If you want to drive for Uber, the car has to qualify first. The wrong vehicle will show up quickly in your mileage tracking, inspection costs, insurance bills, and the products you can actually accept, so this guide helps you avoid the wrong purchase and compare what the car will really cost.
A car that works for one city or one Uber product can still fail another. Before you buy, lease, borrow, or rent, check the local vehicle list, the ride type, and the document file you will need to keep active.
If you want the cost side organized from day one, MyCarTracks mileage tracking helps you separate Uber miles, inspection trips, maintenance runs, and personal driving while the records are still easy to explain.
Before you commit to a car for Uber, check the city and product rules first. Save the eligible-vehicle page, registration, insurance, inspection form, upload confirmation, and any rejected-document message. A vehicle can qualify for UberX and still fail Uber Comfort, Uber Black, Uber Green, Uber WAV, or a local private-hire rule.
The baseline your car has to meet
Besides meeting driver requirements and passing screening, you need an eligible vehicle before you can take ride requests.
How old can your Uber car be?
The maximum age limit is often up to 16 years old, but that can be lower in some cities and for some products. The safest way to check is to use Uber’s eligible vehicles list before you buy or switch cars.
What condition and features your car needs
Your vehicle usually needs to meet these baseline standards:
- It has at least four doors.
- It fits at least four passengers plus the driver.
- It has no commercial branding, taxi coloring, cosmetic damage, or missing parts.
- It has working windows and air conditioning where the local product requires them.
- It has a clean title rather than a rebuilt, salvaged, or reconstructed title.
What changes for other ride types
Once you move beyond the standard product, the rules get stricter. UberXL, Uber Black, Uber Premier, Uber Comfort, Uber Green, and Uber WAV all add their own seating, model-year, insurance, licensing, or accessibility rules.
Registration, insurance, and inspection records
The vehicle file matters as much as the vehicle itself.
Keep these records together:
- Registration, whether official or temporary if your market accepts it.
- Proof of insurance that matches the vehicle you plan to use.
- Inspection form, inspection receipt, and the next due date where inspections are required.
- Upload confirmations and rejected-document messages so you can see exactly what Uber accepted or rejected.
Some markets accept a car that is not registered in your name, while others do not. If you are using a borrowed vehicle, keep the owner-permission record and make sure the insurance file clearly supports your use of the car.
UberX and UberXL
UberX is the standard ride class, and it usually carries these additional rules:
- It is not a box truck, marked government vehicle, or taxi-style vehicle.
- It has factory-installed seat belts and seating.
- It has no aftermarket seating or other passenger modifications that break the local standard.
UberXL usually adds capacity requirements:
- The vehicle often needs seven factory-installed seats and seat belts.
- The age limit can be lower than the general city limit.
- Large passenger vans or commercial-style models may still be excluded.
Uber Black and Uber Black SUV
Uber Black and Uber Black SUV have stricter standards than UberX:
- The vehicle must usually be no more than five years old in the US.
- It needs a black exterior.
- It needs a black leather or vegan-leather interior.
- It needs to be on the local eligible model list.
- The driver usually needs a rating of at least 4.85.
- Commercial insurance and any local for-hire permits or licensing are part of the file.
These products are not just a nicer version of UberX. They are usually a separate compliance and insurance workflow.
Uber Premier
Some cities use Uber Premier instead of, or alongside, Uber Black.
The usual Premier standards include:
- At least five factory-installed seat belts.
- A relatively new model year.
- A Premier-eligible make and model on the local list.
- A leather interior.
- A strong driver rating, often at least 4.85, after enough completed trips.
Premier can open a higher-value product without every commercial-insurance rule that Uber Black may require, but the local list still controls what qualifies.
Uber Comfort and Uber Comfort Electric
Uber Comfort is for newer, roomier eligible vehicles. The usual setup requires:
- A qualifying model with extra legroom.
- At least 100 completed trips.
- A driver rating of at least 4.85.
Uber Comfort Electric adds one more layer:
- The car needs to be a qualifying fully electric model.
- The local age limit for the electric product still applies.
Uber Green
Uber Green is available only in select markets and usually requires:
- A qualifying hybrid, plug-in hybrid, or fully electric vehicle.
- A model year that still fits the local age limit.
If you are choosing a vehicle just to reach Uber Green, check the local product list first. Not every efficient vehicle qualifies.
Uber WAV
Uber WAV is built around wheelchair-accessible transportation, so the requirements are narrower:
- The vehicle needs to be on the Uber WAV eligible list.
- It needs a ramp or lift.
- Some markets also require passenger-service and safety certification.
- The service is only available in specific locations.
If WAV is your target product, confirm the city, certification, and vehicle model before you assume the car can be activated.
How to get a car that qualifies
You can drive with a vehicle you own, lease, or borrow with permission if the local market accepts that setup and the insurance file works. In rental markets, Uber may require you to use an approved vehicle partner instead of an ordinary consumer rental.
Before you commit, save:
- The local eligible-vehicle list.
- The rental, lease, or purchase agreement.
- The insurance file.
- The inspection file.
- The local product page you are qualifying for.
If you need a rental or partner vehicle, use the official Uber vehicle marketplace rather than assuming any rental will work.
Mileage tracking, taxes, deduction choices, and reimbursement records
Vehicle approval is only the first decision. After that, you still need to know whether the car makes sense financially and whether the same car will still work when taxes, deduction choices, and reimbursement records are reviewed later.
Track:
- Business miles by vehicle.
- Fuel or charging costs.
- Insurance costs.
- Cleaning and maintenance.
- Tires and brakes.
- Inspection and permit fees.
- Tolls and parking.
- Downtime after repairs.
- Reimbursement records or platform reimbursements that change the real cost of a trip.
If you want the tax side too, Uber Tax Guide and Uber Tax Deductions show how those records feed into the year-end file.
US vehicle rules vary by state and city, but the official requirement pages are still the starting point. Use the US vehicle requirements page for the general baseline, then confirm the eligible-model list and any local inspection rules before you commit to a car.
Canada keeps the baseline tighter and more explicit: four doors, ten years or newer, good condition, no branding, no salvaged or rebuilt status, and a licensed-mechanic inspection. In Canada, the vehicle needs to be registered in your name.
United Kingdom
In the UK, vehicle rules sit inside a private-hire system. That means the vehicle file and the licensing file usually move together, so check the local Uber vehicle page and the licence flow before you assume a car is ready.
Australia
Australia relies heavily on city and state rules, so vehicle approval can shift by location even inside the same country. Keep the state, city, and product page you used for approval beside your inspection and insurance records.
Germany
Germany is more regulated than a simple UberX-style setup. Vehicle compliance can connect to concession rules, commercial passenger transport, and local licensing, so keep the vehicle page and the business file together.
France
France ties vehicle use closely to VTC-style professional-driver rules. That means the vehicle file is only one part of the approval workflow, and you should keep the local requirement page with the insurance and licensing file.
Additional supported markets
Uber is active in many more markets than this guide can cover section by section. If you drive in Austria, Italy, or Spain, use the local Uber requirement and vehicle pages before you rely on a US or Canadian checklist.
Global availability
Uber operates in more than 15,000 cities worldwide. Use that as a reminder that the platform is global, but the vehicle rule that matters is still the one for your city and product.
How old can your car be before Uber rejects it?
The general upper age limit is often around 16 years, but many products and cities use lower limits. Uber Black, Premier, and other premium options usually require much newer vehicles.
Which vehicles usually fail Uber approval?
Cars that are too old for the market, have commercial branding, have a rebuilt or salvaged title, have cosmetic damage or missing parts, or fail the local product-specific rules are commonly rejected. Modified passenger seating can also disqualify a vehicle.
Can the vehicle you choose change what you earn?
Yes. Your vehicle choice affects which products you can drive, how much you spend on fuel or charging, insurance, cleaning, and maintenance, and whether the extra revenue from a premium product actually turns into better profit.
Use MyCarTracks to compare vehicle eligibility with real operating cost instead of guessing from payout screens alone.
The business mileage reports workflow helps you tag Uber driving, inspection trips, maintenance runs, and personal miles separately so you can see what the car really costs.
- Uber Background Check
- Uber Driver Guide
- Uber Insurance Requirements
- Uber Mileage Guide
- Uber Pay Guide
- Uber Tax Guide
- Uber Driver Requirements
- Uber US vehicle requirements
- Uber eligible vehicles list
- Uber vehicle inspection page
- Uber Comfort service requirements
- Uber Black service requirements
- Uber Black and SUV requirements help
- Uber WAV service requirements
- Uber Vehicle Marketplace
- Uber Canada vehicle requirements
- Uber UK vehicle requirements
- Uber Australia vehicle requirements
- Uber Germany driver requirements
- Uber France driver requirements
- Uber cities worldwide
