Self-employed people often mix up three different ideas: the personal standard deduction, itemized deductions, and business expenses. They are not the same.
The standard deduction and itemized deductions are personal return concepts. Business expenses are used to calculate business profit. A self-employed person may take the standard deduction personally and still keep business expense records for Schedule C or equivalent business reporting.
Personal deductions vs business expenses
Business expenses reduce business profit when they are ordinary, necessary, documented, and allowed. The personal standard deduction or itemized deductions reduce taxable income on the individual side of the return. They do not replace business bookkeeping.
2026 standard deduction amounts
For tax year 2026, IRS inflation adjustments list a standard deduction of $16,100 for single taxpayers and married individuals filing separately, $32,200 for married couples filing jointly, and $24,150 for heads of household.
Itemized deduction concept
Itemized deductions may include certain personal deductions when itemizing is better than the standard deduction. The correct choice depends on personal facts. It does not decide whether business receipts, mileage logs, or income records should be kept.
Common itemized deduction areas can include mortgage interest, certain state and local taxes, charitable contributions, and medical expenses subject to rules and limits. These are personal return items. They should be stored separately from business expense records so the business profit calculation stays clean.
Business records still matter
Even if you use the standard deduction, keep business receipts, mileage logs, invoices, bank statements, and tax forms. The business profit calculation still needs support.
Common mistake
The common mistake is saying, “I took the standard deduction, so I do not need business expense records.” That is wrong for a self-employed business file. The personal deduction choice and the business expense file answer different questions.
Example
A self-employed consultant may have $70,000 of business income and $14,000 of business expenses. Those business expenses are used to calculate business profit. After that, the consultant may still choose the personal standard deduction or itemize personal deductions depending on their personal return. The standard deduction does not erase the need to prove the $14,000 of business expenses.
Why the confusion happens
Tax software and articles often ask whether you will take the standard deduction or itemize. Self-employed people hear that question and assume it controls every deduction. It does not. Business expenses live in the business profit calculation. Personal deductions live on the personal side of the return.
What records each bucket needs
Business expenses need receipts, invoices, mileage logs, payment records, business-purpose notes, and allocation for mixed-use costs. Itemized personal deductions need their own proof, such as mortgage interest, certain taxes, charitable contributions, medical expenses, or other allowed items depending on the tax year. The standard deduction usually needs less paperwork, but it does not reduce business recordkeeping.
Vehicle and home office examples
Business mileage is a business record. A home office can be a business deduction when the rules are met. Neither one is the same as choosing the personal standard deduction. Keep the mileage log and home office support even if the individual return uses the standard deduction.
For 2026, business mileage uses the 72.5 cents per mile rate when the standard mileage method is available and chosen. That is not an itemized personal deduction. It is part of the business expense file.
Canada and Europe note
The exact terms differ outside the US. The broader principle still helps: separate business-profit records from personal tax relief records. That separation makes conversations with a tax professional faster and cleaner.
Good filing-season question
Ask two separate questions. First, what business expenses reduce business profit and what records support them? Second, should the individual return use the standard deduction or itemize personal deductions? Answering them separately keeps the filing workflow clear. It also helps avoid throwing away business receipts because the personal standard deduction seems simpler.
This distinction is especially important for first-year freelancers and contractors. Many people hear “standard deduction” and stop organizing receipts, then later discover that their business profit still needed expense support. Keep the business file complete even when the personal return stays simple.
Can I take the standard deduction and still deduct business expenses?
Yes. The standard deduction is a personal deduction. Supported business expenses are used to calculate business profit.
Can I switch between standard and itemized deductions?
Often, taxpayers compare the options each year. The better choice can change when mortgage interest, taxes, charitable giving, medical costs, or filing status changes.
Is home office an itemized deduction?
For a self-employed person, home office is generally reviewed as a business deduction when the rules are met. It is not the same as choosing to itemize personal deductions.
Do I need mileage records if I take the standard deduction?
Yes, if you claim business mileage. The personal standard deduction does not replace the mileage log.
