IRS Mileage Rate From July 1, 2026
The IRS has increased the standard business mileage rate to 76¢ per mile for eligible business travel from July 1 through December 31, 2026. Business miles logged before July 1 still use the earlier 72.5¢ rate.
That makes 2026 a split-rate year, so the trip date matters when you calculate deductions or reimbursements. For every 1,000 eligible business miles in the second half of the year, the new rate adds $35 compared with the previous rate.
Have you already updated your mileage calculations or reimbursement process? And what’s your approach for keeping the two periods clear in your records?
Read the full July 2026 IRS mileage-rate update
For split-rate years, it helps to treat the rate as a property of the trip date rather than a global setting. Most mileage tools let you add a second rate row with an effective date, so July 1 sorts itself out and you aren’t re-editing trips by hand. I’d also keep a short note in the records explaining why two rates appear in 2026 — it saves explanation if the numbers are ever questioned and makes any reimbursement policy update easier to communicate.
Welcome to the MyCarTracks community, @florineljucovic16811! Thanks for sharing these suggestions.
MyCarTracks already handles rate changes exactly as you described: it automatically applies the appropriate mileage rate based on each trip’s date, keeping trips under their respective rates. Our reports also list the rates alongside their effective dates, so it’s clear which rate applies to each period.
For anyone who needs different rates, we also support manual rates with an effective date. You can set your own rate and when it starts, and MyCarTracks will apply it to trips accordingly.
