graph and a button to view logged statistic details.
Learn more about log book reports if you want to generate and save tracks as PDF or Excel.
