Thumbtack Pro Requirements
If you want to offer services on Thumbtack, you need more than an account. You need a complete profile, a service area you can actually cover, local credentials where required, and a mileage tracking system that supports quotes, payments, reviews, and job records.
Thumbtack connects customers with local service providers across many categories. This guide shows the basic requirements and the record setup you need before you start buying leads.
To keep the trip side of that setup organized early, MyCarTracks automatic mileage tracking helps separate estimate and work trips, while Thumbtack’s Pro Basics and Terms of Use outline the account, service, and legal context behind the signup flow.
Who can join Thumbtack
You can sign up as a Thumbtack pro if you meet the platform’s basic eligibility rules and the legal requirements for the services you want to offer.
Thumbtack’s Terms of Use say access is available only to people who are at least 18 and able to form legally binding contracts. The same terms also say service professionals represent that they, and anyone working for them, are properly qualified, experienced, and licensed, certified, bonded, and insured where the law requires it.
That means the platform does not replace local business rules. You still need to check whether your service requires licensing, insurance, permits, registrations, or written customer contracts before you start buying leads.
How to get started
Step 1: Create your Thumbtack account
Creating an account is straightforward. You add your contact information, choose the services you want to offer, define the areas you serve, and keep a valid payment method on file for lead-related charges.
Thumbtack may also request identity information or run checks through vendors as permitted by law. Keep those notices with your business records instead of relying only on what appears inside the app.
Step 2: Build a strong profile
Your profile is your storefront. It should explain your services clearly and make it easy for a customer to decide whether you are a fit.
A strong profile usually includes:
  • a plain description of what you do
  • the specific services and job types you accept
  • service-area limits
  • photos of completed work where appropriate
  • credentials, certifications, or years of experience
  • review history and contact responsiveness
Profiles are not just marketing. They also affect lead quality. A vague profile tends to attract vague leads.
Step 3: Choose your services carefully
Thumbtack covers a wide range of categories, including home services, events, lessons, wellness, and business services. Choose only the services you can legally and profitably provide.
If one category requires a license or insurance and another does not, keep those records separated. That makes customer communication and compliance checks much easier later.
Step 4: Set your service area
Tell Thumbtack where you work and how far you are willing to travel. This matters more than many new pros expect. A larger radius can create more leads, but it can also create more wasted estimating time, more mileage, and more low-margin jobs.
Before expanding your radius, compare your lead costs and service expenses against what you actually book.
Optional steps that help you stand out
Complete a background check
Thumbtack’s safety page says all new account owners must undergo a criminal background check through a third-party provider when they create a Thumbtack account, and that continuous checks can happen annually. Save any badge or verification notices you receive, especially if customers regularly ask about screening.
Understand Thumbtack’s lead and payment system
Thumbtack’s Pro Basics page says pros can set weekly budgets and maximum lead prices. It also explains that you pay when an actual customer chooses to contact you directly. That means a “requirement” on Thumbtack is not only legal or identity-related. It is also operational. You need a pricing system that can absorb lead costs.
Use the Thumbtack Earnings Guide and Thumbtack Mileage Guide together if you want to see whether your targeting settings are producing workable leads.
Stay licensed and insured
Some categories can run with minimal formal paperwork. Others cannot. Electricians, movers, certain repair pros, event vendors, child-related services, and pros entering customer homes often face stronger insurance or licensing expectations.
Keep your local records organized in one place. If you need a dedicated workflow, use the Thumbtack Licenses and Local Requirements guide.
What to expect as a Thumbtack pro
Managing leads and communication
Your day-to-day success depends on how well you handle incoming leads. Good Thumbtack habits include:
  • replying quickly
  • asking enough questions to scope the job
  • confirming location and travel requirements
  • stating what is included and excluded
  • saving messages and estimate notes
Thumbtack’s Safety for Pros guidance recommends setting expectations before the job, including the work environment, what the work involves, and payment terms.
Reviews and reputation
Reviews matter because they influence customer trust and search performance. Ask satisfied customers for reviews, respond professionally when needed, and keep proof of scope and payment in case a complaint appears later.
For service businesses, a strong record file often matters as much as a strong review file. The record file explains what was promised, what was charged, and what actually happened.
Taxes as a Thumbtack pro
Thumbtack pros are generally not treated as employees of the platform. That means you should keep your own records for income, lead costs, mileage, receipts, and tax forms.
The easiest setup is to start immediately with:
Mileage tracking and record setup
Before your first estimate, decide how you will save business mileage, mileage logs, receipts, and customer notes. A clean mileage log supports both compliance reviews and later tax deduction or reimbursement reviews.
Market notes
Thumbtack’s active pro materials, safety pages, and terms are written for the US market. Use US state and city rules for licensing, permits, contractor registration, and tax questions.
If you run a local service business in Canada, use Canadian rules for registration, insurance, GST/HST, and vehicle records rather than assuming a Thumbtack-specific workflow applies.
If you run a local service business in Europe, use country-level rules for registration, VAT, invoicing, and worker status. Do not assume a US-style 1099 or platform badge workflow applies.
Mileage tracker app workflow
Set up a Thumbtack tag before your first estimate. MyCarTracks can separate estimate trips, paid jobs, supply runs, and personal driving so your records stay usable for both profitability reviews and tax time. The automatic mileage tracking setup is the cleanest place to start when mileage logs and reimbursement notes need to stay matched to the same jobs.
Related guides
If you handle more than one source of self-employed income, compare your recordkeeping with another platform-specific workflow such as the Uber Requirements guide, Walmart Spark Tax Guide, or Airbnb Tax Guide.
