If you deliver with Uber Eats, mileage tracking is one of the records that matters most. It affects your tax deductions, your real hourly profit, and your ability to explain what was business driving versus personal driving. If you want an app that handles the log while you work, MyCarTracks mileage tracking gives you that starting point.
Uber Eats can create more business miles than the payout screen makes obvious. A single day can include driving to pickups, completing dropoffs, handling parking or tolls, buying delivery supplies, and sometimes mixing in personal stops. A clean log keeps those pieces separated before tax time.
Where mileage fits in your Uber Eats tax file
The closest tax-source family keeps coming back to the same point: you do not file from one document alone. Your tax summary, 1099 forms when they apply, receipts, and mileage tracking records all work together.
That matters because you may still need to file and report income even if a form never arrives. Your mileage log is part of the proof that shows what it cost you to do the work. If you want the form side laid out separately, use Uber Eats Tax Forms.
Which trips you should log
Your mileage log should show the trips that connect directly to delivery work:
- Driving tied to accepted Uber Eats deliveries.
- Miles from merchant pickup to customer dropoff.
- Miles between deliveries when you are still actively working.
- Delivery-related trips to buy bags, phone mounts, or other supplies used for Uber Eats.
- Parking and tolls connected to those delivery routes.
- Repositioning that has a clear delivery-business purpose.
If a trip belongs in the business file, write down enough detail to explain it later: date, route or locations, business purpose, vehicle or delivery mode, and any toll or parking cost tied to it.
Which trips you should keep separate
Not every mile on a delivery day is a business mile. Keep these out of the business total until you know the exact local treatment:
- Personal errands while you are online.
- Family, school, shopping, or meal stops.
- Driving with no accepted delivery or clear business purpose.
- Uber rideshare or another app’s miles if they are not tagged separately.
- Home-to-work or work-to-home driving when local rules treat it as personal commuting.
When in doubt, log the trip and classify it later. Missing mileage records are harder to rebuild than extra trips that can be marked personal.
How to build mileage tracking into the shift
You will get cleaner records if you use the same workflow every time:
- Start mileage tracking before the first delivery-related drive.
- Tag the shift as Uber Eats.
- Add notes for pickups, tolls, parking, supply stops, or unusual waits when they matter.
- Split out any personal stop instead of leaving it inside one long route.
- Switch tags when you move to another app or another type of work.
- Compare the mileage log to your Uber Eats earnings and receipts each week.
That weekly check is where low-profit routes usually show themselves.
How the US deduction methods work
The US rule set gives you two main ways to handle vehicle expenses: the standard mileage method or actual expenses.
Standard mileage method
For 2026, the IRS business standard mileage rate is 72.5 cents per mile. This method is often simpler because you multiply qualifying business miles by the IRS rate, then add deductible parking and tolls where allowed.
The actual expense method uses your real vehicle costs instead: fuel, insurance, repairs, registration, tires, lease payments, depreciation, parking, and tolls. Then you apply the business-use percentage.
If your car costs $8,000 for the year and 75% of your total miles were business miles, you would generally use 75% of those vehicle costs as the business share. That is why total annual miles and business miles both matter.
What else the IRS expects
The IRS uses an ordinary-and-necessary business standard, so your log should be created close to when the driving happens. Keep records that show:
- Date of the trip.
- Mileage or distance.
- Starting point and ending point.
- Business purpose.
- Vehicle used.
- Total miles for the vehicle during the year.
- Parking and toll receipts where available.
If you choose the standard mileage rate for a car you own, the timing of that choice matters in the first business-use year. If you lease the car, the standard mileage method generally has to stay in place for the lease period once chosen. Review IRS Publication 463 before switching methods.
Also keep one thing clear: parking and tolls can still be deductible, but traffic tickets and fines are not.
How Canada wants your kilometres tracked
Canada does not use the IRS mileage-rate system. The CRA wants total kilometres and business kilometres when a vehicle is used for both business and personal driving, and the CRA motor vehicle record guide keeps these details explicit.
Your business-trip record should show:
- Date.
- Destination.
- Purpose.
- Kilometres driven.
If you use more than one vehicle, keep a separate log for each one.
What to do in the UK, Germany, and other markets
Uber Eats operates in many more countries than this guide can cover one by one, so use the local official tax rules before assuming a US-style mileage deduction applies everywhere.
United Kingdom
The UK question is less about a cents-per-mile IRS-style rate and more about your local self-employed records, VAT position where relevant, and what counts as a business motor expense in your own filing setup.
Germany
Germany is more partner- and VAT-oriented in the official Uber Eats source set. That means your kilometre logs still matter for real cost review, but the tax treatment can depend on your partner structure and business registration.
Global note
Uber Eats is active in many more places than these sections name directly. Use representative markets and then verify the local tax treatment before filing from a mileage record.
What to keep with the mileage log
Do not store mileage by itself and hope you can explain it later. Keep it together with:
- Uber Eats trip records.
- Payout records.
- Tax summaries and forms.
- Parking receipts.
- Toll receipts.
- Delivery bag and supply receipts.
- Insurance records.
- Notes about vehicle or delivery-mode changes.
That full file is what makes your log easier to defend.
Questions you may still have
Do you still need mileage tracking if Uber Eats never sent you a 1099?
Yes. The filing obligation and the mileage log do not disappear just because a 1099 did not show up.
Can you claim gas and the standard mileage rate together?
No. If you take the standard mileage method, you do not also claim gas as a separate vehicle cost under that same method.
Does mileage tracking still matter if you earned under $600?
Yes. The tax-form threshold and the need for clean business records are not the same question.
Use MyCarTracks to record delivery miles automatically, tag Uber Eats trips, and split personal stops before they distort the monthly totals.
Later, keep your business mileage reports with your Uber Eats payouts and receipts. If you want the broader product overview, use MyCarTracks.
Quick checklist
Before tax season, make sure you still have:
- Uber Eats trip, payout, and tax-summary records.
- Mileage logs by vehicle or delivery mode.
- Total annual miles for each vehicle.
- Parking and toll receipts.
- Delivery bag, phone, and supply receipts.
- Separate tags for Uber Eats, rideshare, and personal driving.
