If you drive Uber, the miles that matter are often the ones you barely notice while you are working: the trip to a pickup, the gap between ride requests, the airport queue, the short repositioning drive after a drop-off, and the ride home when you finally log out. Mileage tracking turns those pieces into a record you can actually use at tax time.
If you want one place to keep the log without rebuilding it from memory, MyCarTracks gives you a clean starting point.
You do not need a perfect memory. You need a habit that separates business miles from personal miles while the week is still fresh.
The IRS treats deductible mileage as ordinary and necessary business use, so the log needs to be detailed enough that you can explain each trip later instead of guessing at tax time.
Mileage tracking that keeps your Uber week honest
Your log does three jobs at once. It shows which miles belong to the business, gives you the numbers you need to compare deduction methods, and gives you a record that still makes sense if you review it months later. If you wait until tax season to sort it out, the week turns into guesswork.
A useful log should show:
- the date
- the start and end points
- the business purpose
- the vehicle you used
- the miles or kilometres
- parking, tolls, and other route costs when they matter
You can keep that record in a notebook or spreadsheet, but most drivers do better with a mileage tracker app because it captures the trip while you are still driving.
The IRS expects a contemporaneous log, not a reconstruction you make months later.
Mileage tracker app setup
Set up automatic tracking before your first paid Uber trip if you can. That gives you a clean baseline and keeps your business miles from getting mixed with the personal trips you take the same week. A tracker like MyCarTracks mileage tracking keeps the log moving while you stay focused on the road.
Miles you should keep
You should keep the miles that exist because you are driving Uber, including:
- driving to a passenger pickup
- driving the passenger to the destination
- moving between ride requests while you stay available on the app
- repositioning after a drop-off to reach a better area
- driving to a required inspection or vehicle check
- picking up supplies or equipment for rideshare work
Miles you should leave out
You should not fold these miles into the business total:
- your commute from home to the first pickup if you are offline
- driving home after you log out at the end of the shift, unless your home is your principal place of business
- personal errands, even if they happen on a work day
- side trips that had nothing to do with Uber
If a drive mixes business and personal use, split it. A trip that is clearly labeled later is easier to defend than a mile you cannot separate anymore.
Standard mileage or actual expenses
Uber mileage tracking matters because it helps you choose between two different ways to handle vehicle costs.
Standard mileage rate
This is the simpler path. You multiply your qualifying business miles by the IRS rate for the year, and that becomes your deduction. The rate bundles common vehicle costs into one number, so you do not have to add up every oil change, repair, or tire on its own.
For many Uber drivers who put a lot of miles on the car, this method is also simpler and often the better fit because one rate covers the common running costs.
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. Self-employed drivers commonly report the deduction on Schedule C.
Actual expenses method
This method takes more work, but it can make sense if your vehicle costs are high. Instead of using a cents-per-mile rate, you total the cost of running the vehicle and apply the business-use percentage.
Typical expenses include:
- fuel or charging
- repairs and maintenance
- lease payments or depreciation
- registration fees
- tires, brakes, and other wear items
If you use this method, keep both your business miles and your total miles for the year. You need both numbers to support the business-use share.
For example, if you drove 20,000 miles total and 15,000 of them were Uber miles, then 75 percent of the qualifying vehicle costs could be deductible under the actual-expenses method.
What to keep with the log
Some costs still matter even if you choose the standard mileage rate:
- parking fees
- tolls
- route-specific costs you paid while driving Uber
- parking while you are waiting for or picking up passengers
Traffic tickets and fines do not belong here.
Keep those receipts with the trip record. They explain why one workday cost more than another and make the file easier to review later.
How the Uber app changes the miles you drive
The app decides the shape of your week. Once you are online, it sends ride requests, shows the pickup and destination, and gives you the choice to accept or skip a request. It also helps you see how far you are from the pickup before you commit.
That matters for mileage because every request is not just a fare. It is also a distance decision. A short ride may still create a long deadhead trip if you need to move to a better area afterward.
When busy hours pay more
Peak hours, surge pricing, airport traffic, and local events can all change the miles you drive. You may make more money in those windows, but you may also drive more empty miles to get there or to get out afterward.
Promotions and bonuses can help too, but they do not change the fact that you still need to log the miles behind the ride. If you chase a bonus without tracking the drive, you can end up with good earnings and weak records.
Safety that protects you and your log
Uber’s in-app safety features can matter to your recordkeeping too. GPS tracking, the emergency button, and trip sharing are there for personal safety, but they also help you document what happened if a trip turns into a claim or dispute.
You should also trust your instincts. If a situation feels off, you can cancel the ride. Keep the doors locked until the rider is inside, and do not share more personal information than you need to.
Passenger comfort still changes the trip
A clean car, a clear greeting, and basic communication still matter. Passengers who feel comfortable are less likely to create avoidable friction, and that can help with ratings and tips.
You do not need to turn every ride into a conversation. You just need a car that feels ready for the next passenger and a habit that keeps the trip moving without drama.
What to do at tax time
When tax season comes, the log does the heavy lifting. Self-employed Uber drivers usually report vehicle expenses on Schedule C, then choose between standard mileage and actual expenses.
You cannot use both methods for the same vehicle in the same year. Compare your mileage total against your vehicle costs before you file, and keep the log, receipts, and year-end records together so the method you choose is easy to support.
Keep those logs and receipts for at least three years, and do not switch methods casually unless you meet the IRS rules for changing.
Report the deduction on Schedule C (Form 1040), not as a guess buried in your personal return.
If the year is messy, a tax professional can help you decide which method fits your numbers better.
Mistakes that shrink the deduction
The mistakes that hurt mileage deductions are usually the simple ones:
- waiting until tax season to rebuild the log
- mixing personal driving with business miles
- forgetting airport lines, repositioning, or inspection trips
- estimating miles instead of recording them
- changing methods without checking the IRS rules first
If you are unsure about a trip, keep it and classify it later. A trip you can still label is better than a mile you cannot prove.
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. Publication 463 also says parking fees and tolls tied to business driving may be deductible in addition to the standard rate. You still need a real log, and you still need to choose between standard mileage and actual expenses for the same vehicle.
CRA says to keep total kilometres and business kilometres when a vehicle is used for both business and personal driving. A business trip log should include the date, destination, purpose, and kilometres driven. If you drive Uber in Canada, keep the kilometres tied to the vehicle you actually use and keep personal driving separate. See Uber Canada tax information and CRA motor vehicle records.
United Kingdom
Uber’s UK tax page explains VAT registration, the Flat Rate Scheme, and how driver earnings flow through local tax rules. Keep your mileage log with your earnings and VAT records so the trip history still lines up when you review business use later. See Uber UK tax information.
Australia
Uber’s Australia tax page says driver-partners are responsible for their own tax and GST, receive monthly and annual Tax Summaries, and may claim Uber-related expenses. Keep your mileage log aligned with those summaries so you can tie gross fares, expenses, and route history together. See Uber Australia tax information and Uber Australia tax FAQ.
Germany
Uber’s Germany tax page says VAT registration (USt-IdNr.) may be required and can take 2 to 6 weeks. Keep your mileage records with the VAT paperwork, fleet records, and business registration files so the route log and tax record support the same work history. See Uber Germany tax information.
France
Uber’s France tax page says VAT registration can be mandatory once turnover passes the current threshold and may take 2 to 4 weeks. It also explains that VAT on business expenses such as fuel and car repairs may matter, so your mileage log should sit next to the VAT file and expense receipts. See Uber France tax information.
Uber’s wider footprint
Uber says it operates in more than 15,000 cities worldwide, so the regional notes above are only the markets where Uber’s own pages give enough detail to matter for logs, taxes, or vehicle compliance. See Uber cities worldwide.
Austria
Uber’s Austria pages show that some drivers work through taxi companies or fleet partners rather than a private-car model. Keep your mileage log with the taxi or fleet records and the vehicle documents that show how you are allowed to drive. See Uber Austria driver requirements and Uber Austria vehicle requirements.
Italy
Uber’s Italy pages say drivers may need a driver licence, CAP, registration to the driver’s role, and VAT registration, while the vehicle page lists NCC licence, liability insurance, and booklet documents. Keep mileage records beside those papers so the trip log and compliance file match the same work history. See Uber Italy driver requirements and Uber Italy vehicle requirements.
Spain
Uber’s Spain pages say VTC drivers need a driver licence, NIE/TIE in some cases, and vehicle documents such as a circulation permit, ITV, VTC licence, and insurance. Keep the mileage log with those documents so the work record supports the local compliance file. See Uber Spain driver requirements and Uber Spain vehicle requirements.
Use MyCarTracks to record rideshare miles automatically, tag Uber trips, separate personal driving, and export tax-ready reports.
The business mileage reports page gives you the export when tax season arrives.
- Uber Background Check
- Uber Driver Guide
- Uber Insurance Requirements
- Uber Pay Guide
- Uber Driver Requirements
- Uber Tax Deductions
- Uber US tax information
- IRS Publication 463
- IRS 2026 standard mileage rate announcement
- Uber Canada tax information
- CRA motor vehicle records
- Uber UK tax information
- Uber Australia tax information
- Uber Australia tax FAQ
- Uber Germany tax information
- Uber France tax information
- Uber cities worldwide
- Uber Austria driver requirements
- Uber Austria vehicle requirements
- Uber Italy driver requirements
- Uber Italy vehicle requirements
- Uber Spain driver requirements
- Uber Spain vehicle requirements
