Stay up to date with the latest MyCarTracks Android app improvements here.
Android app update 2.8.3.7
This release focuses on easier setup, clearer trip review, and more reliable tracking.
- Improved the setup experience with a clearer introduction and simpler guidance through the app.
- Made tracking setup issues easier to spot and resolve before they affect recording.
- Improved trip review with clearer reviewed status, reminders, and recent-drive summaries.
- Added usability and reliability improvements across trip browsing, automatic categorization, map previews, and language support.
This release is mainly focused on usability, tracking reliability, and interface polish.
Android app updates 2.8.3.8–2.8.4.0
These updates add track export and make trip details and tracking checks more useful.
- Export an individual track directly from the app as GPX, KML, CSV, or TCX.
- Added quick actions in trip details for editing a trip, changing its category, setting its purpose, and marking it as reviewed.
- Added average GPS accuracy and mileage value information to statistics screens, with improved chart-point selection.
- Open trips needing review directly from a review notification.
- Added tracking-checklist warnings for missing recent recording activity and disabled Wi-Fi, with options to dismiss or stop checking these items.
- Added a Show IDs setting and copy actions for track, vehicle, and job IDs to help when working with support or an AI assistant.
- Improved Bluetooth permission handling to avoid failures when permissions are missing or revoked.
Android app updates 2.8.4.1–2.8.4.2
These updates expand job management and make it easier to review work on your phone.
- Redesigned the jobs list, job details, customer details, and job logs for clearer navigation.
- Added date and status filters that remember your selections.
- Added job editing and bulk Mark as Done and Mark as Resolved actions, with available actions based on job ownership and assignment.
- Made schedules, work progress, and job logs easier to find in job details.
- Added quick access to navigation and job-log actions, plus clearer guidance on empty screens.
- Improved synchronization of job changes and updates to vehicles and tracks made through the web app.
Android app update 2.8.4.3
This release adds odometer corrections and makes trip review more convenient.
- View trip odometer readings and existing correction details in the app.
- Correct the odometer reading at the end of a completed, synchronized trip when your account has permission. Preview the adjustment before applying it.
- Edit or remove an existing correction and preview how it changes subsequent odometer readings.
- See who made a correction and when, with clearer loading, confirmation, and error messages.
- Added a Mark All Reviewed shortcut to the Tracks screen when manual category review is enabled.
Android app update 2.8.4.4
Manage vehicle expenses and receipts directly in the Android app, with new ways to find and review your trips.
- Added an Expenses section to create, view, edit, and delete expenses, according to your account permissions.
- Added receipt scanning and document import to help fill in expense details. Review the suggested values before saving; scanning and receipt options depend on account and device support.
- Added receipt and invoice attachments, previews, upload status, and retry actions.
- Added refueling details, including fuel amount, fuel type, full-tank status, and odometer readings.
- Added expense filters for date, current vehicle, expense type, and items needing attention, along with daily and monthly totals and bulk deletion.
- Added merchant location lookup and map views, plus navigation between expense details without returning to the list.
- Added custom date ranges and purpose-text filtering for tracks.
- Added previous and next trip navigation within your filtered results, and reorganized trip actions for easier access.
Android app update 2.8.4.5
This release makes manual trip entry easier and adds more control over your settings.
- Refreshed the manual trip screen with a clearer layout and an expandable route map preview.
- Improved address suggestions and added clearer guidance when a driving route cannot be calculated.
- Improved list refreshes after adding a trip or saving a vehicle, along with vehicle selection and status badges.
- Improved work-hour scheduling when the phone’s time zone or clock changes, including handling daylight saving time transitions.
- Improved work-hour settings import and restore handling to avoid applying invalid schedules.
- Added Data and Privacy settings to manage optional usage analytics, advertising measurement, and ads personalization. You can change these choices at any time.
Android app update 2.8.4.6
This update improves manually added trips, map browsing, and synchronization in trip details.
- Fixed differences between the route preview and the saved manual trip, keeping distance, duration, and estimated end time consistent.
- Preserved your map zoom and position when showing or hiding the chart and when trip data refreshes.
- Improved the expandable chart panel so you can explore the chart alongside the map.
- Improved trip synchronization and odometer refreshes, including preventing repeated sync actions while a trip is already synchronizing.
Android app update 2.8.4.7
This release adds dark mode, more useful map views, and easier Bluetooth-based recording.
- Added Light and Dark appearance options in Display settings, with improved colors across screens and charts.
- Added map layers for geofence boundaries, customer locations, and active jobs available to you. Toggle each layer in Display settings; sign in and register your device to use these layers.
- Added a Bluetooth devices and vehicles screen to choose which devices can start recording and assign a vehicle to each device for automatic trip recording.
- Added optional Bluetooth battery saver (BETA) to reduce battery use while waiting for a connection. It is off by default. Some phones may delay or miss automatic recording; turn it off if trips are missing.
- Added vehicle search by name or description.
- Improved Bluetooth connection and reconnection handling, keeping the vehicle assigned to an active trip consistent.
- Improved trip statistics charts and selection of the current or previous month and year.
- Fixed the current-vehicle display in Expenses when expense permissions are unavailable.
Android app update 2.8.4.8
Manage locations and customers directly in the Android app, with improved Smart categorization and new search options.
- Added Locations (Geofences) under More. Create, edit, and delete geofences, customers, alerts, and address rewrite rules, according to your account permissions.
- Draw and adjust geofence boundaries on the map, set a radius, view zone area, and customize point-of-interest colors and icons.
- Select saved customers when creating or editing jobs, and open their shared details directly from a job.
- Added search to the Locations, Jobs, and Expenses lists.
- Improved Smart categorization and added optional Auto-review matched trips. Off by default, this option marks matched new trips as reviewed when Smart categorization and manual review are enabled.
- Added More > AI Assistant, a shortcut that opens the Assistant in your browser.
