Lyft Driver and Vehicle Requirements (Canada)
Before you apply, use this Lyft driver requirements Canada checklist for your province and city. Start with Lyft Canada driver requirements, vehicle requirements, and province and city requirements before you buy a car, order a driving record, book an inspection, or assume one city’s rule works elsewhere.
The short version: Canadian Lyft drivers usually need to be at least 25, use a four-door vehicle with 5 to 8 seats, upload driver and vehicle documents, pass screening, and meet the local licence, inspection, insurance, GST/HST, and emblem rules for the city where they drive. Lyft also warns that vehicle age requirements are changing in select regions starting January 1, 2026, so treat the app and current local page as the final check.
Quick answer: Lyft driver requirements Canada
To drive with Lyft in Canada, prepare to check these items:
  • minimum age of 25
  • valid driver’s licence for the province and city, such as Ontario Class G or B.C./Alberta Class 1, 2, or 4 where required
  • required driving history for your region
  • driver screening that reviews driving history and criminal background
  • smartphone that can run the Lyft Driver app
  • four-door vehicle with 5 to 8 seats, including the driver’s seat
  • valid vehicle registration and personal or approved rideshare insurance documents
  • vehicle inspection or Safety Standards Certificate where required
  • proof of work eligibility
  • GST/HST account number for commercial ride-sharing
  • Lyft emblem, local licence, training, sticker, or in-car document where your city requires it
Do not rely on a national vehicle-age shortcut. Current Lyft Canada rules give different examples by region, including a 7-year rule for Toronto, 2017 or newer in B.C., 2016 or newer in Calgary, 2006 or newer in Edmonton, 10 years or newer in Quebec, 9 years or newer in Nova Scotia, and 20 years or newer for Winnipeg.
General Lyft driver qualifications in Canada
The general driver file starts with age, licence, screening, and work eligibility. Lyft Canada uses 25 as the minimum age, and applicants must also meet regional requirements.
Before you apply, gather:
  • driver profile photo
  • two pieces of government photo identification if your local onboarding flow asks for them
  • proof of vehicle insurance
  • vehicle registration
  • required local inspection certificate or report
  • driving abstract, commercial driving record, vulnerable-sector check, or police information check where your province requires it
  • GST/HST account number if you will provide taxable commercial ride-sharing services
For GST/HST, keep the rideshare rule separate from delivery-only gig work. CRA commercial ride-sharing guidance treats commercial ride-sharing drivers like taxi operators for GST/HST registration. If you want the broader Canada tax explanation, use GST/HST for Gig Drivers (Canada).
What your Lyft vehicle needs
The Canada vehicle baseline is simple, but the city rules are not. Your Lyft vehicle generally needs:
  • four doors
  • 5 to 8 seats, including the driver’s seat
  • no taxi or stretch limousine classification
  • no salvage, non-repairable, rebuilt, or equivalent title where the local page says so
  • local licence plate or registration where required
  • current vehicle inspection document where required
If your car is close to a model-year cutoff, verify the current local page before you pay for repairs, tires, inspection, or insurance changes. Also check the rental rule before using a rented car.
Lyft Canada’s vehicle help says rental vehicles must be rented through Express Drive to be approved. Current public Express Drive availability is not clearly Canada-wide, so the safer planning assumption is that a Canadian Lyft driver should have an eligible personal vehicle unless the Driver app shows an approved rental option. The rental decision is covered in Rent a Car for Uber or Lyft (Canada).
You also need a smartphone and mobile plan that can handle the Lyft Driver app, maps, messaging, document uploads, and in-app support. Plan for several gigabytes of data a month if you drive regularly.
Province and city Lyft requirements
Lyft maintains province-specific pages for Canada. Use the sections below as a planning checklist, not as a substitute for the live app.
British Columbia Lyft requirements
B.C. is stricter than many new drivers expect. Prepare for a Class 1, 2, or 4 commercial driver’s licence, 3 years of Canadian driving history, an eligible B.C.-plated vehicle, ICBC vehicle registration, a Commercial Vehicle Inspection Report, a commercial driving record, proof of work eligibility, and a GST account number.
Keep B.C. worker protections separate from onboarding eligibility. B.C. app-based delivery and ride-hail employment standards apply to engaged time, distance expense amounts, tips, and minimum wage top-ups. The current rate is $21.43 as of June 1, 2025. That rule can affect your earnings review, but it does not replace the licence, inspection, and document checks required to drive.
Alberta Lyft requirements
Alberta drivers should prepare for Class 1, 2, or 4 Alberta licences and city-specific vehicle ages: Calgary is 2016 or newer, while Edmonton is 2006 or newer. Alberta drivers may also need a vehicle inspection, Alberta 3-year Standard Driver Abstract, Police Information Check with Vulnerable Sector Check, and, in Calgary, a Transportation Network Driver’s Licence that Lyft applies for after the required documents are uploaded.
Chestermere and Stony Plain can also require local business licences, so check your city page before you assume the Calgary or Edmonton checklist is enough.
The Alberta page also says rental vehicles are not allowed for Lyft driving there. Confirm that point before planning around any short-term vehicle.
Ontario Lyft requirements
Ontario rules vary by market. Prepare for a Class G or higher Ontario driver’s licence and different driving-history rules: 1 year in Ottawa, 2 years in Kitchener-Waterloo or Niagara, and 3 years in Toronto or the Greater Toronto Area.
Temporary licences may be accepted in Ontario, but do not rely on that until the Driver app and local page confirm your exact document.
Toronto is one of the stricter public examples. Current Toronto Lyft requirements include a 7-years-or-newer vehicle, Ontario plate, snow or all-weather tires from December 1 to April 30, Class G or higher licence, 3 years driving history, driver screening, Safety Standards Certificate, proof of work eligibility, PTC driver’s licence handled by Lyft, and Driver Training Certification.
If you are checking whether Lyft operates in your market before applying, use Lyft’s city availability page alongside the province and city requirements page.
Other Canada vehicle requirement examples
Current Lyft province pages add more examples outside B.C., Alberta, and Ontario:
  • Quebec: 10 years or newer, Quebec Class 5 or higher, 1 year driving history, registration, insurance, mechanical inspection, and local emblem rules.
  • Nova Scotia: 9 years or newer, Nova Scotia Class 1/2/3/4/4a licence, 3 years driving history, inspection, VSC, Child Abuse Registry check, GST account number, and proof of work eligibility.
  • Manitoba / Winnipeg: 20 years or newer in Winnipeg, Manitoba licensing and insurance documents, commercial driving record, and required Winnipeg driver training.
How to sign up and what to expect
The public Lyft application flow is straightforward, but the document checks can take longer than the form.
  1. Apply on the Lyft driver application page or in the Lyft Driver app.
  2. Upload the driver, vehicle, insurance, work-eligibility, tax, inspection, and local licence documents your market asks for.
  3. Complete the background and driving-record screening.
  4. Finish any required inspection, training, city licence, emblem, or sticker step.
  5. After approval, keep your required documents in the car and go online only in markets where you are approved.
Download links are available from the official app stores: Lyft Driver on the Apple App Store and Lyft Driver on Google Play.
Costs and tradeoffs before you apply
Lyft can be flexible side income, but the better planning question is whether your local rule set and vehicle costs still leave enough net profit.
Check these costs before you commit:
  • inspection fees and repeat inspection risk
  • commercial licence, driver abstract, police check, VSC, training, or local licence fees
  • winter tire or all-weather tire requirements
  • insurance changes or rideshare-use confirmation from your insurer
  • fuel, charging, parking, cleaning, and maintenance
  • vehicle depreciation from rideshare kilometres
  • GST/HST filing work and income tax records
  • dead kilometres between rides, staging areas, inspections, and personal errands
If you also drive Uber or delivery apps, keep the records separated by platform. MyCarTracks can help by automatically recording kilometres, letting you tag Lyft work separately, and exporting reports before tax time through automatic mileage tracking.
Pros and cons of becoming a Lyft driver in Canada
Lyft can fit drivers who want flexible rideshare work in an approved Canadian market, already have an eligible vehicle, and can pass the local document checks.
Potential advantages:
  • flexible scheduling after approval
  • rideshare demand in major cities
  • ability to use one vehicle for more than one approved platform, if insurance and platform rules allow it
  • useful income records from the app, plus your own kilometre log and expense file
Common drawbacks:
  • eligibility can change by city, province, vehicle age, and inspection rule
  • the vehicle absorbs fuel, maintenance, tire, cleaning, parking, and depreciation costs
  • earnings vary by demand, time, location, expenses, and taxes
  • your first weeks may be less efficient while you learn local demand, pickup points, airport or venue rules, and rider-flow patterns
  • the work can include long quiet periods between requests, especially outside peak demand windows
  • rideshare insurance and personal insurance need to be checked before driving
  • approval can stall when one document is expired, mismatched, or missing
  • you do not get employer health benefits just because you drive on the platform
  • app records do not replace a complete CRA kilometre log
How old do you have to be to drive for Lyft in Canada?
Lyft Canada driver requirements use 25 as the minimum age. You still need to meet your local licence, driving-history, screening, document, vehicle, and insurance rules.
What car do you need for Lyft in Canada?
Start with a four-door vehicle with 5 to 8 seats, then check the local page. Vehicle age and inspection rules vary. Toronto lists 7 years or newer, B.C. lists 2017 or newer, Calgary lists 2016 or newer, Edmonton lists 2006 or newer, Quebec lists 10 years or newer, and Nova Scotia lists 9 years or newer.
Do Lyft drivers in Canada need a GST/HST number?
For commercial ride-sharing, yes. CRA guidance for taxi operators and commercial ride-sharing drivers says registration applies to commercial ride-sharing services, even when small-supplier thresholds would normally matter for other businesses. Keep the GST/HST account separate from your income tax and kilometre-log records.
Can you use a rental car for Lyft in Canada?
Do not assume you can. Lyft Canada’s vehicle help says approved rental vehicles must come through Express Drive, but public Express Drive availability is not clearly Canada-wide. Alberta’s Lyft page also says rental vehicles are not allowed there. Use your Driver app and local page before budgeting around a rental.
Does approval in Toronto let you drive anywhere in Canada?
No. Approval is tied to the documents and rules for your region. If you move or want to drive in another province, use Lyft’s province and city page and the Driver app to check the transfer steps before you go online.
