MyCarTracks can’t crop recorded tracks directly from the web console but it is possible with some external tool that can handle GPX files. One of such is https://gpx.studio/. Follow these steps to cut any recorded track:
- Open the MyCarTracks web console and go to Tracks.
- Search for the track you want to cut and click on it – either directly on the map or in the left column – so that a popup will be shown with the Show detail button. Click the button.
- On the track details page right above the map are buttons and one is labeled Export. Click it and select GPX. Save the exported GPX to your PC.
- Now open the gpx.studio. On the top is a menu where you can select Load GPX. Choose the exported GPX from disk to load it.
- On the bottom is a slider where you can select which part of the track you want to keep. After you select the part click on the confirm button – a small confirmation button on the bottom right – and confirm with Proceed.
- Now click on Export on the top. Leave only the option Time selected and save it to your PC.
- Go back to the MyCarTracks web console, go to Tracks, and on the top select the List tab.
- Here click the “+” button and select the Import track option.
- Select the modified GPX file from your PC and also update the options on the import form.
- Click the Run import button.
Source: How to crop recorded track
