How to switch recording mode – iOs (iPhone)
By default, MyCarTracks operates in Automatic Recording Mode, which detects when you are driving and records all journeys automatically. However, if you prefer to start recording manually, you can switch modes by following these steps:
  1. Run the MyCarTracks app and swipe up the bottom panel.
2. Touch the Disable recordingbutton. After that touch the Automatic button on the bottom. On every touch the mode changes (from Automatic to On Charger and then to Manual).
3. After you change to Manual don’t forget to touch the START RECORDING button or enable the switch in case of another Automatic mode.
Source: How to switch recording mode – iOs (iPhone)
